G2 for Pad sounds?
Page 1 of 1 [13 Posts]
Bacizone
PostPosted: Mon Jan 01, 2007 4:44 am    Post subject: G2 for Pad sounds?
Subject description: G2 for atmospheric sounds
Is the G2/G2 Engine suitable for creating atmospheric sounds?
I mean "atmospheric" here like the Best Service's XXL Pads, XXL Pads2 sounds in categories like ATMO PADS, AMBI PADS. These are really warm, complex , I guess mulitlayered pad-like sounds.
I used to have the Nord Modular Rack, and however it was capable of creating similar sounds, I would not call its sound "warm".
Thanks for the answer.
Bz.
dorremifasol
G2 patch files: 49
PostPosted: Mon Jan 01, 2007 6:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Well I'm a newbie with the G2 but I have been unlucky at creating soft pads, probably my fault. I'm used to some Yamaha AN1X pads and I haven't been able to reproduce them in my G2, the saws sounds more raspy and aggressive.
Albert
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon Jan 01, 2007 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
The G2 "tone" is bright, tight and crisp, ideal for drums, bass, misc noises. Harder to do pads.
I usually just chorus and phaser the waves prior to the filter for a smoother tone (and after). It is hard to make pads like on a PPG / Microwave XT since the filters are so different. Also, applying Rob's tilt filter can add a smoothing effect.
/Dasz
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon Jan 01, 2007 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
here is an example I just whipped up.
/Dasz
ps.: I like to boost things when the resonance is cranked Wink
PhatPad_DZ.pch2
1st patch of 2007!
 Filename:  PhatPad_DZ.pch2
 Filesize:  3.31 KB
 Downloaded:  1639 Time(s)
Bacizone
PostPosted: Mon Jan 01, 2007 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is what I was afraid of.... Without deep programming knowledge the G2 is not really good in this league. A Virus may rock there...
Sorry dasz, I do not have currently a G2 to listen to that patch. Any mp3 example?
Does anyone know, what instruments do sample developers use for these great atmospheric sounds? I guess post-processing is heavily used on all samples.
B.
PostPosted: Mon Jan 01, 2007 6:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
You should try the G2 demo that Clavia offers for free. Runs on a PC, and is monophonic, but gives you an idea of what's possible, I'd say *most* of the patches can be played on the demo (there are a few modules that don't work on it).
Check the clavia.se site for more.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue Jan 02, 2007 12:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Bacizone,
don't get me wrong, the g2 is great at pads (I've created some 20+ saw osc pads which are T_H_I_C_K), only the kind of pads I'm into (ppg/waldorf xt), take some effort to build -- the ones which will jump out of the mix wrt other G2 sounds. IMO only, not in general!
Once you use a lot of overlapping LFO's and the G2's effects modules, you can do some pretty amazing atmosperic stuff, not to mention being able to trigger external samplers with G2 sequencers connected to midi out modules. It is a sound to behold (sorry I cannot share such examples at the moment).
Please try the demo like jksuperstar suggested, don't give up on the G2.
Check out the G2 demo with some patches from the pad section here on electro-music ( http://electro-music.com/forum/forum-58.html ),
And do keep in mind, we now have a NM Classic to G2 converter project which will greatly enhance the existing sound base of the G2 ( http://electro-music.com/forum/topic-15095.html )
Happy new year,
/Dasz
Bacizone
PostPosted: Tue Jan 02, 2007 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the answer!
I'll chech that patch in the G2 demo software.
It is nice to see that the G2 community stays helpful! What a good news.. G1 to G2 converter. Does it exactly translates e.g. the DX7 patches of the G1?
Thanks,
B.
dreinulldrei
PostPosted: Fri Jan 05, 2007 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe you should rather get one of the other NordLeads 2 or 3. Those can create by instant really really nice ambi pads.
For NL3 pads, check out my podcast and especially the song bits: "Toempadangel" and "Toempadheaven".
http://geschnittenbrot.podspot.de/post/microkit_toempadangel/
Pure NordLead pads.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sat Jan 06, 2007 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
if you like the pads in the leads, you will like the pads in the g2 -- you can easily make a fairly good nord lead model in a g2. The synths are quite simmilar in sound (from what I heard from a friend who owns both a g2 and a lead 2x & lead 3).
/Dasz
sheridan
Audio files: 27
PostPosted: Sat Jan 06, 2007 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I've noticed a few things about (my) G2 pads... while it is relatively easy to create lush pad sounds on the G2 (Chorus module works a treat for them), I find it very difficult to produce bright (but not digital bright), powerful, 'in your face' pads for up tempo dance music. The other thing is that, you often need a lot of polyphony to make them sound good and then there isn't much left for other sounds.
Having said that, I would say overall, that the G2 can produce lovely sounding pads.
transformer Sheridan
Hear music and Nord Modular G2 patches and find out music production tips at
http://www.nitetimeproductions.co.uk
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Apr 12, 2007 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
a phaser and comb filter are good for stacking a big in your face pad sound ...
/Dasz
iPassenger
G2 patch files: 78
PostPosted: Sun Apr 15, 2007 2:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I would say that with time n tweaking u can get dome great pad sounds, custom filters and several oscs are a good place to start.
iP (Ross)
