How do I seed correctly?
Page 1 of 1 [7 Posts]
torsig1967
PostPosted: Fri Jun 27, 2008 3:29 am    Post subject: How do I seed correctly? Reply with quote  Mark this post and the followings unread
Which is the most economical way to correctly seed the clocked random generators?
I want to get get a different value on the seed input every time I load the patch.
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Fri Jun 27, 2008 4:09 am    Post subject: Reply with quote  Mark this post and the followings unread
As far as I know, you get a random seed on patch load if you don't connect anything to the seed input. If you want a repeatable set of values, you have to patch a constant value and use the reset input.
torsig1967
PostPosted: Sat Jun 28, 2008 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, thanks. I thought it was the other way round.
Roland Kuit
G2 patch files: 125
PostPosted: Sat Jun 28, 2008 3:06 am    Post subject: Reply with quote  Mark this post and the followings unread
pattern seed. cheers:) but with no changes when you load the patch.
random trig example 114.pch2
pattern seed example
 Filename:  random trig example 114.pch2
 Filesize:  2.16 KB
 Downloaded:  539 Time(s)
Roland Kuit
http://rolandkuit.com/
Roland Kuit
G2 patch files: 125
PostPosted: Sat Jun 28, 2008 3:53 am    Post subject: Reply with quote  Mark this post and the followings unread
more complicated one
random trig example 115.pch2
 Filename:  random trig example 115.pch2
 Filesize:  4.05 KB
 Downloaded:  611 Time(s)
Roland Kuit
Audio files: 116
G2 patch files: 317
PostPosted: Sat Jun 28, 2008 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Didn't know that ... experimented a bit and it works Cool
When you want it to give you a single random value that's different at each startup you'll need a single clock pulse on the random module from f.i. a constant module set to a value > 0. Without any clocks the startup value will be the same at each startup.
PostPosted: Sat Jun 28, 2008 9:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wouldn't that still give you the same result every time at G2 startup if the patch in question is auto-loaded at that point?
I think the one source of real randomness you have is resistor-noise from the ADC's. I'd seed based on that, a short while (few ms should do it) after patch-load, the wait is to hopefully get rid of any bias that might be there caused by voltage spikes/fluctuations that might be occurring at startup-up.
AmbiphonicDSP
