os x 10.64 problem or corrupted patch? please test
Page 1 of 1 [6 Posts]
3phase
G2 patch files: 141
PostPosted: Wed Jun 16, 2010 8:03 pm    Post subject: os x 10.64 problem or corrupted patch? please test Reply with quote  Mark this post and the followings unread
i just updated to os 10.64 on my mac and first thing what happened was that my editor 1.62 hangs when i try to alter that patch..remove or add a module.. editor hangs...
i would like to know if that is only this patch or maybe related to the new os..
can anybody try the patch on antoher computer system or osx other than 10.64?
thanks
orcgCh_SR DX7.pch2
 Filename:  orcgCh_SR DX7.pch2
 Filesize:  6.08 KB
 Downloaded:  2016 Time(s)
Rivelen
G2 patch files: 12
PostPosted: Thu Jun 17, 2010 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Same thing here,
problem fixed Smile : it was the label box on top left (variation names) that was corrupted (??).
..see patch attached.
orcgch_sr_dx7_93.pch2
 Filename:  orcgch_sr_dx7_93.pch2
 Filesize:  5.74 KB
 Downloaded:  1910 Time(s)
Burp
G2 patch files: 7
PostPosted: Thu Jun 17, 2010 1:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Same here with corrupted patch. With good patch no problem. Tested with some other patches, until now no problems.
(OSX 10.6.4 - G2 editor 1.62)
if you don't know where you're going, you will allways arrive
3phase
G2 patch files: 141
PostPosted: Fri Jun 18, 2010 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Rivelen wrote:
Same thing here,
thanks.. how do you manged to fix that? i tried to delete theese modules but was crashing on any try...
Rivelen
G2 patch files: 12
PostPosted: Fri Jun 18, 2010 2:33 am    Post subject: Reply with quote  Mark this post and the followings unread
i had to delete every column of modules,one after another, to find in wich one the problem was.
the editor crashed also here, until i deleted the left one.
so i tried to delete modules in this column until i find the problem.
(that was a lot of crashes Laughing )
i already had this problem on some nm1 converted patches, that's why i knew the trick...
(OSX 10.6.2 - G2 editor 1.62)
varice
Audio files: 29
G2 patch files: 54
PostPosted: Fri Jun 18, 2010 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
It appears that the convertor has created two sets of variation name modules, one set hidden behind the other in the Editor window. When I double click on one of the name modules, the text of the hidden name module appears in the edit box instead of the text of the name module on top. I can select and move the hidden name module to a different position or delete it, and the module on top stays in place. Once the hidden module is moved or deleted from behind the top module, then you can edit the top module as usual.
I did this running the 1.40 Editor on Windows XP offline (USB disconnected), and the Editor never crashed. I have not tested this with G2 connected.
varice
