 Forum index » Clavia Nord Modular » G2 Patches - Completed » Synth
Lite Synth ! my first Patch with the G2 Engine
Page 1 of 1 [9 Posts]
oxylog2000
G2 patch files: 8
PostPosted: Sun Dec 11, 2005 2:00 pm    Post subject: Lite Synth ! my first Patch with the G2 Engine Reply with quote  Mark this post and the followings unread
hey...
this is my first patch wich i created with the G2 Engine.
it´s easy stuff, but powerfull.
i assignd most important knobs(like OSC,Pitch,Cutoff..like this)
to the behringer BCR2000.
on behringer i use the preset fromAfro88.
have fun.
greetings
SynthLite.pch2
 Filename:  SynthLite.pch2
 Filesize:  2.76 KB
 Downloaded:  1356 Time(s)
Audio files: 225
PostPosted: Sun Dec 11, 2005 7:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Congrats.
Nice patch.
Just a heads-up. Your patch has a gray patch cord. This is because it connects an input to an input. It doesn't really hurt anything, but it doesn't do anything either.
oxylog2000
G2 patch files: 8
PostPosted: Mon Dec 12, 2005 4:26 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks.
yes i know, the grey line.
i forgot to disconnect Smile
greetings
oxylog2000
G2 patch files: 8
PostPosted: Mon Dec 12, 2005 9:07 am    Post subject: Reply with quote  Mark this post and the followings unread
hey..
in moment i working on variations for the synth.
but i have one problem.
in the patch i have a OSC is calles "oscD1".
for vari 1 i want use the sine. but for vari 3 i want use the saw.
the problem is.. if i change in oscd1 to saw(for variation3).. then i go back to vari1, there is also changed to saw !
but i have this problem only with this module.
here is the patch
SynthLiteWithVar.pch2
 Filename:  SynthLiteWithVar.pch2
 Filesize:  2.75 KB
 Downloaded:  1296 Time(s)
Audio files: 225
PostPosted: Mon Dec 12, 2005 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks like you have discovered a bug in the OscD module. Shocked
Wan
G2 patch files: 46
PostPosted: Mon Dec 12, 2005 10:38 am    Post subject: Reply with quote  Mark this post and the followings unread
No, this is not a bug.
Osc D makes use of a dropdown listbox to choose the waveform. This type of control in the editor means that a change of value will be recalculated and used for ALL variations. Using less CPU.
If you want to change waveform between variations you have to use an osc with a Radiobutton type control in the editor (f.i. Osc A). Using more CPU.
Hope this helps
Grtz Wan
Audio files: 225
PostPosted: Mon Dec 12, 2005 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I stand corrected. Thank you. Very Happy
oxylog2000
G2 patch files: 8
PostPosted: Mon Dec 12, 2005 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
ahhh ok.. thank you for the answer.
i will change the OSC.
thx+greetings
Tranceparent
PostPosted: Tue Dec 20, 2005 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
thx+greetings
Note that Oscillators with radio buttons require more power from your G2's DSP units, so if you don't really need different waveforms, use the Oscillators with the dropdown menus that are more economic as far as processing power is concerned. Wink
Clavia Nord Modular G2X rules!
Moduled Modulated Modulation Modular Module...
