monads
Joined: Oct 12, 2005 Posts: 115 Location: electroland
Jari Jokinen
Posted: Sat Jan 19, 2008 6:14 am Post subject:
Impressive setup!
I wouldn't mind some brief examples from NS-4. Especially, what kind of smooth random output can it make.
Jari Jokinen |
monads
Posted: Mon Jan 21, 2008 6:26 am Post subject:
| Jari Jokinen wrote: | | Impressive setup! |
| Jari Jokinen wrote: | | I wouldn't mind some brief examples from NS-4. Especially, what kind of smooth random output can it make. |
Well I recorded some samples for you tonight. They're all running through the MMF on the S1.
1st one is just noise as follows (MMF on S1 Open all the way):
S1 White, NS-4 White, S1 Red, NS-4 Red, NS-4 Pink. The 'Red' sounds different and deeper/lower in tone on the S1.
2nd sample is the S/H from the NS-4 (w/some reverb added, MMF on S1 about half way Open). This is feeding the Cutoff of the MMF. I took 2 oscillators from the S1 and used them to drive the Rate & Lag CV on the NS-4. I then adjusted the knobs on the NS-4 to taste. Only 1 oscillator (sawtooth) was going to the MMF of the S1 and that is what you hear 'changing'.
Let me know what you think. I didn't compress or eq these samples.
monads
| Description: |
 Download (listen) |
| Filename: |
Cwejman Noise.mp3 |
| Filesize: |
715.1 KB |
| Downloaded: |
1536 Time(s) |
| Description: |
| NS-4 S/H with some reverb added. |
 Download (listen) |
| Filename: |
SH.mp3 |
| Filesize: |
2.47 MB |
| Downloaded: |
1625 Time(s) |
Jari Jokinen
monads
Posted: Tue Sep 23, 2008 3:29 pm Post subject:
| I'm just curious, but has anyone else purchased the rack for use with their Cwejman modules? |
tompty
Posted: Tue Sep 23, 2008 4:45 pm Post subject:
i am tempted to buy the rack, its beautifull!
however i think im limiting my choices for the future when i want other modules ( well just two i want currently, the malgorithm and zeroscillator ). |
Cat-A-Tonic
Joined: Mar 24, 2008 Posts: 42 Location: Yokohama, Japan
Posted: Wed Sep 24, 2008 7:34 pm Post subject:
Awesome Setup!
How does the 3 Band Parametric EQ compare with the Quad Resonator? |
monads
Posted: Fri Sep 26, 2008 10:03 am Post subject:
| Cat-A-Tonic wrote: | Awesome Setup!
Thanks Cat! They have their similarties. They both have the same frequency range. With the RES-4 you do get that extra band and the Notch output. It really depends on what you want to do. You can really dial in frequencies with the VCEQ-3.
You need another module to take advantage of the FREQ, BW, LEVEL inputs on both modules. Either the D-LFO or another favorite the PH-4. |
