Adventures in Sound
Page 14 of 49 [1223 Posts]
Goto page: Previous 1, 2, 3, ..., 12, 13, 14, 15, 16, ..., 47, 48, 49 Next
PostPosted: Wed Oct 27, 2010 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry to hear, Rob.
Audio files: 495
PostPosted: Thu Oct 28, 2010 3:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the kind words all. Smile
I will be back next time as normal.
Audio files: 278
PostPosted: Wed Nov 03, 2010 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
oh no, it appears I'm not doing the 'odd' episodes anymore Shocked
Audio files: 278
PostPosted: Wed Nov 03, 2010 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
tonight I celebrate the power of moog, with a set using only my new micromoog for sounds, with looping from my electrix repeater and delays of doom from my dynachord ec 280 and boss dd-20
Audio files: 278
PostPosted: Wed Nov 03, 2010 7:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
signal path: micromoog -> repeater -> ec 280 -> dd-20
for some reason I thought this was Episode 56, but it wasn't Wink
Adventures In Sound_058_031110.wav.mp3
Adventures In Sound - Episode 58 - The Power of Moog
 Filename:  Adventures In Sound_058_031110.wav.mp3
 Filesize:  55.06 MB
 Downloaded:  2546 Time(s)
Audio files: 495
PostPosted: Sat Nov 13, 2010 1:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
After some deliberation I have decided to not continue uploading every show but instead use the recordings for further editing and processing and make new tracks out of them. I believe this will make them much more listenable, or at least a little more interesting ... hopefully. Smile
I will continue to do live shows as before though, and also concentrate on new ways to improvise with sound adventures. The journey has only just about begun. Wink
Audio files: 278
PostPosted: Sat Nov 13, 2010 5:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
interesting decision Rob, but I think you could do both, use this thread to post shows for anyone who might have missed an episode, and then edit some for later release elsewhere Smile
Audio files: 297
PostPosted: Sat Nov 13, 2010 7:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I hope you'll keep posting "unedited" recordings here Rob, but no pushing here, just a would like. I'd look forward to edited ones as well Laughing
Audio files: 495
PostPosted: Sun Nov 14, 2010 9:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure, I can post some shows on here, unedited and all, but I think I will hold some back as well. It is not often that things goes to plan however, so we'll see. Razz
Audio files: 278
PostPosted: Wed Nov 17, 2010 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
tonight's set will be performed on my yamaha sk-20 symphonic ensemble with some weird noise from my trax rota-synth rs-1
Audio files: 278
PostPosted: Fri Nov 19, 2010 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
This episode is a bit schizophrenic, it starts by exploring the sounds of the yamaha sk-20 symphonic ensemble (organ/strings/polysynth) for some spacey drones in a mostly major key then goes a bit weird with the trax rota-synth rs-1, an analog sequencer/ synth that's good for less tonal stuff
sk-20 + trax rota-synth rs-1 -> resonator -> repeater -> dd-20
Adventures_In_Sound_060_171110.mp3
Adventures In Sound - Episode 60 - String Machine Theory
 Filename:  Adventures_In_Sound_060_171110.mp3
 Filesize:  54.25 MB
 Downloaded:  2525 Time(s)
Audio files: 297
PostPosted: Fri Nov 19, 2010 7:16 am    Post subject: Reply with quote  Mark this post and the followings unread
modulator_esp wrote:
schizophrenic
Don't know about that, but I like it very much.
Audio files: 278
PostPosted: Fri Nov 19, 2010 7:39 am    Post subject: Reply with quote  Mark this post and the followings unread
schizophrenic
ok, glad you like it anyway Smile
Audio files: 495
PostPosted: Thu Nov 25, 2010 7:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Episode 61 "The Last Person on Earth"
An exercise in desolation, using only Micron and MPC. The MPC actually locked up towards the end but kept on playing, which worked out ok.
AIS_episode_61_LPOE.mp3
Adventures in Sound - Episode 61 "The Last Person on Earth"
 Filename:  AIS_episode_61_LPOE.mp3
 Filesize:  65.75 MB
 Downloaded:  2005 Time(s)
Audio files: 278
PostPosted: Thu Nov 25, 2010 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
nice episode Rob Smile
Audio files: 278
PostPosted: Wed Dec 01, 2010 5:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Tonight's episode will be an experiment with asynchronous feedback looping Smile
Audio files: 278
PostPosted: Thu Dec 02, 2010 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Episode 62 looked doomed to failure as there were some serious technical difficulties just as I was due to start, but after a slowish start I got into it and had fun making possibly my weirdest show yet.
I used a Yamaha CS-01, Yamaha VSS-30 and voice as sound sources through a Korg Monotron, with sounds sampled into the VSS-30 from my ipod, this then went into a Korg PX3 for delay and phaser effects then into a pair of Boss DD-20 delays which were connected to each other in a feedback loop, running at slightly different times.
This lead to all sorts of droning and strange throbbing rhythmic effects Smile
Adventures In Sound_062_011210.mp3
Adventures In Sound - Episode 62 - Asynchronous Feedback Loop Experiment
 Filename:  Adventures In Sound_062_011210.mp3
 Filesize:  52.14 MB
 Downloaded:  2405 Time(s)
Audio files: 495
PostPosted: Sat Dec 11, 2010 7:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is an extended version of the last set - I was playing some time before going on air and recorded the full set. Enjoy. Smile
episode-six-threeAIS_on_the_sun.mp3
adventures in sound episode 63 "on the sun"
 Filename:  episode-six-threeAIS_on_the_sun.mp3
 Filesize:  87.57 MB
 Downloaded:  1972 Time(s)
shanemorris
Audio files: 92
PostPosted: Sat Dec 11, 2010 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
great set thanks rob!
ElectroCasa
Audio files: 278
PostPosted: Fri Dec 17, 2010 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
For this episode I decided to try something a bit more melodic and rhythmic as my last few sets had all been more abstract noise/drone.
I used all digital sounds from a nord modular, korg ds8 and waldorf blofeld for sounds, and for the first time ever the repeater was synced to the nord by midi, so I could add stuff in time with the rhythmic stuff
The ds8 went through a frostwave resonator into the repeater for loops, the nord modular was used primarily for sequences and playing the blofeld, which supplied drones, flutes, choirs and the arpeggiated stuff
Adventures_In_Sound_064_151210.mp3
Adventures In Sound - Episode 64 - Digital Jam
 Filename:  Adventures_In_Sound_064_151210.mp3
 Filesize:  55.93 MB
 Downloaded:  2466 Time(s)
shanemorris
Audio files: 92
PostPosted: Fri Dec 17, 2010 2:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Listened to your set AFK... really loved it Jez. Thanks for sharing it. Very Happy
ElectroCasa
Audio files: 278
PostPosted: Fri Dec 17, 2010 6:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool cheers shane
Audio files: 278
PostPosted: Mon Dec 20, 2010 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I listened back to it today and I liked it too, which is nice
Might even think about giving it a bit of polish and releasing it Smile
Audio files: 495
PostPosted: Thu Dec 23, 2010 5:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Episode 65, "Ethereality".
AIS-episode 65_ethereality.MP3
AIS episode 65, "Ethereality" An exploration of large spaces.
 Filename:  AIS-episode 65_ethereality.MP3
 Filesize:  83.88 MB
 Downloaded:  1917 Time(s)
Audio files: 278
PostPosted: Wed Dec 29, 2010 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
tonight's set will feature the Oberheim Matrix 12 Smile
