Can THIS be done with g2 sequencers?
Page 1 of 1 [13 Posts]
Project
PostPosted: Sat Jun 16, 2007 1:56 am    Post subject: Can THIS be done with g2 sequencers? Reply with quote  Mark this post and the followings unread
Hi all, I'm wondering if something like what we can see in this video can be done with g2 sequencers.
http://youtube.com/watch?v=gNmzyZaqVwI
I'm talking about step skipping, manually alternating between 1 or 2 sequencers, and so on (I'm not sure about how everything that's in the video has been done)
Any help would be really appreciated..
Project
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Jun 16, 2007 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Some was already possible on the Classic, so I assume it can be done in the G2.
Take a look at
http://nm-archives.electro-music.com/010_NordModular/014_Interesting_Threads/Folder/MoogSequencerEmulation/MoogSequencer.htm
Wout
Project
PostPosted: Sat Jun 16, 2007 4:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot for your reply Wout, very interesting link, but I'm wondering how to do step skipping. The synthesizers.com sequencer, with the 2 accompanying modules featured in the video, is more advanced than the original Moog 960
regards
Project
PostPosted: Sat Jun 16, 2007 7:05 am    Post subject: Reply with quote  Mark this post and the followings unread
http://electro-music.com/forum/post-33604.html has a skipping sequencer. There are quite a few different approaches on sequencers in the patch archive, including ones that can run forward and backward.
Using http://electro-music.com/g2patches.php and your browser's search function would probably be the easiest way to find 'm.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sat Jun 16, 2007 12:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
the g2 voltage sequencer and some lfo's can do this an so much more. Also you can stack multiple sequencers so their levels add up to produce this kind of stuff.
I'm quite into the subject of sequencers.
/dasz
Project
PostPosted: Mon Jun 18, 2007 11:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your reply Dasz and BH.
One thing that does not seem possible with the G2 is having a button for forcing a step to became the current step. I.e. in the 960 every step has a button and if you press it this step became the next one in the sequence. Any hints for realizing this on the g2?
TIA
Project
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue Jun 19, 2007 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
again, the voltage sequencer can do this. You can set up 16 momentary toggle buttons which go int a mixer which then is connected to the ctrl input of the voltage sequencer.
each button is a gate for a specific cv level (0, 4,8, ...64) pressing that button will pass the specific control signal, which will jump the sequencer to that step.
/Dasz
G2 patch files: 626
PostPosted: Tue Jun 19, 2007 12:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is one option.
Uses SeqCtl and a S+H based staircase generator. Pressing one of the step buttons forces a jump to that step. Step zero is a special case.
Jump2step.pch2
Example jump to step
 Filename:  Jump2step.pch2
 Filesize:  1.84 KB
 Downloaded:  1842 Time(s)
Project
PostPosted: Sun Jun 24, 2007 3:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks G2ian, that was exactly what I was searching for regarding manual step selection, but there's still one big problem, that the step selection is completely manual, i.e., is not in time with the clock. What I have in mind is that when you press a step button, that step becames the next one in the sequence, not instantly but at the next clock signal. What I want to achieve is a performing situation where I can choose the next step number when the sequence is running. I tried to solve this thing in your patch before posting again, but today, when I've finally found the time to do it, I must admit that I failed.... so, again any help will be really appreciated...
Project
G2 patch files: 626
PostPosted: Sun Jun 24, 2007 5:05 am    Post subject: Reply with quote  Mark this post and the followings unread
lol, that's actually what my first version did, I had to add another OR gate to make it asynchronous.
What would you like it to do if you hold a step select button? This version changes to the selected step on the next clock and repeats that step as long as the button is held.
It a pity that the G2 surface does not allow the knob/button/led to be assigned to different modules.
Jump2step2.pch2
 Filename:  Jump2step2.pch2
 Filesize:  2.01 KB
 Downloaded:  1828 Time(s)
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sun Jun 24, 2007 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
This can be done. This way my 1st post on e-m (indirectly).
http://electro-music.com/forum/topic-7050-0.html&postdays=0&postorder=asc&
/Dasz
Project
PostPosted: Wed Jun 27, 2007 2:42 am    Post subject: Reply with quote  Mark this post and the followings unread
G2ian, thanks a lot, you're the man!!!, this what exactly what I was trying to achieve regarding manual step selection, and the step repeat is an added bonus! I've noticed that if I sync the sequencer with MIDI clock, it stop a few step after the master, and is not possible to have the sequence start from step 1 when the master is started (I know I should use the clock active output of the master clock, but I don't know where to connect it)
thanks again
Project
G2 patch files: 626
PostPosted: Wed Jun 27, 2007 3:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I am not sure about the late stopping but here is a version that resets to step 1 on the clock active signal. It does not work without the logic delay due to racing (S&H triggers before ValSwitch changes state).
Thanks for the tip Dasz, I think I could use that idea to get 8 knobs for pitch and 8 buttons for step jump. Still would be nice to have the spare LED run through the sequence though.
jump2step3.pch2
 Filename:  jump2step3.pch2
 Filesize:  2.14 KB
 Downloaded:  1973 Time(s)
