SOUNDLAB koopasynth!
Page 2 of 2 [33 Posts]
Goto page: Previous 1, 2
Wild Zebra
PostPosted: Fri Apr 06, 2007 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm gonna make this go all over the place. superkoopa, awesome work man nice combo, nice songs. I should be getting my paia theremax today (I hope) And I always wanted to get into ham mosc and bruce, but don't know where to start. I have a cobra 29 xlr in my truck (got it at the thrifty for 10 bucks) barefoot so I don't get out too much, but I heard I could squeeze some juice out of it. Everyone just pretty much gives me a hard time. I can't even find anyone to peak and tweak the sucker. It's kinda the opposite of here, if your new and not on the ins seems like everyone just keeps you at bay. Instead of helpin out trying to find a better radio they just say "get a better radio if ya wanna run with the big dogs" hahahha
"your stripes are killer bro"
sohcahtoa
PostPosted: Sun Apr 08, 2007 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Amazing Soundlab,
A few questions:
1. You said you integrated a microphone input, how did you connect this up?
2. Did you do the Gate modification for the Theremin?
3. Are you running it off of +12 - 12 Volts?
4. Where did you get the tubes for the Theremin?
once again awesome work, and a great video.
SuperKoopa
PostPosted: Mon Apr 09, 2007 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
sohcahtoa Posted: Yesterday, at 5:11 pm Post subject:
Amazing Soundlab,
A few questions:
1 If you look at the original guitar trigger schematics, there is a spare op amp of the LF444. I've used this in series with the guitar trigger input as a x100 inverting amplifier.
2 No ,i didn't. in the video I use the pitch CV output as gate source (if you look at the video you can see that i use my right hand to trigger the sounds and the left to change the VCF frequency)
3 yes.
4 no tubes , it's a PAIA theremax ,for more informations go to : http://paia.com/theremax.asp
Good luck, Bye!
sohcahtoa
PostPosted: Tue Apr 10, 2007 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I meant to ask where you got the antenna not the tubes sorry.
Did you pick them up at a local hardware shop or buy them from a store?
SuperKoopa
PostPosted: Tue Apr 10, 2007 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing Ok!
tubes = Electronic valves but also =home-made antennas!
It was very hard to find those pieces of tubes. On every theremin-related forum, like thereminworld.com ,everyone says that the best solution is 3/8" tubes (used for oil pumps , air conditioning...) and compression fittings.
3/8" tubes seems unavailable in italy so i've used 6mm tubes from a local store.The compression fittings seems also disappeared from the face of earth ,so i've used a different fitting, but i can't explain with words how that's is made. Maybe I will post a photo later...
sohcahtoa
PostPosted: Tue Apr 10, 2007 10:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
yea, that would be great.
I bet the inside of you theremin is a rats nest!, post some more videos too if you get the time.
SuperKoopa
PostPosted: Wed Apr 11, 2007 4:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is some pics of my antennas and fittings and a wiew on the rats nest Cool
Antenna fittings
 Filesize:  41.91 KB
 Viewed:  5533 Time(s)
 Filesize:  43.51 KB
 Viewed:  5548 Time(s)
the rats nest
 Filesize:  470.35 KB
 Viewed:  5537 Time(s)
sohcahtoa
PostPosted: Thu Apr 12, 2007 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
ahh... a Delay circuit I was thinking about putting one of those on board the synth. I was going to go with an echo circuit, for the theremin here is a link to what I was thinking about.
http://www.generalguitargadgets.com/forums.html?option=content&task=view&id=48&Itemid=80
