Tempo-sensitive loop capture
jamos
G2 patch files: 41
PostPosted: Sat Dec 03, 2005 5:10 pm    Post subject: Tempo-sensitive loop capture
Subject description: A loop capture block that syncs to the master clock
This little patch is something i'm trying to build that snags a loop that is synced to the master clock temp. Start your audio, hit Capture, and this will capture exactly one measure's worth of audio.
The reason I put it in Experimental rather than Building Blocks is that I'm trying to figure out how to make it easy to change teh loop length - not necessarily on the fly, but at least at setup time. Right now I have to change the delay time as well as either the LFO speed or the sequencer length. I'd like to tie all those to a single control, but I haven't been able to figure out how.
Note that this is based on someone else's work but I can't remember whose.
Suggestions?
Loop Capture.pch2
A tempo-sensitive loop capture block
 Filename:  Loop Capture.pch2
 Filesize:  2.2 KB
 Downloaded:  1548 Time(s)
