janvanvolt
Joined: Nov 24, 2005 Posts: 285 Location: Mainz, Germany
Posted: Thu Jul 15, 2010 4:04 am Post subject:
Can't wait to get the PCB I got most of the chips now and also finished measuring out the 1% ones out the 10% bag (for the 47n's).
Regarding the SMD: It's not too hard, with a small solder tip it's easy to do. _________________ Homepage - http://www.czmok.de
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me |
/mr
Joined: Aug 05, 2007 Posts: 223 Location: Elektron City, Sweden
Posted: Thu Jul 15, 2010 4:16 am Post subject:
| eframp wrote: | | I need someone to show me the Secret SMT Technique then, 'cause I seem to have a hell of a time with them. |
I had almost no experience with soldering surface mount when I built my first JH project, but found it easier than expected actually. Jürgen, what PCB factory do you use? The solder pads are really easy to solder, they wet perfectly. Better than most other boards, it makes both SMT and hole mount a joy to solder.  |
whomper
Posted: Thu Jul 15, 2010 5:15 am Post subject:
Where can I find %1 caps? I will probably not go into selecting caps from a big bag.
Is there perhaps a part number for both of them that I can use? _________________ Erez Yaary
Home Page: http://www.yaary.com
Buy my CDs at http://www.mellowjet.de |
jhaible
Posted: Thu Jul 15, 2010 5:30 am Post subject:
| whomper wrote: | | Where can I find %1 caps? |
http://www.jhaible.de/vocoder/living_vocoder.html
JH. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
guitarsandsynths
Posted: Thu Jul 15, 2010 10:38 am Post subject:
This is how I did on my resonator projecct:
Melt the solder on one pad first, then place the smt cap with a pair of tweezers. Then solder the other side. I too thought it was going to be impossible. I'm a real newbie. It was not too hard, but there were fewer smt caps in that project. |
JoeMorris
Posted: Thu Jul 15, 2010 10:49 am Post subject:
| I agree with the above method of wetting one pad with solder before you start, but I use a small flat-tip screwdriver to maneouvre and hold the upper surface of the smt cap into place and then use the iron in my other hand to re-melt the solder on the pad. I remove the iron whilst i keep pressing down with the screwdriver until the solder sets again. then obviously the other pad is easy to solder as the cap is already firmly in place. once you get in the rhythm its actually pretty easy. |
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Thu Jul 15, 2010 5:12 pm Post subject:
yes jurgens boards seem better than some for SMT they wet very well
if the board is new and has not been stored for too long and kept clean
no finger prints! . I have not had to use a flux paste or pre wet any of the pads so far on any of jurgens boards
this is my method, it is quite simple
I found by holding all the parts in place with a tiny bit of blue tack on one end and soldering the other side first it is goes very smoothly note: the blue tack must only be on top of the component and pushed down onto the board so as to hold the component in place, aligning the component correctly is not difficult then as it allows small adjustments to be made
you must also allow the blue tack to cool to the touch before removing it before soldering the other side, this happens fairly quickly, but don't rush this part if you do don't panic what residue remains can be removed by dabbing it with more blue tack it just adds more time to the process
the use of blue tack does not seem to affect the solderability in any way
once visually removed and i have had no faults caused by this method so far
this way for 143 SMT caps you may only need to pick up the iron twice
as i said previously this method is very quick, much quicker than thru hole.
cheers
denis |
diablojoy
Posted: Thu Jul 15, 2010 5:23 pm Post subject:
| Quote: | | Where can I find %1 caps? |
you could also try rush online capacitors
around 0.49 GBP each for styrene 10nf or poly 47nf in F or D tolerance though as yet have not checked physical sizes to see if they will fit on the board |
zthee
Posted: Fri Jul 16, 2010 12:38 am Post subject:
A quick question...
http://www.jhaible.de/vocoder/schematics/channel_5.pdf
Inputs and outputs are confusing me - It probably means that the bottom pin goes INTO the patchbay (The pin is an output, but labled as an input?)?, and the output is what comes OUT of the patchbay (The pin is an input, but labled as an output?)?
Just needed it clarified! Thanks!
Edit: What's throwing me off is the | Quote: | *) Connect patchbay outout to cw end of 5k audio taper potentiometer.
Connect wiper to middle pin of connector.
Connect ccw end of Pot to GND. |
Right now the middle pin is labled patchbay output: And I'm supposed to connect that to CW end, and then I'm supposed to connect the wiper to the middle pin!
It just doesn't add up for me...
(I guess it's just a small detail, but I'm trying to get my head around all this...) _________________ http://www.thehumancomparator.net/ |
jhaible
Posted: Fri Jul 16, 2010 12:59 am Post subject:
Sorry for the confusion.
From the PCB viewpoint, the lowest pin is the analyzing filter output, and the middle pin is the envelope detector input.
But if you look at the matrix as a module, that can (optionally) be inserted at this break point, the matrix' input signal will come from the lowest pin of the PCB, and the matrix' output will go to the middle pin.
