How was this sound made?
Page 1 of 1 [10 Posts]
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Sun Aug 13, 2006 6:55 pm    Post subject: How was this sound made? Reply with quote  Mark this post and the followings unread
Anyone have any idea how this sound was made and/or how to recreate it with the G2? It's the showmff sound halfway through beat 2 of the bar.
It is one of the few sounds that I really like, that I have no idea how to make Evil or Very Mad
showmff.mp3
Showmff sound
 Filename:  showmff.mp3
 Filesize:  57.98 KB
 Downloaded:  1436 Time(s)
Tim Kleinert
G2 patch files: 236
PostPosted: Mon Aug 14, 2006 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
It sounds sampling-based to my ears. Like a downpitched snippet of something.
I guess you could synthesize it somehow -I hear a "noise" component and a tonal component. Perhaps trying to get the formants of those two components right by means of static phasing or comb filters, EQs etc. and then shape the transients might be a good start. That's the route I would try.
G2 patch files: 626
PostPosted: Mon Aug 14, 2006 4:07 am    Post subject: Reply with quote  Mark this post and the followings unread
It took a while for the sound to come in to focus for some reason. What I hear sounds like a sample of someone going "showmff" into a vocoder (one with a working unvoiced detector).
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Mon Aug 14, 2006 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Perhaps a downpitched sample of a vocoder perhaps? I'll try some stuff out...
Thanks for the ideas guys Very Happy
astroid power-up!
PostPosted: Mon Aug 14, 2006 10:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah sounds like someone's mouth to me, too.
Astroid Power-Up!: "googleplex" available at:
http://cdbaby.com/cd/googleplex
Axiom
G2 patch files: 28
PostPosted: Tue Aug 15, 2006 12:19 am    Post subject: Reply with quote  Mark this post and the followings unread
seems a filtered drumloop to me... anyways, you can get a similar sound with a noise through a lowpass with sequenced cutoff.
Luca
Posted Image, might have been reduced in size. Click Image to view fullscreen. Posted Image, might have been reduced in size. Click Image to view fullscreen.
suthnear
PostPosted: Tue Aug 15, 2006 12:22 am    Post subject: Reply with quote  Mark this post and the followings unread
fwiw, it sounds like two sounds to me: a fairly standard multi-osc lead sound doing the (minor) chord and a filtered noise bit over the top. The key to the chord sound is an element of detune: so it's either multi-oscillators slightly detuned, a chorus unit or unison. Or, as others have suggested, a vocoder. Just use noise as the source. It's difficult to say exactly which because the second sound is masking the first a bit. The sound is also filtered through a fairly closed LPF and there's definitely some envelope on it - a fairly slow attack, gentle release. It's the chord that provides the 'show' component.
The second sound is noise through a resonant LPF (or fairly wide band pass - I'm not sure if it's the noise colour or the filter that is removing the lower frequencies) and it's the filter movement on this that's providing the shape, the 'mff'. Particularly, the sound is played with the filter closed, slightly before the chord and the filter is opened into that sound (if you know what I mean). There's delay on it, too.
I am sure I could do this on the g2, but all my gear is packed up at the moment because the floor is being repaired. If I have some time tonight I'll install the editor on my work laptop and see if I can match it for you and provide a patch.
suthnear
PostPosted: Tue Aug 15, 2006 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok, here's a rather quick go at it. I used the arp bass preset plus I added a filtered noise source: ideally they should be two separate patches (I inserted a delay module to give an idea of the effect) - so the noise is only doing the "sh" and not the "ff" as well.
Unfortunately I couldn't listen at the same time as build (I only have one pair of headphones here) but playing an Abm triad it sounded fairly close. It's a very similar sound to the one vibrasphere use in their track 'landmark' so I may have been influenced a little in that direction rather than the one in the clip Smile
somewhatshowmff.pch2
 Filename:  somewhatshowmff.pch2
 Filesize:  4.45 KB
 Downloaded:  1521 Time(s)
sheridan
Audio files: 27
PostPosted: Wed Aug 16, 2006 7:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Personally, I don't think vocals were used although there could possibly be a vocoder used on the noise element of the sound. I think Suthnear is on the right track.
It sounds to me that the lower, bassier part of the sound is not 'in tune', ie. maybe it uses low amounts of FM or large amounts of detune (5 or 7 semitones?) to get the fullness that it exhibits. As for the noise element, is the 'mffff' even part of the sound, or is it separate, but similar sounding - it is panned to a different place and not panned across from the place the 'shhhh' comes from either?
It could just be a sampled waveform though... didn't Orbital love using their Korg M1 (or was it Z1) back in those days?
transformer Sheridan
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Wed Aug 16, 2006 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
suthnear - Thanks for that patch. It's definitely a noise source and a synth of some kind. I haven't had a chance to play around with a vocoder with a proper unvoiced detector like g2ian said, but I think if I feed a sound similar to your patch (minus noise) into it and go "showww" into the mic it may sound similar.
Sheridan - You're right, the ff part isn't actually part of the showmff sound. The showm is spread across the speakers, but the ff is centered.
