today> Twyndyllyngs Chez Mosc
Steiner Filter - Simultaneous Outs
Page 1 of 1 [3 Posts]
logicgate
PostPosted: Fri Sep 19, 2014 4:48 pm    Post subject: Steiner Filter - Simultaneous Outs Reply with quote  Mark this post and the followings unread
I wanted to build a version of this filter but with LP/BP/HP simultaneous outputs.
I reckon I only need to triplicate the core?
Are the numbers in red (image attached) correctly corresponding to the 3P4T switch lugs???
 Filesize:  92.69 KB
 Viewed:  287 Time(s)
wackelpeter
Audio files: 10
PostPosted: Thu Sep 25, 2014 7:29 am    Post subject: Reply with quote  Mark this post and the followings unread
maybe you want to Combine Yves' design with one of Ken Stone's version of the Steiner Filter...
Ken Stone built it with 3 different input stages hp,lp,bp and an input where the signal is spread to all 3 filter sections... then you can mix the signals into each filter section and select how much of the signal is applied to each section and at the Output you have a mix of all the Signal fed into the filter...
you can also feed different signals into the filter at once...
is it that what you're looking for?
yusynth
PostPosted: Thu Sep 25, 2014 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
A Steiner VCF which is based on a Sallen and Key architecture in which you can only have separate LP,HP,BP inputs for a single output.
If you are looking for a filter with a single input point and three distinct outputs which are LP, BP and HP respectively then you must pick a completely different filter architecture such as a State Variable filter (Oberheim SEM filter, Elektor formant 12dB VCF etc…)
If you triplicate the core then yes it can be done but it is a very complicated way compared to the SVF architecture.
Yves
