The Karplus Strong eChucK DIY Project
Page 23 of 24 [577 Posts]
Goto page: Previous 1, 2, 3, ..., 21, 22, 23, 24 Next
Ayab
PostPosted: Sun Jan 03, 2016 7:47 am    Post subject:
Subject description: Karplus Strong Project
CreatorLes
Best wishes for a healthy and happy 2016 (and to all on Electro-Music).
Thank you for your work on such an interesting and creative project. I would really like to experiment with this synthesis method. Do you have any pcb's available or are you planning another run?
I would also be interested in the 'brick'
All the best
Ben
CreatorLes
PostPosted: Thu Jan 14, 2016 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've been out of the loop so long i forgot.
Les
masterofstuff124
PostPosted: Mon Jun 20, 2016 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
pcbs? or the most up to date files so i can get the some boards made?
masterofstuff124
PostPosted: Tue Jul 26, 2016 9:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
alright built one of these up. any one have any idea what the correct values of r27 and r32 are for 12v power supply? any other necessary changes?
my FBk knob and VCF knob both dont seem to do all that much.
I replaced both r11- 40.2k and r18 49.9k with 47k. and C7 with 2.7n
only 2 2k tempcos for the tranny pairs? I also flipped both of the 2n3906's backwards as mentioned earlier in the thread.
Should I bring all the labelled points on the board to jacks? sum, vol,jls etc...
should feedback send be normalled to fdbk jack? i.e. connected to its switch lug? with attenuator?
different styles of triggers seem to drastically change the tone which is neat!
anyone have any switching ideas for the different kinds of chips?
any other switching ideas. like infinite feedback, or changing out the tone caps in the loops etc...
Lots of questions. I know. really keen on this circuit!@ my first vco so my knowledge is lacking.
PostPosted: Tue Apr 04, 2017 10:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Les's Karplus-Strong circuit sounds really, really good!
I had a good fiddle with it today, and the Stim input is vital to getting good sounds out of this circuit. I tried a saw wave into the Stim input, and was getting rather insane sounds, so I googled "karplus-strong synthesis".
Noise is what needs stimulating. Modulated noise. The longer the envelope, the more "breathy" and panpipe-y it sounds.
This is what I worked up from Les's excellent schematic. Didn't have to do any patches due to stupidity on my own part, so that's always a plus. Hopefully Les doesn't mind my putting his name on the front, or E-M!
Thanks for making this circuit public, Les.
BlacKcaT
PostPosted: Wed Apr 05, 2017 4:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked nice!
I'm wondering if are still there some pcb to buy...
masterofstuff124
PostPosted: Wed Apr 05, 2017 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
AlanP you need to start selling all your pcb/panel designs. everytime I see one I immediately want it....
i want this....
Shocked
BlacKcaT
PostPosted: Wed Apr 05, 2017 8:10 am    Post subject: Reply with quote  Mark this post and the followings unread
i want this....
Shocked
this is herorack addiction !
Inventor
Audio files: 267
PostPosted: Thu Apr 06, 2017 1:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh man, I just found this - I feel so joyful to have my name on your version of the KS! This really made my day, and the PCB looks rock solid primo grade A extra fine!
I gotta stress that this was a community project and lots of people helped. Without that help I never could have done it! I even quit it just before it was complete and folks pitched in to carry it to fruition.
Now if you can fabricate it and breathe new life into the project, well, nothing would make me feel better than that (well not much!). Enjoy to the max.
Les
p.s. I'll pay for two built boards with panels if I can afford it, would love to set up a "brick" again as it made IMHO the best sounds I ever made at em.
Audio files: 227
PostPosted: Thu Apr 06, 2017 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Congrats, Alan. I'm almost as happy as Les on this. Putting electro-music.com on your front panel is great too. Splendid work. Got any recordings of this module?
YashN
PostPosted: Fri Apr 07, 2017 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks so neat, well done Alan & Les and others.
How's the faceplate labelling done?
PostPosted: Sun Apr 09, 2017 3:24 am    Post subject: Reply with quote  Mark this post and the followings unread
looks fantastic Alan Smile
i still have my KS built using the first Les pcbs from 2010/11 http://electro-music.com/forum/phpbb-files/thumbs/t_ks_working_in_the_modular_190.jpg
bringing those aux send & return to normalised panel jacks is a must have, i found an fx pedal (delay/chorus/flanger etc.) in the loop makes great noises.
great build Alan Smile
PostPosted: Mon Apr 24, 2017 12:23 am    Post subject: Reply with quote  Mark this post and the followings unread
A quick mess-around shows that this can also be used as a flanger (at least, with the 3207 BBD I currently have in it.)
Signal into Stim, LFO into VCO CV. Turn Feedback to minimum first. Freq is now Manual, VCO CV Level is Depth. Once you've got a good flange-y thing, try adding a bit of feedback.
PostPosted: Fri Sep 15, 2017 6:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Did some very quick ear-testing with some modern BBD reproductions from Smallbear, with this circuit.
The Bei-Ling BL3207 sounds very good in this, not much noise, good range with the Freq knob to get a relatively wide range response.
The Coolaudio v3208, on the other hand, sounds dreadful. Noisy. The lowest frequency is higher than the BL3207, and the highest frequency is lower. I have some Coolaudio v3205d chips lying around but, with how noisy they are in a Memory Man clone I have, and how noisy the v3208 was, I decided not to bother perfing up an adaptor board.
