4089 Rhythm Generator
Page 1 of 1 [8 Posts]
PostPosted: Sun Oct 19, 2014 4:02 am    Post subject: 4089 Rhythm Generator
Subject description: with reset/sync
A rhythm generator using the CD4089, very similar to the one I used for the bandersnatch except this time I'm using the clear input as a reset.
For this to work the D input needs to be low when the Clear is made high. So I used an AND gate (made up of U2a + U2b) to
be able to make the D input low. Because this has to happen when the Clear input is high there is an extra inverter (U2c) on
the input of this AND gate. The reset signal is turned into a very narrow pulse and used as a sync input. The Clock needs to
be inverted (since the CD4089 triggers on a high to low transistion) so I used a transistor for that.
The 3 position (toggle) switches make it possible to select between a high, low, or external signal for the ABCD control inputs.
CD4089 timing diagram
 Filesize:  61.24 KB
 Viewed:  17610 Time(s)
4089 Rhythm Generator schematic
 Filesize:  59.93 KB
 Viewed:  1822 Time(s)
 Filesize:  97.97 KB
 Viewed:  838 Time(s)
 Filesize:  88.47 KB
 Viewed:  793 Time(s)
 Filesize:  65.76 KB
 Viewed:  828 Time(s)
dave the butcher
PostPosted: Sun Oct 19, 2014 2:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, looks interesting!!!
gasboss775
PostPosted: Thu Mar 09, 2017 5:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
PHOBoS have you tried running an audio rate clock through this. The 4089 makes a good melody generator if you sequence the ABCD inputs with a pattern generator.
PostPosted: Fri Mar 10, 2017 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I probably tried it but I am not entirely sure, so I guess I have to give it (another) go. It should indeed work very nicely.
mike page
PostPosted: Wed Jan 17, 2018 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Excellent! I was just thinking of building pretty much exactly this. I dont have to do the breadboarding now! THANKSSSSS!
PostPosted: Thu Jan 18, 2018 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
good to hear it's useful Very Happy
You can get some longer sequences out of it by connecting the control inputs to a counter like a 4040. Even more fun if
you use an output of the 4089 to clock that. Of course you could use any digital signals and I often use a LFSR to have
some (semi-)random variations when I use it for drums.
mike page
PostPosted: Sun Jan 21, 2018 6:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I turned it into a PCB Smile
Im developing a surface mount lunetta modular format where the modules are horizontal as that seems to suit my designs best. They will latch straight onto power rails, maybe with magnets. Here we are looking at the back of a panel.
bolts and switches go through the larger pads. It should be very flat, I might build it into the shell of an old macbook Smile
At the larger blue 'O' a pin on the 4089 needs to be bodged to ground.
zaphod betamax
PostPosted: Thu Oct 27, 2022 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great circuit.
Will have to buy some CD4089s and build some up!