And if you look at channel potentiometer(s) as another (optional) module, the matrix output will go to the potentiometer's "input" (cw end), and the potentiometer's "output" (wiper) then goes to the env detector input (middle pin on PCB).
zthee
Posted: Fri Jul 16, 2010 1:04 am Post subject:
That's the way I thought it was - now it's all clear!
OH - And while I have the possibility to beat everyone to it; 10K log pots will be OK instead of the 5K? _________________ http://www.thehumancomparator.net/ |
jhaible
Posted: Fri Jul 16, 2010 1:38 am Post subject:
| zthee wrote: | Thanks!
OH - And while I have the possibility to beat everyone to it; 10K log pots will be OK instead of the 5K? |
I think so. The control response may be a tad more warped than with 5k pots, though. The wiper is loaded with less than 7kOhms on some channels.
Jh. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
robotmakers
Posted: Mon Jul 19, 2010 7:57 am Post subject:
Please excuse my returning to my earlier point, and I promise I'll drop this if it's annoying to the forum. I'm posed with a dilemma that may be relevant to these discussions. I don't have the time or desire to build the board myself (which is of course my problem). I've had conversations with folks who would build one for me and have found the cost to be prohibitive. For example, the comparison I made is that I could purchase a vintage Moog vocoder for about 2/3rds the cost of having the Haible Vokoder built for me. Yes, there are performance differences, but the Moog unit in the long run will likely have more investment value. Just my personal calculus.
Which then begs the question for me, could this board (with the same circuitry) be designed such that it would cost less to construct (after taking into account the value of the builder's time)? Could a layout employing far more SMT components (rather than through-the-hole) be prepared for automated stuffing? Would this be more economical for the builder? Could this also be more profitable for Mr. Haible? I think so, as it would dramatically increase the number of units he could sell and with more profit margin. Maybe this could be subcontracted to someone who has experience with automated SMT board runs?
Thanks for your time,
Roger |
jhaible
Posted: Mon Jul 19, 2010 11:40 am Post subject:
| robotmakers wrote: | | For example, the comparison I made is that I could purchase a vintage Moog vocoder for about 2/3rds the cost of having the Haible Vokoder built for me. |
Or you could compare it with a MAM VF11 or a Paia Vocoder and come to even more different results. Both are good vocoders, and I bet the Moog vocoder is even a little better than the MAM and Paia.
But I'm shure you can have a Living Vocoder built by someone (not me) for less than half the price of an EMS 5000. I'm quite aware that I still can miserably fail in me efforts, but EMS 5000 and Sennheiser are the reference for me, by which a want the Living Vocoder to be measured - not the Moog.
Could I design a Living Vocoder in SMT technology? Probably. But for most diy-ers this only causes problems. And I'm not in the manufacturing business - only in the PCB business.
Would I be interested in re-designing the Living Vocoder in SMT technology and licence it to someone who *is* in the manufacturing business? Certainly, if you're making me a commercially interesting offer.
robotmakers
Posted: Tue Jul 20, 2010 9:22 am Post subject:
Thanks for your thoughtful reply. I'm glad that you're open to the possibility of a manufactured SMT version. Perhaps someone will see this post and it will start a ball rolling somewhere. Until then, unfortunately I don't have a deal in hand for you. But, who knows?
Best wishes,
Roger |
StephenGiles
Posted: Wed Jul 21, 2010 4:25 am Post subject:
Many constructors like myself with what are best described as "tired eyes" curse the very existence of SMD - I've been used to "normal" sized components for over 30 years and I won't change now. Hopefully, thanks to TI, my stocks will last me!!!
For me, normal sized components look much prettier  |
magman
Joined: Feb 04, 2009 Posts: 363 Location: Liverpool, UK
Posted: Wed Jul 21, 2010 5:45 am Post subject:
| robotmakers wrote: | | Thanks for your thoughtful reply. I'm glad that you're open to the possibility of a manufactured SMT version. Perhaps someone will see this post and it will start a ball rolling somewhere. Until then, unfortunately I don't have a deal in hand for you. But, who knows? |
There is a possibility of a third option as well, so that you don't have to wait for an SMD version.
It might be possible for someone to organise a group-buy, where the thru-hole PCB's JH is developing are professionally stuffed and soldered using machinery. There are a number of small companies that have the capability to stuff and wave-solder boards much cheaper than paying for someones time to manually do the same, you just have to look at Synth makers like Macbeth, I'm sure they don't get modules made in the hundreds (probably nearer 20-50) and Macbeth have a link to this type of company on their website:
http://www.diatron.co.uk/
There would then be the assembly phase, to make a workable instrument, but this is less critical and more subjective than the main PCB assembly. This is also do-able for someone who doesn't have a high level of electronics knowledge.
It would obviously take some investigation by someone, and a critical mass to make it viable, but I suspect that this may be an opportunity for people who are interested in this project but don't have the time or requisite skills to get one of these devices for themselves. I'm sure JH would be quite happy to make the boards available.
Personally, I enjoy the PCB assembly process, almost like doing a technical Jigsaw, so I won't be following this route myself, but it potentially opens the door to a wider audience for when JH gets this interesting device working.
