TheGreenGroove
Posted: Wed Oct 05, 2005 11:40 am Post subject:
Favorite Reverb Tools |
Hi everyone, I am looking right now for some way of getting realistic and controlable reverb. I am wondering what peoples favorite tools are for gaining this effect. Right now I am using the Cubase SX Built in plug-ins and am finding them extremely limiting.
So tell me, what is your favorite reverb tool? |
Mohoyoho
seraph
Editor
Audio files: 33
Posted: Wed Oct 05, 2005 2:05 pm Post subject:
elektro80 wrote: | RoomVerb M1 for the Soundart Chameleon |
Stein do you own a Soundart Chameleon? _________________ homepage - blog - forum - youtube
Quote: | Don't die with your music still in you - Wayne Dyer |
Posted: Wed Oct 05, 2005 2:17 pm Post subject:
Realtime: Lexicon MPX-1
Convolution(non-realtime): Cool Edit Pro 2.0 (built-in) or SIR vst.
Lots of convolution impulses at http://www.noisevault.com (SIR can be found through there as well). But I tend to record my own (I use a dog clicker from a pet store and a portable minidisc/MP3 recorder). |
Posted: Wed Oct 05, 2005 2:21 pm Post subject:
seraph wrote: | elektro80 wrote: | RoomVerb M1 for the Soundart Chameleon |
Stein do you own a Soundart Chameleon? |
Yes. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Wed Oct 05, 2005 6:06 pm Post subject:
Re: Favorite Reverb Tools |
TheGreenGroove wrote: | Hi everyone, I am looking right now for some way of getting realistic and controlable reverb. I am wondering what peoples favorite tools are for gaining this effect. Right now I am using the Cubase SX Built in plug-ins and am finding them extremely limiting.
In a mix, either live or in the studio, reverb can enveloped using a synth with great success with . Think of it as an extra ( stereo) synth voice. This method, or rather, approach to using reverb will often render a more interesting and musical blend. What you really want is to add room, some kind of spatial fatness and body to the sounds. The resulting mix should of course have a "realistic" sound but that does not mean you cannot shape the wet signal as you like.
You can also add stepfiltering in there somewhere.
This is an example of a bass line that is being processed in real time using similar techniques.
Wholesale _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
paul e.
Joined: Sep 22, 2003 Posts: 1567 Location: toronto, canada
Posted: Wed Oct 05, 2005 6:35 pm Post subject:
i'm thinking this is a 'production/engineering topic'..moving _________________ Spiral Recordings |
Posted: Wed Oct 05, 2005 6:41 pm Post subject:
Yup.. smart move..  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Mohoyoho
Posted: Wed Oct 05, 2005 7:02 pm Post subject:
THX
This is a good example of how reverb can be used within a patch. However, the effect will then become a part of the voice and needs to be played. This hardly works well for post processing. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
paul e.
Posted: Wed Oct 05, 2005 7:11 pm Post subject:
yeah....groovy track....cool lead sound... _________________ Spiral Recordings |
Posted: Wed Oct 05, 2005 7:16 pm Post subject:
just a plinky organ.. but I like organs
anyway.. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
paul e.
Posted: Wed Oct 05, 2005 7:24 pm Post subject:
an Elektro 80 ultra-organ™... _________________ Spiral Recordings |
Posted: Wed Oct 05, 2005 7:26 pm Post subject:
"middle aged dude with an ultraorgan looking for a gig.."
right..
Flickr |
TheGreenGroove
Posted: Fri Oct 07, 2005 11:23 am Post subject:
Electro80 are you talking about running the wet signal of the reverb BACK into the Filter input of the synthesiser? I don't exactly understand what you mean by Enveloped by a synth, but It sounds like a good idea because yes the intent is to fatten up the sounds most of the time. Generally I only want to simulate a room if I am running a reverb over the whole track. |
Posted: Fri Oct 07, 2005 12:33 pm Post subject:
Yes, but technically .."back into" isn´t quite correct.. but I guess we are thinking abut the same thing.
The NM-1/G2 are two inexpensive tools for this. They have audio inputs and you can set up the processing patch as somplec as you like in order to make the tone you want.
A modern reverb creates its own envelope.. which is what you hear when you listen to ony the wet output of a reverb device. You can however treat this signal as if comes from a synth.. the wet signal is the oscillator output.. then throw fixed filter banks, VCFs, envelope generators VCSa and whatnot. Imagine simply effects first.. like using a really slow attack on the reverb feed.
