2011 Build Pictures
Page 5 of 19 [453 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, ..., 17, 18, 19 Next
jordroid
PostPosted: Wed Mar 09, 2011 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Boogdish wrote:
It's two chips, a 16F913 PIC and a quad op amp being used as an output buffer and voltage summer/limiter of the time CV. I'm sure it could be done using standard CMOS chips, but for me, it's easier to figure it out with a PIC.
I'm thinking about starting over with it and have the PIC read the values of the pots then output with the PWM or a standalone DAC. That way the PIC could do the filtering of between step voltages and have smoother transitions. I think I'd also have try having separate time controls for A/S/R.
Thanks for the explanation. You could easily do most of that stuff with a 4017, but some of the cooler functions, like being able to pingpong back and forth between two points defined by switches would be trickier and probably not doable with only two chips, so it seems like a great use of a microcontroller. It would make a pretty cool "standard" sequencer as well, it has some features that seem useful which are uncommon to see in the 10 and 16 step analog sequencer designs i am used to. I want one!
JCM
PostPosted: Wed Mar 09, 2011 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Any plans for a PCB of the Envelope Sequencer? I would definitely get at least one of those!
PostPosted: Wed Mar 09, 2011 12:00 pm    Post subject: Purle Star 555
Subject description: Dr Steve's 555 Circuit modded by PHOBoS
I finally got the last parts to finish this thing, the knobs!
It's a noise/sound generator with 2 NE555 chips, original design by
Dr. Steve with some modifications by me. Cool
more info and audio here
more photos here
 Filesize:  46.81 KB
 Viewed:  460 Time(s)
 Filesize:  31.61 KB
 Viewed:  453 Time(s)
PostPosted: Wed Mar 09, 2011 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
actually that might not be that hard. I just happened to come across this video today.
Using 2 4017 chips to create a bounce effect (one chip for each direction)
so that might be a start. Though microcontrollers are of course an 'easier'
way and more versatile.
I really like that envelope generator btw, and the LEDs in the slidepots look
great! Very Happy
tjookum
Audio files: 26
PostPosted: Thu Mar 10, 2011 12:35 am    Post subject: Reply with quote  Mark this post and the followings unread
nice one phobos, another one for the moonbase Smile
And Boogdish, really like your work. That looks like a great functional piece of kit.
Hunter S. Thompson
movies
noise
sduck
PostPosted: Thu Mar 10, 2011 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just finished this one:
Toppobrillo Triple Wavefolder front
Toppobrillo Triple Wavefolder profile
Toppobrillo Triple Wavefolder back
toppobrillo
PostPosted: Thu Mar 10, 2011 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
sweet!![/list]
jordroid
PostPosted: Sat Mar 12, 2011 7:10 am    Post subject: Reply with quote  Mark this post and the followings unread
great! Very Happy
Ah, but the trick of pingponging back and forth between any two steps as selected by switches is still going to be tricky, i don't know a way to make a 4017 reset to anything but output 0? Nice 555 machine btw!
kupfer_m
PostPosted: Wed Mar 16, 2011 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
A few pics of my modular project:
MFOS dual AR:
Rgrds,
Jim
TekniK
PostPosted: Wed Mar 16, 2011 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
your modulles looks very nice
jordroid
PostPosted: Thu Mar 17, 2011 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Not quite "finished" finished, but i reached a milestone on a pre-patched synth i am working on, panel wiring is finished as of last night! All that is left is to chase any remaining gremlins out (shouldn't be too bad, most everything is tested and calibrated), make a proper panel and box it up.
Contains one Ian Fritz saw core VCO as described in an EM thread, with standard tri, sine and pulse shapers, plus a Fritz 5 pulser and two Scott Stites "wave things". Your basic three octave 11 waveform VCO Smile
One Ian Fritz Teezer through zero VCO, holey moley is that thing amazing.
Four Thomas Henry VCAs.
One Ian Fritz Threeler multi mode VCF.
One transformer/diode ring modulator, Ken Stone style.
Four simple LFOs, one Tom Wiltshire/Electric Druid tap LFO.
Three Tom Wiltshire ADSRs.
Two 4017 sequencers, one 4013 divide by 2 and one 4017 divide by 1-8. Sequencers can be mixed together with one running off a divided clock (divided by 1-16) or run independently.
The sequencer clock is a falling ramp/comparator set up with VC gate width, thanks for the great idea Fonik!
Two Boogdish pic quantizers.
Two simple glide circuits, portamento can be applied before or after quantization.
A single buss 1v/oct keyboard controller.
