I s this feature whorthwhile to have |
Yes |
45% |
[ 5 ] |
No |
27% |
[ 3 ] |
Maybe |
27% |
[ 3 ] |
Total Votes : 11 |
cebec
G2 patch files: 31
Posted: Wed Dec 29, 2004 9:52 am Post subject:
disconnect all cables at once |
is there a way to disconnect all the cables in a patch at one time? not just the unused ones... or a way to select a group of modules and just disconnect those? if not, there ought to be a way...
that's my wish... or my ignorance... depending ... |
Joined: Jan 31, 2003 Posts: 18240 Location: Durham, NC
Audio files: 224
Posted: Wed Dec 29, 2004 11:31 am Post subject:
There may be a better way, but put all the modules down that you want in your patch and then set this cordless patch to the init variation. Then, when you are working on a variation, just load the init variation and you'll have it. _________________ --Howard
my music and other stuff Last edited by mosc on Wed Dec 29, 2004 11:47 am; edited 1 time in total |
cebec
G2 patch files: 31
Posted: Wed Dec 29, 2004 11:38 am Post subject:
ah, obviously I didn't think of that... good idea, thanks. |
Joined: Apr 03, 2004 Posts: 24422 Location: The Netherlands, Enschede
Audio files: 297
Posted: Wed Dec 29, 2004 12:56 pm Post subject:
There is a way to disconnect a set of selected modules from it's suroundings - if that's what you want to do.
Just cut them out and then paste them back.
Jan. |
Afro88
Audio files: 12
G2 patch files: 79
Posted: Wed Dec 29, 2004 4:26 pm Post subject:
mosc wrote: | There may be a better way, but put all the modules down that you want in your patch and then set this cordless patch to the init variation. Then, when you are working on a variation, just load the init variation and you'll have it. |
I'm not sure if this is what you meant, but you can't have different wirings for the same patch in different variations due to recalculation issues. Variations only work on parameters, and only parameters that don't force a recalculation/optimisation. If you set an unwired patch the the var init, wire up a few modules and then press init, you'll find the cables stay the same unfortunately. |
cebec
G2 patch files: 31
Posted: Wed Dec 29, 2004 7:05 pm Post subject:
oh! ok, i hadn't gotten around to trying it, yet, but it sounded like it would work.
so: a feature that disconnects all cables in a patch at one time, or even in a group of selected modules, without having to cut and paste them. |
Audio files: 297
Posted: Wed Dec 29, 2004 8:09 pm Post subject:
I added a poll to this thread, curious as I am ...
When you consider this poll to be inappropriate, misleading, incomplete, wrong or moraly objective in any whatsoever way please tell !, it can be removed or edited again (I hope :-)
jan. |
cebec
G2 patch files: 31
Posted: Wed Mar 23, 2005 9:02 am Post subject:
so, yeah. i'd like the option to delete ALL cables at once or in a given selection of modules. |
Audio files: 224
Posted: Wed Mar 23, 2005 9:42 am Post subject:
Afrokid wrote: | If you set an unwired patch the the var init, wire up a few modules and then press init, you'll find the cables stay the same unfortunately. |
Opps, you are right. I should have tried it before suggesting it.  _________________ --Howard
my music and other stuff |
Posted: Wed Mar 23, 2005 11:25 am Post subject:
I propose we go back to her and tell her that we didn´t apreceate her at the time. We´ll say "please OS2.1, please take us back, we never realised how good you were to us", then we´ll admit we only upgraded because we thought two vocoders in the same patch would be kinda neat but in the end never realy did use that.
Then we´ll kiss her calculator and all will be well again.
(the G1 used to have this, and building blocks, and a calculator, version 3.0 snipped a couple of percentages of cost of the vocoder which used to cost 55% or so and also axed the building blocks and the calculator. "remove all cables" might still be there, never used it) _________________ Kassen |
jamos
Joined: Jun 01, 2004 Posts: 514 Location: Eugene, Oregon, USA
G2 patch files: 41
Posted: Wed Mar 23, 2005 11:31 am Post subject:
I'll admit, I'm puzzled: how would this feature be useful? |
cebec
G2 patch files: 31
Posted: Wed Mar 23, 2005 12:02 pm Post subject:
it'd be a time saver and not difficult to implement, i don't think.
for example, let's say i've got my voice area populated with modules and things are cabled up but I don't like the patching direction i've gone... now, i could have saved an un-cabled version of my patch but I'd much rather select all or just click an option to uncable everything rather than go through each module one by one, double-click dragging or right click disconnecting. takes a lot of time and is hard on the ol' wrist.
in another situation i might want to delete the cables from a specific section of modules. why go through each one when i can just drag a box around the modules and right click/disconnect all or something like that? |
Posted: Wed Mar 23, 2005 1:03 pm Post subject:
That idea would more usefull on the G1 where drawing cables did not force a recompile, I suppose. I intensely longed for this feature many times, but all of those times were on analogues. Even a feature that hangs the cables back on the cable rack would be nice.
:¬) _________________ Kassen |
cappy2112
Joined: Dec 24, 2004 Posts: 2494 Location: San Jose, California
Posted: Tue May 03, 2005 2:09 pm Post subject:
jamos wrote: | I'll admit, I'm puzzled: how would this feature be useful? |
Starting from scratch- a handfull of modules, but no wires.
Even 10 modules take some time to drag & position. Myself, I have tendonitis from using the mouse over the years, so any shortcuts are helpfull. |
