  bingsatellites Mostly Ambient
 Forum index » DIY Hardware and Software » Rob Hordijk DIY Designs
Zeitgeist Schematics
Post new topic   Reply to topic Moderators: Rob
Page 1 of 1 [15 Posts]
electri-fire
G2 patch files: 4
PostPosted: Wed Nov 25, 2009 9:48 am    Post subject: Zeitgeist Schematics Reply with quote  Mark this post and the followings unread
I asked for the Zeitgeist schematics, but....
Edit: I just remembered Rob mailed them to me. As he also posted the Benjolin schematics I presume he won't mind me posting the Zeitgeist.
 Filesize:  111.69 KB
 Viewed:  627 Time(s)
 Filesize:  72.5 KB
 Viewed:  316 Time(s)
ZeitgeistSchematic.pdf
 Filename:  ZeitgeistSchematic.pdf
 Filesize:  34.07 KB
 Downloaded:  953 Time(s)
Ginsengbob
PostPosted: Mon Jul 04, 2011 12:59 pm    Post subject: This May be a stupid question but...... Reply with quote  Mark this post and the followings unread
How can you use the board graphic for making a pcb when it's got the component graphics on it like that?
Thanks
CJ Miller
PostPosted: Thu Mar 15, 2012 5:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I noticed a small error on the schematic diagram. It has C9 - pin 9 on the delay chip - as 9100nF. Looking at the overlay and photo here it appears that the extra 9 is a typo, it should probably be 100nF.
Ginsengbob
PostPosted: Fri Mar 16, 2012 10:43 am    Post subject: Seriously Reply with quote  Mark this post and the followings unread
On the Benjolin post there is a graphic with the components and a graphic for using a transfer with no components to print on the transfer paper.
Is there something I'm missing?
Please tell me.
Thanks
PickNick
PostPosted: Sun Mar 18, 2012 9:21 am    Post subject: Reply with quote  Mark this post and the followings unread
i'm still not sure what kind of regulator is 1702...
mcp1702?
can i use 7805?
Allow theex.nl
inlifeindeath
PostPosted: Sun Mar 18, 2012 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
mcp1702?
can i use 7805?
yes, it's just a 5v line for the delay chip. 7805 work fine.
PickNick
PostPosted: Mon Mar 19, 2012 7:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
great news!
thanks mate!
Allow theex.nl
tokyomatik
Audio files: 6
PostPosted: Tue Apr 23, 2013 8:28 pm    Post subject: Re: Seriously Reply with quote  Mark this post and the followings unread
Please tell me.
Thanks
so? no pnp transfer layout?? Sad
xiwi
PostPosted: Sat May 18, 2013 6:59 pm    Post subject: Re: Seriously Reply with quote  Mark this post and the followings unread
Please tell me.
Thanks
This might be sacrilege, but I'm currently working on an alternate PCB layout for the Zeitgeist with external pots and jacks. Here's an image. Not making it fully available yet, as I haven't had the time to confirm that it's working perfectly.
http://imgur.com/1TLzkLx
tokyomatik
Audio files: 6
PostPosted: Sat May 18, 2013 7:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
i already feel better Cool
Dogenigt
PostPosted: Sun May 26, 2013 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi can anyone tell me what these potentiometers on Rob's board is called? I often need ones this size!
And can anyone explain the 10 pin connector for the jumper if I wanted to make one myself?
www.dogenigt.com
LFLab
PostPosted: Sun Jun 02, 2013 1:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Those are 9mm pots, several manufacturers make them, Alpha too.
Just need to specify that you want vertical mount.
boundlessFX
PostPosted: Tue Jun 11, 2013 12:20 am    Post subject: n00b question Reply with quote  Mark this post and the followings unread
What exactly are the components labeled "HDR_3"? I recognize everything else and have most of it on hand, but I've never seen these before. Are they some type of transistor?
inlifeindeath
PostPosted: Tue Jun 11, 2013 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
They are headers, you can just use hookup wire.
boundlessFX
PostPosted: Wed Jun 12, 2013 6:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awesome. Thanks!
mps board
