How can I emit a pulse whenever a logic signal changes?
Page 1 of 1 [23 Posts]
ark
G2 patch files: 31
PostPosted: Mon Mar 02, 2009 10:22 am    Post subject: How can I emit a pulse whenever a logic signal changes?
Subject description: I can do it but feel like there should be a simpler way
I have a logic signal that changes from time to time at LFO-ish rates. I want to emit a short pulse each time it changes.
Straightfoward way: Put the signal into a pulse generator, invert the signal and put the output of the inverter into another pulse generator, and "or" the two pulses together.
That takes three modules. Is there an easier way?
PostPosted: Mon Mar 02, 2009 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
By "changes" you mean crosses zero? Then I can't think of a more economical signal.
First I though "changes" meant, say, from 63.1 to 63.2. That's a problem I've been scratching my head at over for a couple of years.
/Stefan
ark
G2 patch files: 31
PostPosted: Mon Mar 02, 2009 1:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually, I meant that it's a logic signal -- i.e. it is either "true" or "false." In fact, it's the output of a level comparison module, which I think is always 64 or 0.
PostPosted: Mon Mar 02, 2009 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Usually I take a high pass filter followed by a diode module (double rectifying for this case), but there is not much control over the pulse duration this way and it may be less efficient cpu wise.
Detecting changes in pulse duration seems a lot less straight forward thinking
ark
G2 patch files: 31
PostPosted: Mon Mar 02, 2009 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah! I didn't realize there was a full-wave rectifier.
As it happens, in this particular case, pulse duration doesn't matter as long as it's not too long.
Here is what I am really trying to do.
I would like to build a note sequencer with MIDI output that gives me the degree of control one finds on synths such as the Radias or Blofeld, in which for each note you can specify pitch, duration, and velocity.
No problem so far -- except I would also like to be able to have a swing rhythm, and I would like the note durations to change automatically as the swing amount changes. This requirement seems to rule out using a clock generator module directly, despite its swing facility, because I don't know how to make the note duration change as swing changes.
So here is how I'm trying to solve the problem. It occurs to me that an LfoShpA module can generate a triangle wave with a variable slope. If I can detect the up and down peaks, I can reverse the polarity of every other segment, and get a triangle wave with two alternating frequencies. Then I can use level comparisons on the triangle waves to decide when to cut off each note.
Chet
G2 patch files: 35
PostPosted: Mon Mar 02, 2009 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could feed the original signal into a short delay and then XOR the delay's output with the original signal.
Tim Kleinert
G2 patch files: 236
PostPosted: Mon Mar 02, 2009 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I had the delay-XOR idea too. However, this leaves you with a second gate which you might have no any use for.
Here's the most efficient solution -just two blue modules. It's a bit weird to understand Laughing, but it works.
bipolartriggerTK.pch2
Emits a trigger whenever zero goes 64, or 64 goes zero. efficient (2 modules).
 Filename:  bipolartriggerTK.pch2
 Filesize:  1.05 KB
 Downloaded:  1698 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Tue Mar 03, 2009 4:59 am    Post subject: Reply with quote  Mark this post and the followings unread
hehe..
Cunning and then the delay sets the pulse duration, set it too long in relation to the rhythm though and it starts to fall over. Love the solution tho, sorry tim can't see yrs as I'm at work.
iP (Ross)
iPassenger
G2 patch files: 78
PostPosted: Tue Mar 03, 2009 5:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm really struggling to understand this sat at work, please post it if you get it sorted out tho as it sounds great.
Drifting OT: Presumably you could create your own groove template by using a delay line, running the standard clock signal through it, also sending that clock signal to a groove sequencer, the groove sequencer value output goes to the delay mod input and the output of the delay line to trigger your actual sequencers. Positive and negative values of the groove sequencers would push the timing of the notes in either direction.
The down side to this would be that the amount of groove would be dependent on tempo as this wouldn't be taken into account by the delay unit, so perhaps the output of the groove sequencer would need to be scaled to the tempo some how. Furthermore the whole sequence would need to be delayed somewhat in order to allow for negative time shift of the triggered notes.
iP (Ross)
ark
G2 patch files: 31
PostPosted: Tue Mar 03, 2009 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, what I have so far is attached. Turn the "Shape" dial on the LFO in the upper left corner to change the amount of swing.
Right now I am using a low-pass filter to detect the inflection points of the triangle wave that the LFO generates. I don't like this because (1) it seems to be unreliable, and (2) its output is an orange signal, which consumes more cpu than needed.
It seems to me that there must be a simple way to find out deterministically when a triangle wave changes direction.
Swing sequencer example.pch2
 Filename:  Swing sequencer example.pch2
 Filesize:  2.15 KB
 Downloaded:  1882 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Tue Mar 03, 2009 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok,
Just had a clumsy idea that might work. What if you use shift register clocked by 392Hz LFOC.
