Streaming now
Cellular automata
Page 1 of 1 [6 Posts]
Rivelen
G2 patch files: 12
PostPosted: Wed Aug 29, 2007 6:43 am    Post subject: Cellular automata
Subject description: chaos generator
This one is a cellular automata..
what it is? : http://en.wikipedia.org/wiki/Cellular_automata
what does it look like ? have a look to the 1D family here :
http://www.mirekw.com/ca/ca_gallery.html
here are some rules : http://www.mirekw.com/ca/rullex_1dbi.html
(but i prefer press the rnd button on the rules block in the patch joined)
in fact, it is not so far from fractals...
it can be used to generate melodies, rythms, ect...
it is possible to use it in audio domain to generate sounds...
How does it work?
an array (of cells) is filled with random numbers, then, a recirculatory circuit scan thru it and apply rules to the numbers founds: A cell and its two neighbours are used to choose a rule in a lookup table (a ctrSeq).
have fun!
cellularAutomata.pch2
 Filename:  cellularAutomata.pch2
 Filesize:  1.85 KB
 Downloaded:  2114 Time(s)
JLS
G2 patch files: 316
PostPosted: Wed Aug 29, 2007 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
totaly great Smile
thanks
https://www.youtube.com/@kamilondrousek6973
https://soundcloud.com/1jls
https://soundcloud.com/user-819966312-266044932
https://github.com/jlswbs
https://www.instagram.com/ondrousek.kamil/
Audio files: 299
PostPosted: Tue Sep 04, 2007 3:45 pm    Post subject: Re: Cellular automata
Rivelen wrote:
have fun!
yes Exclamation is a nice machine Very Happy
Made a small mod to loose a module.
cellularautomaton_bh.pch2
 Filename:  cellularautomaton_bh.pch2
 Filesize:  1.95 KB
 Downloaded:  3257 Time(s)
JLS
G2 patch files: 316
PostPosted: Sat Nov 24, 2007 4:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Cellular automata static pattern version ( non random )
1-4 presets example
Smile
Cellu.pch2
cellular automat static
 Filename:  Cellu.pch2
 Filesize:  1.77 KB
 Downloaded:  2158 Time(s)
JLS
G2 patch files: 316
PostPosted: Sat Nov 24, 2007 4:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Cellular automata with binary counter pattern (non random)
Smile
Cellu2.pch2
cellular automat binary counter
 Filename:  Cellu2.pch2
 Filesize:  1.85 KB
 Downloaded:  2044 Time(s)
JLS
G2 patch files: 316
PostPosted: Wed Jan 28, 2009 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
other patching CA
Two parameters Seed and Probability
Start/Stop run
cellu3.pch2
 Filename:  cellu3.pch2
 Filesize:  2.22 KB
 Downloaded:  1933 Time(s)
