Fading between several oscillators?
Page 1 of 1 [11 Posts]
laurentius
PostPosted: Tue Apr 11, 2017 1:45 pm    Post subject: Fading between several oscillators? Reply with quote  Mark this post and the followings unread
How would you do this?:
Let's say I have 8 different oscillators. I wanna fade from one to the next using a controller (might be the mod wheel for instance).
On top of that it would be amazing to have the option to not fade between the osc's but mix/blend them together.
Each option itself wouldn't be a too hard task, but both together in one patch seems impossible for me.
Any idea?
Thanks,
L.
PostPosted: Tue Apr 11, 2017 10:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would use 8 digitally controlled potmeters, a rotary encoder and an Arduino to pull this off
PostPosted: Tue Apr 11, 2017 11:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://jhaible.com/legacy/interpolating_scanner_and_scanv/jh_interpolating_scanner_and_scanvib.html
The Interpolating Scanner sounds like the first part of what you're after.
Easiest way to have the second part would be to have a little 8 input mixer (little, he says!) just before the OTAs.
Edit -- don't solder your G2. It probably won't end well.
G2 patch files: 626
PostPosted: Wed Apr 12, 2017 12:40 am    Post subject: Re: Fading between several oscillators? Reply with quote  Mark this post and the followings unread
Any idea?
Thanks,
L.
The Mux8-1X (in the switch group) does this. The X-Fade knob varies from hard switch to smooth cross fade between consecutive inputs.
Patch your mod wheel or whatever to the Ctrl input.
PostPosted: Wed Apr 12, 2017 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Very sorry, I did not spot that this was the G2 section.
PostPosted: Wed Apr 12, 2017 2:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Me neither Embarassed
laurentius
PostPosted: Wed Apr 12, 2017 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, much appreciated. Still the second part of my task remains unclear to me how solve it... Wink
G2 patch files: 626
PostPosted: Wed Apr 12, 2017 6:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, I missed that. Can you explain to me the difference between fade, mix and blend?
laurentius
PostPosted: Fri Apr 14, 2017 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fade: pretty obvious, I hope. I want to fade from one to the next oscillator so that basically it's just one osc sounding.
Blend: I mean mixing them together (all of them together).
The problem is to find a solution to be flexible in doing both: Having one controller like the mod wheel for the fade-thing while having the encoders at hand to mix all the oscillators together when I want to...
I don't know how to patch that together...
G2 patch files: 626
PostPosted: Fri Apr 14, 2017 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Like using a mixer and a fader?
This patch allows you to choose with a switch. If you were thinking of doing both at the same time, just replace the switch with a two input mixer.
Please excuse me if I still don't understand what you are trying to do.
fade-mix.pch2
demo
 Filename:  fade-mix.pch2
 Filesize:  1.33 KB
 Downloaded:  3956 Time(s)
laurentius
PostPosted: Sat Apr 15, 2017 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
that seems like a perfect solution! Thanks!!!
