 Forum index » Instruments and Equipment » DSI Synths
Evolver sequencer external midi clock problem
Page 1 of 1 [2 Posts]
sonictransportsystem
PostPosted: Tue Oct 01, 2019 3:38 pm    Post subject: Evolver sequencer external midi clock problem Reply with quote  Mark this post and the followings unread
Hi to everyone,
When working with external midi clock from a DAW or from an hardware sequencer like Elektron A4 my Evolver desktop sequencer after some minutes loses the clock and start playing out of midi clock its just a small diference but its there.
Do you guys have the same problem or have any idea.
Thanks in advance.
efluon
PostPosted: Wed Oct 02, 2019 12:21 am    Post subject: Reply with quote  Mark this post and the followings unread
With midi clock midi jitter adds up. This is a quite strong effect especially with most usb based interfaces that have a jitter of 1ms. And quite normal. I don‘t see it as obviously when using my digitakt as clock, so either the a4 has worse timing, or it is on the input of the evolver (or something else).
I solve it by using note ons as clock (or directly as triggers). Another solution I use (that won‘t help you either) is using ableton link. If it is not the evolvers input jitter (which would be bad), you can get a precise master clock, which will improve the situation.