The input to the shift register is the output of your SHPLFO, take the second output (and therefore delayed) of the shift register and plug it into one side of a comparator and the other input gets yr signal straight from the SHPLFO. So now you will be able to tell when the lfo is going in one direction (and therfore when it is going in the other).... It should also remain a yellow rather than orange signal. You could use either logic invertor or another comparator if you needed two logic signals all the time.
Sorry if this duplicates ideas already referenced but am stuck at work so cant really test anything out here. Smile
iP (Ross)
ark
G2 patch files: 31
PostPosted: Tue Mar 03, 2009 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I just tried out your suggestion and there is something I don't understand: When I set the delay to 0.01ms, it stops working. This behavior makes no sense to me, as I would think that there would have to be a difference in level over some 0.01ms period after the direction change.
I similarly tried Tim's trick of using a Mix-1 module to introduce the smallest possible delay, and again the levels appear to compare equal all the time with such a short delay. Makes no sense to me -- can someone explain?
Direction change detector.pch2
 Filename:  Direction change detector.pch2
 Filesize:  998 Bytes
 Downloaded:  1670 Time(s)
Chet
G2 patch files: 35
PostPosted: Tue Mar 03, 2009 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
In a 96kHz system, 0.01 ms is about one sample. I wouldn't try to be that precise on a G2.
ark
G2 patch files: 31
PostPosted: Tue Mar 03, 2009 10:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I still do not understand why it should not work--because if the signal level changes, then at some point it should differ from its most recent level.
PostPosted: Tue Mar 03, 2009 11:01 am    Post subject: Reply with quote  Mark this post and the followings unread
The blue and yellow signals are calculated at a quarter (I think) of the frequency of red signals. This might affect the way the compare modules work.
/Stefan
ark
G2 patch files: 31
PostPosted: Tue Mar 03, 2009 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, so you're thinking that maybe the two signals differ between sampling points and the difference has gone away by the time the next sample request rolls around?
Fozzie
G2 patch files: 49
PostPosted: Tue Mar 03, 2009 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can't look at any patches right now, but there is a bug in the dlyeight module
Rob wrote
The DlyEight module is off by 4 ticks on the scale, the knob positions 0 to 3 simply "do not work" and the input is passed unaltered on all eight outputs, so all delays are zero. At position 4 to 7 the eight delay outputs give delays of 1 to 8 samples. Then at knob position 8 to 11 the delays are from 2 to 16 samples with gaps of a sample. At knob position 12 to 15 they are 3 to 24 samples with gaps of 3 samples. Etc.
So, the display is utterly incorrect, as there are actually only 32 ranges on the knob and not 128 as could be expected from the display.
here: http://electro-music.com/forum/post-105724.html#105724
maybe that has something to do with this?? Is this the troublesome module??
iPassenger
G2 patch files: 78
PostPosted: Tue Mar 03, 2009 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
/Stefan
Yeah pretty sure that is it, its 24Khz for control level signals.
iP (Ross)
iPassenger
G2 patch files: 78
PostPosted: Tue Mar 03, 2009 12:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
How about this:
EDIT : Swapped LFOC for Logic inverter fedback on itself.
Test Groove.pch2
 Filename:  Test Groove.pch2
 Filesize:  1.6 KB
 Downloaded:  1693 Time(s)
test_groove_2_185[1].pch2
 Filename:  test_groove_2_185[1].pch2
 Filesize:  1.63 KB
 Downloaded:  1706 Time(s)
iP (Ross)
Fozzie
G2 patch files: 49
PostPosted: Tue Mar 03, 2009 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, had a chance now to look at the patch and unfortunately my previous comment was utterly irrelevant Embarassed Laughing
iPassenger
G2 patch files: 78
PostPosted: Tue Mar 03, 2009 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Smart. Smile
iP (Ross)
iPassenger
G2 patch files: 78
PostPosted: Tue Mar 03, 2009 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I feel a bit like that as my patch is fair bit more processing power..
Rolling Eyes
having said that it does seem to work pretty smoothly, as long as the lfo remains in sync with the on beats.
iP (Ross)
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Mar 04, 2009 3:08 am    Post subject: Reply with quote  Mark this post and the followings unread
The reliability issues are caused by tweaking swing (LFO shape) and length parameters continuously, as the comparators are doing their thing -which can whack things out of alignment. Adding control modules for these S/H'ing them with the LFO Sync output removes all problems.
Attached is a 100% bulletproof version, which also keeps check of minimum/maximum note lengths, so the sequencer triggering is always reliable.
tim
LFOSwing16 TK.pch2
using a shape LFO as a seq clock with swing and length control (idea by ark)
 Filename:  LFOSwing16 TK.pch2
 Filesize:  1.86 KB
 Downloaded:  1708 Time(s)
