today> Cancelled - Sorry Chez Mosc
Pitch stick problem ?!
Page 1 of 1 [8 Posts]
onosendai
G2 patch files: 4
PostPosted: Tue Aug 25, 2009 12:59 pm    Post subject: Pitch stick problem ?! Reply with quote  Mark this post and the followings unread
When i use the pitch stick, the sound bend but don't come back when i stop using it. I suspect the pitch to lose calibration. It's annoying ! I can't use this fabulous stick anymore !
Have you seen this before ? Does a solution exist ?
Audio files: 299
PostPosted: Tue Aug 25, 2009 1:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Others have reported this problem as well, the solution is to replace the pitch stick. It might be possible to order one through the shop where you bought the synth and do the replacement yourself - I believe others did so.
onosendai
G2 patch files: 4
PostPosted: Tue Aug 25, 2009 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Replace it fix the problem ? It is hard to do ?
fairplay
PostPosted: Thu Aug 27, 2009 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
...might this be the same problem when the pitch-stick just doesnt do anything anymore (as well as the Mod-wheel)? - probably not, but if yes i'd be grateful for a hint...
TIA.
Audio files: 299
PostPosted: Thu Aug 27, 2009 2:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some links :
http://electro-music.com/forum/viewtopic.php?highlight=pitch+stick&t=16180
http://electro-music.com/forum/viewtopic.php?highlight=pitch+stick&t=24114
http://electro-music.com/forum/viewtopic.php?highlight=pitch+stick&t=15419
hope that helps to make an estimation of the difficulty :-)
Audio files: 299
PostPosted: Thu Aug 27, 2009 2:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
TIA.
That would sound more like a loose cable ... maybe open the synth to see if you can find any, maybe pull some connectors and push them back on ...
crueltwist
PostPosted: Wed Oct 07, 2009 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
the stick is very easy to replace if you can do basic soldering, but they aren't cheap - between about 70 and 100 euro including post if my memory serves correctly - the stick is really the most amazing pitch stick I've ever come across - the floyd rose of pitch sticks - but the design is a bit on the crap side - it's a pressure sensitive resistor (which is essentially a piece of tape with a circuit inside) stuck onto a piece of flexible metal - basically the resistor comes partially unstuck and doesn't track properly if the stick has been over-wanked - the worst thing is that when it goes wrong, the pitch of the synth can start wildly and randomly fluctuating, even when not using the stick at all - so once it starts going wrong it needs replacing - fortunately all the pitch sticks nord use are the same (aside from the length of the wires - the g2 uses shorter ones than the lead) so for now we don't need to worry about stocking up on replacements before they're all gone -
fairplay
PostPosted: Wed Oct 07, 2009 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
...turned out the motherboard was damaged and had to be replaced...
...luckily my G2 is still under warranty...
