surgesg
Joined: Jun 05, 2010 Posts: 19 Location: San Diego, CA
oootini
Posted: Mon Aug 30, 2010 7:51 am Post subject:
| sounds very interesting! |
oootini
Posted: Mon Aug 30, 2010 7:52 am Post subject:
| is this mac only? |
surgesg
Posted: Mon Aug 30, 2010 8:09 am Post subject:
Thanks for checking it out.
Although I'm developing on a Mac, I've chosen Processing as the language for the host app specifically because it's so cross-platform. I have to do some testing, but it should work on Windows and Linux as well. |
oootini
Posted: Mon Aug 30, 2010 8:40 am Post subject:
| you should post on the muff wigglers forum. you'll get a lot of interest there... |
surgesg
Posted: Mon Aug 30, 2010 8:44 am Post subject:
| will do, thanks. |
BobTheDog
Posted: Mon Aug 30, 2010 8:47 am Post subject:
Looks great!
If you do a pcb run then put me down for one.
Andy |
surgesg
Posted: Wed Sep 01, 2010 7:57 am Post subject:
To update, I just placed an order for a small run of PCBs. A limited number of kits will be available as well.
- Greg |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Wed Sep 01, 2010 7:58 pm Post subject:
| What would your prices be? |
surgesg
Posted: Thu Sep 02, 2010 9:37 am Post subject:
| Thinking $16 and shipping for the PCB, not sure about kits yet. |
TekniK
Posted: Thu Sep 02, 2010 9:54 am Post subject:
| Hi,am interested in a 'kit',but how do you program this thing etc? |
surgesg
Posted: Thu Sep 02, 2010 10:27 am Post subject:
Teknik,
Well, I'm considering provided pre-programmed chips if desired, but you can also program your own using the Arduino environment.
I'll be posting the source code soon, but I'm just wrapping things up to make sure it works cross-platform.
I did a little tutorial here: http://gregsurges.com/programming/osc-processing-microcontroller-connect-maxmsp-dac-ic/
If this seems too complex, don't let it scare you. I've done all of the hard serial coding, and all the user really needs to do is generate OSC data from whatever method they like. This tutorial is really just to show what goes on behind the scenes, and to document my process.
Does that help?
- Greg |
TekniK
Posted: Fri Sep 03, 2010 4:47 am Post subject:
Hi Greg,thanks for reply.
i don't think its something for me.
am just after a cv/gate interface i can built into module form wich match my module format and can directly communicate via midi trough usb.
very handy just hooking a laptop to my modular via usb
Cheers |
surgesg
Posted: Sat Sep 04, 2010 8:36 am Post subject:
Cool project! I would be interested in buying a kit or PCB as well.
surgesg
Posted: Thu Sep 09, 2010 9:50 am Post subject:
Hi everyone,
I'm excited to announce that the first run of PCBs for the USB-Octomod has arrived! There are 20, and it seems like they will go fast.
You can check out the project page here: http://www.gregsurges.com/circuitry/usb-octomod/
There is also a link to order the PCB on that page.
Boards will be $16 + shipping, and I'm set up for Paypal and Google Checkout.
I've also posted the source for both the Teensy microcontroller and the Processing Host app on that page.
Thanks for your interest in the project!
- Greg |
surgesg
Posted: Tue Sep 14, 2010 7:49 pm Post subject:
Well, they did go fast, only a few left. I've got mine working with an Arduino instead of Teensy too. Seems to work equally well, actually.
Posted some code for that here: http://www.gregsurges.com/circuitry/usb-octomod. |
max92
Posted: Wed Sep 15, 2010 4:22 pm Post subject:
| I could be interested! do I need to program any IC myself? cause i've never done anything like that. only soldering and setting analog modules up... |
surgesg
Posted: Wed Sep 15, 2010 4:41 pm Post subject:
| I will soon have kits or pre-populated boards, no programming necessary. |
max92
Posted: Thu Sep 16, 2010 12:31 am Post subject:
| surgesg wrote: | | I will soon have kits or pre-populated boards, no programming necessary. |
Great! |
surgesg
max92
Posted: Wed Sep 22, 2010 3:08 pm Post subject:
I'd very much like a kit  |
max92
Posted: Wed Sep 22, 2010 3:49 pm Post subject:
| Hm... Can I controll it thru anything else than Max/MSP? i am only using Live without Max for Live. Can I still send OSC? |
surgesg
Posted: Wed Sep 22, 2010 4:02 pm Post subject:
You can use any software that transmits OSC. Lots of open-source stuff out there, PD, ChucK, etc.
The osc interface is /dac chan1 chan2 chan3 chan4 chan5 chan6 chan7 chan8 |
surgesg
Posted: Mon Oct 04, 2010 3:52 pm Post subject:
Hello everyone,
I've finally got some full sets of components available. I've got five sets, which can be shipped either as pre-assembled, tested boards, or as component kits w/ a pre-programmed Teensy 2.0.
You can check them out at http://www.gregsurges.com/circuitry/store/
Enjoy!
- Greg |
