cgs35 VCF modification question
Page 1 of 1 [3 Posts]
mike page
PostPosted: Sat Jun 02, 2018 7:15 am    Post subject: cgs35 VCF modification question Reply with quote  Mark this post and the followings unread
Hello all, Im currently plan on making the cgs35 steiner filter in a module with another filter.
The other filter uses 3 parts of a ssm2164. so I was thinking maybe I could use the spare VCA to replace something on the steiner. Any thoughts on this?
wackelpeter
Audio files: 10
PostPosted: Sat Jun 02, 2018 7:23 am    Post subject: Reply with quote  Mark this post and the followings unread
not really sure if this would work... but one Thing that i can imagine is to fit the VCA in the resonance path and have it voltage controlled... thus still with an attentuator to dial in a amount of resonance manually and add some more via VC... if it works also switching resonance on/off could be a nice feature eventually...
Fernando
PostPosted: Wed Jun 10, 2020 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
or do that externally: an VCA between output and BP input
Fer
