DIY Buchla 200e style Frac-Rack cabinet
Page 2 of 2 [30 Posts]
Goto page: Previous 1, 2
ericcoleridge
PostPosted: Wed Jul 09, 2008 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Luka wrote:
hey eric, where did you get your buchla-esqe knobs?
I got them nos surplus; However, Allied has the same ones, but only in black and for 1/8" shaft. They are all .5 diam.
I'm planning on buying the bigger, frequency-type knobs from Allied, which they have for 1/4" shaft. They're kinda steep at about $3.50 US each, but I won't need many.
macumbista
PostPosted: Sat Aug 29, 2009 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Photos posted of my cabinet build in the other 200e cabinet clone thread:
http://electro-music.com/forum/post-260773.html
Enjoy!
macumbista.net
jonkull
PostPosted: Sun Jan 10, 2010 9:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Since this is designed for Frac is there any reason it wouldn't work for euro if the proper rails are used? The dimensions should be the same (they are both 3U formats), correct?
http://recoilsun.bandcamp.com/
macumbista
PostPosted: Mon Jan 11, 2010 2:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought Frac were taller (like 4U), and most Euro modules are far too deep for any kind of folding case. You really need modules with PCBs parallel to the faceplate (like the Cwejman ones) to make a folding case worthwhile. Unless you want a very un-portable folding case, of course...
macumbista.net
jonkull
PostPosted: Mon Jan 11, 2010 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Most euro modules made in the last year or so are fairly shallow with PCBs parallel to the panel. Frac and euro are both 3U. The difference between them is that euro has the mounting holes close to the edge of the panel and frac has them inset so they use a different kind of rack rail.
