Surgeon
Posted: Mon Apr 07, 2008 11:34 am Post subject:
Strange dried ooze... Subject description: Coming out of my electronics. |
| Well, I'm new to circuit bending. I've only been fooling around with it for a few days. But today, when i looked at the circuitry in this Yamaha SHS-10 that I've been fooling with, I noticed some strange dried up yellow-brown goo around some of the metal pieces. What is this stuff? Is it battery acid or something? Is this normal? Am I harming the circuitry? How could I properly clean this off? |
Joined: Apr 03, 2004 Posts: 24582 Location: The Netherlands, Enschede
Audio files: 308
Posted: Mon Apr 07, 2008 11:40 am Post subject:
Welcome,
do you have a picture? _________________ Jan
Posted: Mon Apr 07, 2008 11:43 am Post subject:
Well, you might have harmed the parts and in that case you can compare this to the goo that results from dropping a 13-ton weight on top of someones grandmother.
Anyways, to electro-music.com _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr Last edited by elektro80 on Mon Apr 07, 2008 11:46 am; edited 1 time in total |
Posted: Mon Apr 07, 2008 11:45 am Post subject:
However, it could be old resin residue or something from the soldering...
Does it smell? _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Surgeon
Posted: Mon Apr 07, 2008 12:03 pm Post subject:
Unfortunatley, I don't have a camera so I can't take a picture, and infact I never actually soldered anything yet. The only thing I've done up to this point is take off the casing and explore the circuitry with my test leads.
The odd part is that the goo, which kinda looks like dried honey/wood glue, isn't anywhere near the batteries. |
Audio files: 308
Posted: Mon Apr 07, 2008 12:05 pm Post subject:
In that case I'd go with elektro, old resin  _________________ Jan
Posted: Mon Apr 07, 2008 12:23 pm Post subject:
| Blue Hell wrote: | In that case I'd go with elektro, old resin  |
I´d go with me too..
Flickr |
Surgeon
Posted: Mon Apr 07, 2008 12:29 pm Post subject:
well in that case, i guess i have no choice!
I guess I'll clean the stuff off and then take note if it ever comes back.
Thanks for the help! |
Posted: Mon Apr 07, 2008 12:39 pm Post subject:
What you really should be looking out for are those moments when the magic smoke is trying to escape from the components. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
RF
Audio files: 28
Posted: Fri Apr 18, 2008 10:16 am Post subject:
This brown goo just sounds like glue around the base of electrolytics...
If it ain't broke, why mess with it?
bruce |
Inventor
Audio files: 267
Posted: Fri Apr 18, 2008 4:58 pm Post subject:
Could be electrolytic juice leaking out of an old capacitor. Or it could be dried up electron sweat. Those little e's move at half the speed of light, so they sweat a lot. Apply some strong deodorant and don't turn the knobs so fast anymore. Then again, it could be flux from a flux capacitor, in which case you can use it to build a very small time machine. _________________ "Let's make noise for peace." - Kijjaz |
otherunicorn
Posted: Fri Jun 20, 2008 10:51 pm Post subject:
A rusty yelow color in amounts substantial enough to stick electros to the circuit board is in all likely glue. They use it to stop heavier components wobbling, thus breacking their connections to the PCB.
Two things should be noted about it though.
1) it is corrosive, and sometimes will cause circuit failure (yes, even when dry)
2) it is known by the rather amusing name "gorilla snot". _________________ http://www.cgs.synth.net/ |
badstatic
Posted: Wed Sep 03, 2008 2:06 pm Post subject:
It's called 'Ectoplasm' and it occurs in the presence of ghosts/ghools/spirits.
The best thing you can do is to get a white haired catholic priest to perform an exorcism on the machine. Just be sure to disconnect the power supply before he drenches the machine in holy water. |
Audio files: 308
Posted: Wed Sep 03, 2008 3:17 pm Post subject:
imaguitargod
Posted: Fri Sep 05, 2008 7:50 am Post subject:
| badstatic wrote: | | It's called 'Ectoplasm' and it occurs in the presence of ghosts/ghools/spirits. |
"Who ya gunna call?" _________________ Assistant brewer for Hoppin' Frog Brewery
My Noise Project: I Like Pie (MySpace Page) |
badstatic
Posted: Sat Feb 21, 2009 6:34 pm Post subject:
Have you seen a rather amazing film called PI ?
The main character has a custom computer system, which briefly becomes alive and self aware (skynet style) ..... It dies shortly after, but not before producing some strange sticky gunk, and a 216 digit number.
You may have just stumbled upon on the 'true name of god'. |
