 Forum index » Clavia Nord Modular » G2 Patches - Completed » Drones
Is this a drone?
Page 1 of 1 [7 Posts]
Carl Mikael Björk
G2 patch files: 5
PostPosted: Mon May 30, 2005 4:19 am    Post subject: Is this a drone? Reply with quote  Mark this post and the followings unread
This started out with the need for a bassy texture. Then I read an article in Grooves magazine on drones. And I wonder if this one might qualify. They talked a lot of overtones, which isn't exactly a feature in my patch.
Anyway, there are four variations, if you'd like to add some - please do and upload a new version of the patch here.
Mikael
Three-by-Drone.pch2
A drony bass texture. Based on three parallell 2 osc/dual filter synths. Pan, tuning, filter and volume are modified by LFOs. Valuable parameters (for programming) are assigned to knobs. Enjoy!
 Filename:  Three-by-Drone.pch2
 Filesize:  5.89 KB
 Downloaded:  1879 Time(s)
Electronic Music Tutorials Designed for Learning
Audio files: 224
PostPosted: Mon May 30, 2005 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, this is definitely a drone. Very Happy
Drone is a pretty loose term. The 5th string on a 5-string banjo is called a drone even though it is just a "ping" when plucked. It's a drone because it plays the same note throughout the performance while the other strings change pitch by being fretted. So, but this analogy, even variation 3 is a drone, IMHO.
Carl Mikael Björk
G2 patch files: 5
PostPosted: Mon May 30, 2005 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Mosc for clearing that out! Very Happy And thank for listening...
/Mikael
cebec
G2 patch files: 31
PostPosted: Tue May 31, 2005 4:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
yep, definitely a drone. and a good one at that... nice n' slow...
Carl Mikael Björk
G2 patch files: 5
PostPosted: Wed Jun 01, 2005 12:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you, Sir! Very Happy
Wan
G2 patch files: 46
PostPosted: Sun Jun 05, 2005 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fine patch, nice to play with, good knob assignments.
And filed as a drone too Smile
Grtz Wan
Carl Mikael Björk
G2 patch files: 5
PostPosted: Sun Jun 05, 2005 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very much Wan. Glad you enjoyed it! Very Happy
With all this feedback, maybe I should try building one with evolving overtones... Has no clue as how to go about it. But I might as well try.
Regards,
Mikael
