Polivoks Euro Format PCB
Page 1 of 1 [12 Posts]
jbeuckm
Audio files: 9
PostPosted: Tue Dec 29, 2015 2:08 pm    Post subject: Polivoks Euro Format PCB Reply with quote  Mark this post and the followings unread
I'm planning to make a no-wire layout for this filter.
How does this schematic look, @isak?
 Filesize:  98.65 KB
 Viewed:  568 Time(s)
jbeuckm
Audio files: 9
PostPosted: Thu Dec 31, 2015 10:08 pm    Post subject:   Reply with quote  Mark this post and the followings unread
I reversed the resonance pot, but this works well on 12V.
Happy New Year!
 Filesize:  36.07 KB
 Viewed:  343 Time(s)
isak
PostPosted: Sat Jan 02, 2016 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Damn man!
Great work!
I dont see you post the files Smile
Did you built it?
How does it sounds?
Please if you dont post the files let me heat the sound! Shocked
Cheers and hapoy new year Smile
isak
PostPosted: Sat Jan 02, 2016 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I see you didnt do the layout with the known mods, as i understand they are very good to add.
Maybe you can add them?
I think it would be easy for you.
The mods are listed here:
http://modularsynthesis.com/kuzmin/polivoks/polivoks_vcf.htm
 Filesize:  304.04 KB
 Viewed:  413 Time(s)
jbeuckm
Audio files: 9
PostPosted: Sat Jan 02, 2016 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I built and verified that first layout. The github files have the resonance pot corrected and a few tweaks: https://github.com/jbeuckm/Polivoks-VCF
Yes - should be pretty easy to add in the mods.
isak
PostPosted: Sat Jan 02, 2016 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thats cool!
Can you maybe add sound clips please?
Did you built it with LM4250?
jbeuckm
Audio files: 9
PostPosted: Sat Jan 02, 2016 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep LM4250
PostPosted: Sat Jan 02, 2016 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://nz.mouser.com/ProductDetail/Texas-Instruments/LM4250CN-NOPB/?qs=sGAEpiMZZMtOXy69nW9rM8pMfn3Xc4QRCklImShfPEE%3d
This part? I thought that the Polivoks ran on unobtanium, might have to look into this Smile
jbeuckm
Audio files: 9
PostPosted: Sat Jan 02, 2016 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got mine a little cheaper from Digikey:
http://www.digikey.com/product-detail/en/LM4250CN%2FNOPB/LM4250CN%2FNOPB-ND/9489
isak
PostPosted: Sat Jan 02, 2016 10:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Amazing!!!
Thanks man Smile
jbeuckm
Audio files: 9
PostPosted: Fri Jan 29, 2016 9:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a working layout with the mods from above. I have not tried the FM input on either layout but the LP and BP are working with Freq/Res controls as expected. I am still figuring out what the "soft" switch does, but it does something.
schematic updated with mods
 Filesize:  33.87 KB
 Viewed:  417 Time(s)
polivoks vcf layout with mods
 Filesize:  38.18 KB
 Viewed:  362 Time(s)
isak
PostPosted: Sat Jan 30, 2016 3:17 am    Post subject: Reply with quote  Mark this post and the followings unread
cool, thanks man Smile