I have a suspicion that this has something to do with the relative simplicity of this circuit -- no compander is used, relatively light filtering, meaning that lower quality BBDs don't quite cut it. The good thing is that Smallbear has the Bei Ling chip in decent quantities.
chaffel3
PostPosted: Fri May 31, 2019 10:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I ordered pcbs and parts for the KS11, way cheaper than I thought! Big thanks to Les for making an awesome DIY project!
chaffel3
PostPosted: Wed Jun 19, 2019 7:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm getting really close to finishing a build but I'm not able to adjust VCO frequency and the filter isn't having any effect.
I'm building it into a eurorack module so I'm using +- 12 volts on the supply, what resistor are people using for r27 and r32? I think the original 14.3k is for 9 volts if I'm not mistaken. I installed trimmers but haven't had any luck experimenting.
What am I looking for in terms of observable behavior when I have r27 and r32set right? (I have an O scope if that's helpful)
One big hint is that the TL074 is getting pretty warm so I'm looking around that for clues how to proceed.
Thanks all!
PostPosted: Wed Jun 19, 2019 8:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
If an opamp is warming up like that, then you've got a short somewhere, or a wrong value component.
If you have an o'scope, then put a continuous waveform into the Stim input, and trace through the circuit until you find where it stops being passed on. My guess would be that it will be somewhere in the opamp that is heating up. (The bias for the BBD in this circuit is ultra-simple, so it should be fine.)
I just used the stock resistor values for my 12V build.
chaffel3
PostPosted: Sun Jun 30, 2019 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've decided to start a new build on a fresh pcb so I can verify it at every step, I also am now using a variable power supply so I can give it +-9. I just re-read the whole thread and flipped my Q2 transistor around, now trying to nail down resistor values.
I have a scope on the TP5 test point (OCV) which is the output of the op amp that feeds to the transistors. The range I'm seeing adjusting the frequency knob is -0.15 to 0.2 volts. From someone earlier in the thread their range was 0.167V to -0.163V which sounds similar enough, might be able to figure out how to make it symmetrical around 0 volts.
At test point 16 (OCC) which is the point right after the transistor stage I'm seeing a range of about -7.9 to 0 by adjusting the freq knob. The trimmer has a minor effect around the middle of the range but minimum and maximum are unaffected. Someone else posted that they had -4.32V to -8.13V. At about 6 oclock way the voltage is near 0 and the rest of the rotation of the freq pot doesn't have any effect.
I had a wrong resistor value messing up my level shifter but I fixed that and I have a decent clock coming out of the level shifter, it could be a more even pulse width but it seems fine.
I'm going to build the rest of board #2 and see if my op amp overheating happens again, this time I'm more prepared to diagnose.
I have learned a lot so far it's been fun!
chaffel3
PostPosted: Fri Jul 05, 2019 4:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got my second build working and I'm super excited! Works well at +-9V and +-12, calibration is the last thing I need to do. I have another couple PCBs and I'm planning on building them eventually. Maybe I'll do 3 to make a power chord polyphonic set someone mentioned in the thread.
Now that I have a known working board I can retest the voltages on my first one. I'm finding a mysterious voltage of VDD on two of my op amp pins (1 and 2) which should be near zero, which must explain the overheating I am encountering. I have the op amp unplugged from the board so it should have any significant voltage. It is somehow related a current path through the 100 ohm pot so I'll be investigating all those paths to VDD.
I have basically memorized the schematic at this point. I feel like I have learned a lot about CV input and 13700 Oscillators which has really given me confidence in planning some of my own designs in the future!
Audio files: 227
PostPosted: Tue Jul 30, 2019 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
chaffel3 wrote:
... I feel like I have learned a lot about CV input and 13700 Oscillators which has really given me confidence in planning some of my own designs in the future!
This makes me feel great, and I’m sure Les feels the same. This is one of the reasons we started electro-music.com some 16 years ago. We support, encourage, inspire, and appreciate each other. (Other things too.)
Congrats on getting things working.
Inventor
Audio files: 267
PostPosted: Fri Aug 02, 2019 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Aw... Warm fuzzies and cool breezies all around!
Les
jean bender
PostPosted: Sun Nov 15, 2020 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Please see this page:
http://echuck.othomann.de/eChucK/eChucK.html
For the eChucK website that wmonk has kindly offered to host for me. It has KS info and documentation, so have a look.
Les
Ok, so 10 years after, i'm finding back my pcbs used for a specific project.. Wow, it's been a while.
I'd like to rebuild my units, but i can't find back the documentation i used by the past.
Inventor's website seems to be dead, and i remember i used it helping me building my karplus..
Anybody would have any idea how to find back this site ?
Or would somedbody help me tuning the several trimpots used ?
Thanks a lot !!
http://h.a.k.free.fr/
www.electroncanon.org
PostPosted: Sun Nov 15, 2020 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is what I have
 Filesize:  421.5 KB
 Viewed:  253 Time(s)
ks jack.pdf
 Filename:  ks jack.pdf
 Filesize:  26.31 KB
 Downloaded:  220 Time(s)
ks v0.2 eng.pdf
 Filename:  ks v0.2 eng.pdf
 Filesize:  27.57 KB
 Downloaded:  678 Time(s)
my synth
jean bender
PostPosted: Mon Nov 16, 2020 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi !
Thanks for you repply !
But sadly my boards don't seem to be the same batches. I have two trimmers on it, and can't find back how to calibrate them...
So sad to not have grab inventor's website.. i know that's not cool, but it seems there are so many down diy websites actually..
I will try to post some pictures from my boards.
Best
J.
PostPosted: Mon Nov 16, 2020 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe you can find the website you are looking for in the wayback machine?
https://archive.org/web/
my synth