It is however more fun to do this in stereo.. so you gotta at least double everything. Doing this the old way is great too, but most analog modulars will need signal level adapters. I haven´t seen any of these around recently, but I am sure there must be some DIY kits or schematics available still . This does of course also mean that you just as well can split and pipe a signal to a reverb device or any outboard device you might think of .. out of an analog modular.. and then back in after processing. Be sure to have the proper level/gain adapters around though. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
TheGreenGroove
Posted: Fri Oct 07, 2005 2:14 pm Post subject:
I am still not sure I understand how this would work. I understand the idea of treating the wet reverb signal as an oscillator, but I am not sure where I would find the ADSR to run it into. Are there LFO, Filer, ADSR boxes that I can buy? A piece of equipment or plug-in that allows me to manipulate any audio signal as though it were a synthesiser? |
Posted: Fri Oct 07, 2005 6:01 pm Post subject:
There are lotsa software virtual synths that can be used for processing audio tracks or live audio inputs. The most cost effective tools these days for realtime processsing are the Clavia NM-1 and the G-2.. racks or keys editions.. you pick whatever suits you best.
You can of course do this old style using analog modulars, but this is still relatively expensive. If you choose this route, be sure to use the correct level/gain adapters though.
You would of course want to do this in stereo, so if you are doing this using Doepfers, Oakleys or MOTMs or whatever, you need at least 2 of each module. In some cases in can be worthwhile to think M-S and then you might at times find that you willl even need 5 splits or more depening on your chosen level of "serious fun". _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Sun Oct 09, 2005 8:50 am Post subject:
TheGreenGroove wrote: | A piece of equipment or plug-in that allows me to manipulate any audio signal as though it were a synthesiser? |
An analog modular synth. ( But do get the proper gain/level adapters. )
This is as old school as it gets. Before the true modern synths ( Moog etc. ) showed up on the scene, processing audio using custom built equipment was what electronic music was about. Many of the electronic music studios/tape labs that bought analog modular synths early on would integrate these with what was already there.
An interesting thing is that the mentality at the times led popular experimental acts like Pink Floyd to rather pursue the tape lab setting rather than laying down tracks like The Beatles did. Then they took the tape lab sound with them when they did gigs.
I guess we are still seeing the influence of the BBC Radiophonics Workshop.
Synths never really caught up with all this. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Joined: Jan 31, 2003 Posts: 18252 Location: Durham, NC
Audio files: 227
Posted: Sun Oct 09, 2005 9:11 am Post subject:
I think what Elektro80 is getting at is to use the reverb as a sort of filter module. In a typical subtractive synthesis patch you have:
osc -> fixed filter bank -> low pass filter -> VCA/Envelope -> reverb
Elektro80 is suggesting reversing the order of the VCA/Envelope and the reverb. I guess you could also put the reverb in at any point after the osc.
Am I right, Elektro80? _________________ --Howard
my music and other stuff |
Posted: Sun Oct 09, 2005 9:23 am Post subject:
That is one possible config.
Or..
Mono signal = osc -> fixed filter bank -> low pass filter -> VCA/Envelope ( this is your main synth signal .. pan to mid )
split at outpout.. send to a stereo reverb
then_ stereo compressor/limiter - stereo distortion - fixed filter banks - low pass ( and this one might be say.. stepped by a sequencer.. so you have like 16 filter states that the sequencer will run through ) - stereo/compressor limiter - Stereo VCA / envelope.
Obviously you might want to add in control sections that can fade or change the raw synth signal too.. like ducking it in the decay state of the adsr and use the rattlting stepfiltered reverb feed for that section of the sound.
Then.. why not also split this even more and slide in some envelope followers / SHs and more.. and set up some kind of stereo pan.. or signal controlled scheme for whatever..
Main thing is to create something that feels rich and full and will move spatially while you play. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Sun Oct 09, 2005 9:40 am Post subject:
There are numerous ways to set this up. The most important side to this is seeing those obnoxious outboards as useful within a patch, and not simply strapped to the synth output. I tend to think that using whatever is in the kitchen drawer is what electronic music used to be about anyway. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Sun Oct 09, 2005 9:56 am Post subject:
And you can throw in vocoders into the patch too. No need for a microphone, you can use a some signal somewhere from within the patch as the carrier and then some other as the modulator.
The attached file ( which will be online for only a limited time) has something like 25 such similar patches - using vocoder, reverbs, compressors and more.
( Yes Kassen, there are some drums here.. old style step sequenced synth stuff ) _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr Last edited by elektro80 on Tue Oct 18, 2011 4:44 pm; edited 2 times in total |
deknow
Posted: Sun Oct 09, 2005 10:39 am Post subject:
stein, that reads like the answer key to some audio production textbook!
deknow |
