Phase correct panning.
Page 1 of 1 [2 Posts]
bachus
PostPosted: Tue Apr 01, 2008 7:33 am    Post subject: Phase correct panning. Reply with quote  Mark this post and the followings unread
I’m looking for a plug-in that will allow me to do phase/time correct panning on my DAW. The figure below shows the problem I want to address. The path from A to L is shorter than the path from A to R. The reverse is true for B. Common simple L/R amplitude ratio control is adequate but not ideal as human hearing uses both amplitude and phase/time delta to derive the position of a sound source.
If there is no such plug-in I need direction to an introduction to the VST API. The material I have thus far located is way too dense for me to start with.
 Filesize:  39.88 KB
 Viewed:  293 Time(s)
bachus
PostPosted: Tue Apr 01, 2008 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
How 'bout that! Using this as a search key got me several D'Oh!
