today> Cancelled - Sorry Chez Mosc
Thomas Henry's SN76477 Super Controller Module
Page 5 of 10 [232 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 Next
Is there an interest in Super Controller PCBs?
Yes, by all means.
95%
 95%  [ 23 ]
No, it just doesn't cut the mustard, i think.
0%
 0%  [ 0 ]
I don't know. I mean, i... er...
4%
 4%  [ 1 ]
Total Votes : 24
Tim Servo
PostPosted: Thu Jul 05, 2007 10:47 am    Post subject: Thomas Henry's SN76477 Super Controller
Subject description: PCB Layout
fonik wrote:
so here is the final version. as you might want to recognize: i added standard MTA.100 footprints for almost all potentiometers, switches and jack sockets. the boards size is 4.7 x 3.3 inch (120 x 84 mm). i will post some sound samples later this day.
Hi Fonik,
I had a couple of questions / comments. First off, it looks like you added .100MTA connectors for the pots and switches, but you should try to orient MTA connectors so that the polarizing tab is away from the outer edge of the board. For example, P3 is "backwards." It will still work just fine, but it doesn't really adhere to industry standards. However, that won't keep it from working, so I wouldn't worry too much about that one. Looking at M8, 9, 6 and 11 though, these won't work with the AMP connectors. The .100 Molex connectors are available with crimp pins that allow the wire to come out the top of the connector, but the AMP MTA connectors are an "IDC" style and require that the wire come out the front or back side. As you have these connectors placed, they are all front to back and the wires won't fit. Again, this is only a problem with the AMP connectors, but I like these because they are quicker to put together and are more robust since they don't rely on a separate crimped connection to the contact pin. For a better illustration of how the wires come out of the AMP MTA connectors, take a look at the Synth.com page at
http://www.synthesizers.com/technical.html
About 3/4 of the way down the page, you'll see some pictures accompanying the description of "6 pin MTA" and "2 pin MTA" connectors.
Am I making sense here? Again, there's nothing here that will keep the board from working, but it will be a little more difficult to wire up. Let me know if I'm rambling or being just plain stupid here (it's happened before), but I just thought I'd throw my $0.02 in.
Tim (oh wait, all I have is $0.01) Servo
PostPosted: Thu Jul 05, 2007 1:57 pm    Post subject: Re: Thomas Henry's SN76477 Super Controller
Tim Servo wrote:
...Am I making sense here? Again, there's nothing here that will keep the board from working, but it will be a little more difficult to wire up....
many thanks for the advice, tim. we all are here to learn and too help each other and i am certainly one of those, who have to learn more than others!
actually i wanted to do the layout just according the good old DIY wiring method: a lot of single wires from many different points of the board. but then i tried to do it a little bit better. thanks to your suggestions i will hopefully do just a little bit more better before sending the files to the manufacturer (still not perfect). i will see what i can achieve the next days. i definitely don't want the board to get much larger.
so again many thanks. your comments are highly appreciated.
PostPosted: Thu Jul 05, 2007 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
i made some short samples tonight. they are uncut, just 5min playing around. i used the TH SN Super Controller Module, the TH SN-voice as oscillator and the baby10 instead of a keyboard, which does not matter.
so here some noise. there are three different noise timbres provided by the SCM. the sweep is modulated by the internal LFO, the filter is manually fiddled:
http://www.modular.fonik.de/sound/SCM/noise1.mp3
http://www.modular.fonik.de/sound/SCM/noise2.mp3
http://www.modular.fonik.de/sound/SCM/noise3.mp3
then the LFO modes. first the gated LFO triangle, then gated LFO square and at last a delayed LFO (the trigger comes with each deep note):
http://www.modular.fonik.de/sound/SCM/gatedLFOtri.mp3
http://www.modular.fonik.de/sound/SCM/gatedLFOsqr.mp3
http://www.modular.fonik.de/sound/SCM/delayedLFOtri.mp3
last but not least the s/h. noise1 fed into the s/h, then playing around with noise sweep and filter:
http://www.modular.fonik.de/sound/SCM/SHnoise1.mp3
bambam
PostPosted: Thu Jul 05, 2007 5:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great samples Matthias Wink
Can't wait to get my hands on a couple of pcb's and get building!
Well done on getting this together.
Brett
bubblechamber
PostPosted: Thu Jul 05, 2007 9:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
sounds great. put me down for 2. thanks.
David
PostPosted: Fri Jul 06, 2007 1:33 am    Post subject: Reply with quote  Mark this post and the followings unread
did some minor changes in the layout according to tim's suggestions. check the 1st post for screenshot.
Scott Stites
Audio files: 96
PostPosted: Fri Jul 06, 2007 8:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great samples, Fonik!
Don't forget I'm one of those guys that wants a board..... Very Happy
Scott
My Site
PostPosted: Fri Jul 06, 2007 9:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great examples of the Super Controller. The S/H example is a good demonstration of a key feature. Very Happy
Bill
kryptic
PostPosted: Sun Jul 08, 2007 11:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great samples. You can put me down for two boards also, please.
goodrevdoc
PostPosted: Mon Jul 09, 2007 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
put me down for one, fonik
-justin
HPL
PostPosted: Mon Jul 09, 2007 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Fonik
now im also here.
wanna get one too.
SolderSmoke
PostPosted: Wed Jul 11, 2007 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Fonik!
One for me too, please!
Randaleem
PostPosted: Wed Jul 11, 2007 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Fonik,
Me too, one please!
Randal
factus10
PostPosted: Wed Jul 11, 2007 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd love one!
PostPosted: Wed Jul 11, 2007 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
i still take advance orders until 12 JUL 2007, 10:00 UTC.
I did ask for one didn't I?
ACHTUNG!
fluxmonkey
PostPosted: Wed Jul 11, 2007 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
likewise--i requested one when these were first being discussed... i am still interested.
bbob
krellmusician
PostPosted: Wed Jul 11, 2007 9:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd like one board, please.
PostPosted: Wed Jul 11, 2007 11:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
bbob
@bbob & v-un-v
i considered everybody who said he had interest. so you both are on the list...
i simply have not had the time to send a confirmation to everybody this time, sorry.
Scirocco
PostPosted: Thu Jul 12, 2007 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I want 2 boards, Is it still posible?
Have a nice day Very Happy
http://www.flickr.com/photos/monocapa/
PostPosted: Thu Jul 12, 2007 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
it is. you are on the list.
@all
i will be on vacation for the next two weeks, so don't wonder if i won't answer then...
Scirocco
PostPosted: Thu Jul 12, 2007 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice !
Good vacation fonik !
PostPosted: Sat Jul 28, 2007 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
i am back from vacation and found the PCBs in the mail. i will test one next week and i will still have to do that documentation!
that's how the PCBs look like:
philpeery
PostPosted: Sat Jul 28, 2007 7:22 am    Post subject: Super controller pcb looks great! Reply with quote  Mark this post and the followings unread
Hi Fonik,
Are you looking for beta testers? I'd be glad to, and have all the parts all ready to go! I'd love to have three right now!
Regards,
Phil
Dan Lavin
Audio files: 21
PostPosted: Sat Jul 28, 2007 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Fonik,
Excellent work!
Phil,
don't you have enough to do?!
Scott Stites
Audio files: 96
PostPosted: Sat Jul 28, 2007 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice to have you back Mr. Matthias Very Happy
Board's lookin' good too.
Scott
My Site