Regards
Magman |
TekniK
Posted: Wed Jul 21, 2010 9:05 pm Post subject:
| magman wrote: |
It might be possible for someone to organise a group-buy, where the thru-hole PCB's JH is developing are professionally stuffed and soldered using machinery. Regards
Magman |
+1 |
robotmakers
Posted: Thu Jul 22, 2010 8:20 am Post subject:
Just thought I'd mention that I brought the recent discussion in this thread to the attention of two of the major US modular synth makers. Unfortunately, neither are currently interested in pursuing partial or complete manufacture of the vokoder board.
Anyone in Europe interested in contacting someone like http://www.diatron.co.uk/ and running the BOM and board info by them? At the very least, it would be interesting to see how much money one saves by doing all the soldering work by hand.
Roger |
Funky40
G2 patch files: 5
Posted: Thu Jul 22, 2010 8:54 am Post subject:
Jürgen,
when do you think are you ready to sell the boards ?
must plan my finances.....
( i'm not in hurry, springtime would be cool ) |
jhaible
Posted: Thu Jul 22, 2010 9:02 am Post subject:
| Funky40 wrote: | Jürgen,
As soon as possible.
Right now, I'm going over the layout again, without having built a prototype yet, because there are manufacturing issues.
(Without going into detail, I can say I will never, ever, use polygon pads again.)
I hope to build my prototype this summer - if all goes as expected, I could have boards in fall. If not, well then ...
Funky40
G2 patch files: 5
Posted: Sat Jul 24, 2010 4:22 am Post subject:
thanks, it's as hoped
( i mixed up sring with fall in my post. Fall is good ...... winter is perfect ) |
/mr
Posted: Sat Jul 24, 2010 9:13 am Post subject:
I suddenly checked out the channel schematics a bit more than before, and realize that the (optional) crosspatching between analyzer channels and syntesizer channels is done before the envelope detectors - i.e., with the bandpass-filtered audio signals, not with the envelope-followed analyzed CV versions of them. Am I understanding this correctly?
(There are envelope outputs as well, after the envelope detectors, but the CV inputs of the bands are before them, so they can't be used for crosspatching.)
To me it feels like a strange design choice... do other vocoders employ it?
I was expecting CV patching and see no obvious benefits with audio patching, rather the opposite. I was planning to pick out the handy low-frequent CVs and feed in externally treated versions of them (shifted bands etc, without a need for a physical matrix), but when the signals are in the audio range it will not be done so easily. |
jhaible
Posted: Sat Jul 24, 2010 11:26 am Post subject:
It's another EMS trick. Surprising at first, it avoids a lot of trouble with offset voltages. The way it is, you only have one CV offset adjustment per channel. (Still, these are 20 Pots that must be carefully adjusted, or you're ruining the Vocoders dynamic range completely.)
If you'd do the crosspatching adter th eenvelope detectors (on DC rather than AC), you'd need two offset trimmers per channel, one for the DC path before the patchpoint, and a second for the DC path after the patch point.
/mr
Posted: Sat Jul 24, 2010 2:59 pm Post subject:
Oh my, those British chaps again. Yes, I expect the "making of proper CV level" after the analyzer filter would need a trimpot to adjust for amplitude errors in the analyzer filter, and then the VCA in the syntesizer filter would need another trimpot to adjust for amplitude errors there. With your design these two amplitude error corrections combine into one.
Or... do they really? In a hardwired vocoder, yes - but if the channels are patched differently, don't you need both trimmers anyway?
Anyway - with AC patching instead of DC patching we can forget all the free CV connectivity with the outer world a la Doepfer Vocoder. Almost no use putting telejacks at the 20+20 patchpoints (unless you want something quite weird and know how to use them), and perhaps it's not much to cry for. The more introvert and internal solution of a pin matrix would still make sense though... if the channels allow it well enough.
Do they?
The single trimmer solution mentioned above is the first thing that makes me wonder, and the other thing is the time constants of the envelope followers (EF). With AC crosspatching (before the EF) between different channels, the signal gets EF'ed by "the wrong channel", and higher channels have shorter EF time constants in order to allow for the more rapidly changing envelopes of those channel analyzers. For example, if I read the schematics correctly, with channel 2 patched to channel 19, we have a bandpass signal around 250 Hz from channel 2 analyzer, which goes to the 19th channel EF with its time constant R*C = 0.0002 s which translates to a lowpass cutoff frequency of roughly 800 Hz. This frequency works well for the 6.3 kHz frequencies of channel 19, but is way too high for the 250 Hz channel 2 signal, letting it all through instead of following its envelope!
I hope I haven't confused it all into something completely gibberish...
Having shorter time constants in higher-channel EF's is at least something expected, since the higher-channel envelopes can vary more rapidly, and it should be used to avoid a slow vocoder response for higher channels. But for proper performance I expect each channel EF to always take care of its own analyzer signal, otherwise we end up with the problem just described. To do this, the patching should be after the EF's, with the DC signals and not the AC ones... I'm afraid. (Hoping I'm all wrong.)  |