Circuits are from Ian Fritz, Thomas Henry, Scott Stites, Ken Stone, Tom Wiltshire, Ray Wilson, Michael Barton and Bernie Hutchins/electronotes contributers, thanks guys, i promise to have way too much fun Smile
 Filesize:  1.37 MB
 Viewed:  299 Time(s)
 Filesize:  940.96 KB
 Viewed:  298 Time(s)
tommi
PostPosted: Thu Mar 17, 2011 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, I completed this morning the troubleshooting of my Toppobrillo Dual 281 FG module. The problem was caused by mounting the lm7810 backwards. I think it caused the failure of 1 cd4001 (the one for section A, section B worked from the very beginning). I like troubleshooting! Especially when it makes something work! Very Happy
 Filesize:  1.45 MB
 Viewed:  320 Time(s)
 Filesize:  1.47 MB
 Viewed:  323 Time(s)
http://soundcloud.com/mister-vommi
http://tideofsound.net
dougseidel
PostPosted: Thu Mar 17, 2011 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
jordroid
I love that! Also it's nice to see something from ithaca (where i grew up).
mph
PostPosted: Fri Mar 18, 2011 6:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
I have recently finished my first modular synth. It is only Yusynth modules + one ACX Midi 2 CV interface, one Formant Intrument Interface and a Deepsea active multiple (those ones are on the upper and lower left side).
PSU is a CGS66 heavily modded and built on perfboard.
Thanks a lot to Yves Usson and all the people who helped me to finish this build.
Thanks also to AndrewF for helping me finding those big colored knobs Wink
Cheers!
PostPosted: Fri Mar 18, 2011 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Congratulations. Nice looking synthesizer with a nice set of modules. Enjoy!
Luka
PostPosted: Fri Mar 18, 2011 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice work!
that is going to be a crazy synth
problemchild
melbourne australia
PostPosted: Fri Mar 18, 2011 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks like you will definitely have a lot of fun!
To Sduck and kupfer_m, beautiful panels. Most elegant.
kupfer_m
PostPosted: Sat Mar 19, 2011 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I'm very pleased with the result too!
PostPosted: Sat Mar 19, 2011 10:45 am    Post subject: mini Spingboard
Subject description: Spring Equinox build
Here's a mini springboard I made last night for todays Spring Equinox,
it has been used in the midichat Smile
mini springboard made for Spring Equinox 2011
 Filesize:  297.77 KB
 Viewed:  272 Time(s)
Appliancide*
PostPosted: Sat Mar 19, 2011 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Eurorack synth made with Ikea Rast.
http://appliancide/blogspot.com
Audio files: 297
PostPosted: Sun Mar 20, 2011 10:57 am    Post subject: Re: mini Spingboard
it has been used in the midichat :)
Loved it!
And here is a recording of the chatroom movements.
davemoog
PostPosted: Sun Mar 20, 2011 5:04 pm    Post subject: Re: mini Spingboard
nice!!
seaweedfactory
PostPosted: Wed Mar 23, 2011 4:39 pm    Post subject: . Reply with quote  Mark this post and the followings unread
Last edited by seaweedfactory on Sun Jul 06, 2014 7:27 pm; edited 2 times in total
PostPosted: Thu Mar 31, 2011 9:30 pm    Post subject: A redesign and new functions for a double-width module Reply with quote  Mark this post and the followings unread
While I liked my Modulo Magic module, I was never satisfied with my initial panel layout -- it was overly cluttered with inputs and controls that proved to be redundant.
Through experimentation I discovered that to add a VCA input section and a bias shifter increases the Modulo Magic's capabilities.
The VCA accepts both a/c and d/c inputs and can be used stand-alone. It sends it's output to a self-designed bias shifter circuit that I defaulted to a +5v bias -- the bias level can be shifted by an external voltage.
The modulo magic accepts that shifted signal as well as an auxiliary signal. I renamed the functions to: Threshold, Range, and Step Size -- these all can be voltage controlled.
I originally built Modulo Magic as a control voltage processor however I really like it as an audio signal processor. Thus, I optimized the front panel control ranges and the functions for audio (though it works fine as a control voltage processor, too).
This redesign required 1 1/2 module spaces so I added a Yusynth Dual Gated Slew which takes up the other 1/2 module space.
The redesigned and expanded panel.
 Filesize:  915.63 KB
 Viewed:  267 Time(s)
View of the PCBs. The three PCBs are the CGS Modulo Magic, a board that contains the Yusynth VCA and my own bias shifter, and the Yusynth Dual Gated Slew PCB.
 Filesize:  1.16 MB
 Viewed:  276 Time(s)
egasimus
PostPosted: Thu Mar 31, 2011 10:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Your builds make me sad, people. I don't think I'll ever have the time and resources to build something like this, even if I had the skills and knowledge.
Any chance of a schematic for the Polyrhythm generator? That's something relatively simple and definitely usable.
mph, any info on that "Formant Instrument Interface"? Google gives nothing.
