Silas
Posted: Tue Sep 23, 2008 2:50 pm Post subject:
Filter Help Subject description: What filter i need ? |
Hey, I need to put a filter on a mixer so I have the mid and high on one output and the bass in its own.. Am i looking for a Passband filter or am I way off ?
To clearify, I need the filter to split the mid and high range from the bass..
Help me out please, THANKS.. |
bubblechamber
Posted: Tue Sep 23, 2008 5:59 pm Post subject:
it seems like you could do this with a high pass, for the mids and highs. and a low pass for the bass.this would give you 2 output.
3 band passes would work too, and that might give you more control in the long run. but would require 3 outputs.
david _________________ You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same. |
urbanscallywag
Posted: Tue Sep 23, 2008 8:08 pm Post subject:
A state-variable filter would be cool since it has simultaneous low pass and high pass outputs (with a single cutoff frequency). |
Silas
Posted: Wed Sep 24, 2008 7:25 am Post subject:
Hmm, both suggestions sounds just fine... Problem is I've spent the last hour looking at filters and I don't understand much.. Certanly none of the calculations.. whoa.. Really I guess i just wan't to be spoon fed, can you link me to somewhere theres schematics that also tells me what the values of the components ?
Looking at the state-variable filter, I'm guessing it's no problem having the mid and high on one output and the low on it's own?
Also, I have no internet at my place so I have to commute 30 min, to get to some internet, so I would really apriciate if you could help me out in one go..
THANK YOU VERY MUCH! |
Scott Stites
Audio files: 96
Dave Kendall
Posted: Wed Sep 24, 2008 10:51 am Post subject:
Just a thought - is it for a DJ-type use, or for a P.A. crossover use?
If it's for DJ use, you might want to look at a type of filter, or pair of filters (lowpass and highpass), that can have the frequency swept via a pot or control voltage.
To filter out all but the "real" bass, you will often need a relatively low cutoff frequency, around 100Hz or lower, and need to tweak the cutoff frequency according to the track you're playing through it. The same holds for the mid-high frequencies.
The steepness of roll-off (sharpness at the cutoff point) is probably an issue too. For example, a 6dB/octave filter will sound very different to a 24 dB filter in this application....
In the end, just use your ears to decide what filter type to go for - if it sounds good, it *is* good.
just my .02 pence worth....
Dave |
