RYO 3x VCA - Stripboard layout help
Page 1 of 2 [41 Posts]
BlacKcaT
PostPosted: Sun Jan 14, 2018 4:39 am    Post subject: RYO 3x VCA - Stripboard layout help Reply with quote  Mark this post and the followings unread
Never done a stripboard layout from schematics. I know there are some free sw for it, but dunno where to start. Is there any of you so kind to help me with this?
http://ljunggrenaudio.com/products/3XVCA/3xVCA%20schematic%201.0.gif
I'm looking to do that on stripboard and put in my eurorack.
Hope this insn't unfair, since the schematics are online, and I only want to build one or two for my system.
Any help is much appreciated!
EDIT: If you are going to build this one, please read all the 3ad in order to follow alla the changes made at the project. Many thanks to Nardu, who made the job!
gabbagabi
PostPosted: Mon Jan 15, 2018 1:17 am    Post subject: Reply with quote  Mark this post and the followings unread
there is a demoversion of "Lochmaster"
https://www.electronic-software-shop.com/forums.html?seo=demo-versionen
in the demoversion u cant save ur drawings, but u could do screenshots
cheers
ps. : why triple vca? it leaves one half of the 13700 unused, may make it 2x2?
khakifridge
PostPosted: Mon Jan 15, 2018 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
If you're looking for software, then check out DIYLC. Good for vero, perf and PCBs.
BlacKcaT
PostPosted: Mon Jan 15, 2018 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
cheers
Thanks for the reply g.gabba,
I'm not able ATM to develop a new schematic for a 2x2, so I'm trying to draw a stripboard layout for this tested one
gabbagabi
PostPosted: Mon Jan 15, 2018 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
in every of the 3 VCAs in the schematic is written Ljunggrenaudio.com
just leave the one on the bottom out
so u will use one LM13700 and two tl074 to build two VCAs
BlacKcaT
PostPosted: Mon Jan 15, 2018 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! I'll check it Smile
BlacKcaT
PostPosted: Mon Jan 15, 2018 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Fairly simple Embarassed
gabbagabi
PostPosted: Tue Jan 16, 2018 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy in bocca lupo per il progetto
Nardu
PostPosted: Tue Jan 16, 2018 5:08 pm    Post subject: RYO 2X VCA Reply with quote  Mark this post and the followings unread
A stripboard version for 2X VCA 64x92mm. Almost finished.
I used LochMaster - http://www.abacom-online.de/uk/html/body_lochmaster.html
RYO 2X VCA stripboard version with LochMaster software
 Filesize:  119.87 KB
 Viewed:  858 Time(s)
http://nardusynth.blogspot.ro/
BlacKcaT
PostPosted: Wed Jan 17, 2018 5:08 am    Post subject: Reply with quote  Mark this post and the followings unread
@nardu ! This is great! Thank you so much for this! I'll check it Razz
Nardu
PostPosted: Wed Jan 17, 2018 6:29 am    Post subject: RYO 2X VCA Reply with quote  Mark this post and the followings unread
Not finessed !
Here with potentials
I used IC2, IC5, but with the pins renumber. Pins IC3 are the same.
Instead of D1,D2,R1,R2,C1,C2,C3,C4 I have used 2 ferrite bead. I will complete pcb with this pieces too.
RYO 2X VCA stripboard version with LochMaster software. Potentials
 Filesize:  302.16 KB
 Viewed:  547 Time(s)
gabbagabi
PostPosted: Wed Jan 17, 2018 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
i posted here (page4)
http://electro-music.com/forum/post-432536.html#432536
how to make a pcb with lochmaster
may u want to do so?
btw, nice work
always a good feeling to see people designing and sharing
Nardu
PostPosted: Wed Jan 17, 2018 9:01 am    Post subject: Reply with quote  Mark this post and the followings unread
@g.gabba, I use for pcb design Sprint-Layout 6.0 from Abacom http://www.abacom-online.de/uk/html/body_sprint-layout.html .
It's simpler and more productive. Export Gerber files, Drill data (Excellon), Isolation milling (HGPL, .plt), bmp, jpg, gif, emf. Print all layers with option.
All you need to produce DIY pcb; press&peel, toner transfer, CNC milling, plotter, PCB manufacturing... China!
Here is an example
Silkscreen & bottom pcb
 Filesize:  83.98 KB
 Viewed:  481 Time(s)
Photo view with solder mask, like real
 Filesize:  163.82 KB
 Viewed:  521 Time(s)
Nardu
PostPosted: Wed Jan 17, 2018 2:30 pm    Post subject: RYO 2X VCA - Front panel Reply with quote  Mark this post and the followings unread
Front panel idea 4HP EuroRack
 Filesize:  12.87 KB
 Viewed:  25929 Time(s)
RYO 2x VCA-4HP_eurorack.pdf
 Filename:  RYO 2x VCA-4HP_eurorack.pdf
 Filesize:  12.44 KB
 Downloaded:  537 Time(s)
RYO 2x VCA-4HP_eurorack v,2.pdf
 Filename:  RYO 2x VCA-4HP_eurorack v,2.pdf
 Filesize:  12.45 KB
 Downloaded:  516 Time(s)
RYO 2x VCA-2HP_eurorack.fpd
 Filename:  RYO 2x VCA-2HP_eurorack.fpd
 Filesize:  1.11 KB
 Downloaded:  517 Time(s)
RYO 2x VCA-2HP_eurorack v,2.fpd
 Filename:  RYO 2x VCA-2HP_eurorack v,2.fpd
 Filesize:  1.14 KB
 Downloaded:  524 Time(s)
gabbagabi
PostPosted: Thu Jan 18, 2018 12:58 am    Post subject: Reply with quote  Mark this post and the followings unread
hi nardu, iam also using sprint-layout Smile
Do u guys know how the 13700 behaving when the CV is negative?
they just quiet or they get damaged? Since there is no protection against negative CV in the Schematic i could imagine that they just go quiet.
And If they do so u could pimp this dual VCA further to a Ringmod with a switch.
BlacKcaT
PostPosted: Thu Jan 18, 2018 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Nardu,
you are so kind Smile Thank you for sharing all this info and the panels and so on!
This is a nice present for the community !
I've a question about sprint-layout. Is it also possible to draw the schematics, and then let the sw do the p'n'p layout for toner transfer method?
This would be really interesting indeed!
BlacKcaT
PostPosted: Thu Jan 18, 2018 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
nice idea, how you would manage that?
gabbagabi
PostPosted: Thu Jan 18, 2018 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
cv2 input goes to the output of IC2D
and
IN2 input goes to the output of IC5C
so it will be a double switch
ONLY if the anwer is YES to:
Nardu
PostPosted: Thu Jan 18, 2018 5:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
please reformulate the question
gabbagabi
PostPosted: Fri Jan 19, 2018 12:10 am    Post subject: Reply with quote  Mark this post and the followings unread
i guess he meant something like the partplace & autorouter function- which sprint-Layout does not have
BlacKcaT
PostPosted: Fri Jan 19, 2018 2:38 am    Post subject: Reply with quote  Mark this post and the followings unread
oh, sorry I was unclear ...
I was meaning if it is possible from schematics to have components layout and traces.
For example, from this:
to this:
this way I can use toner transfer method for make my pcb
thanks
Nardu
PostPosted: Tue Jan 23, 2018 10:55 am    Post subject: Stripboard version for 2X VCA 76x92mm Reply with quote  Mark this post and the followings unread
Stripboard version for 2X VCA 76x92mm. Is not like the original scheme
All you need here - RYO 2x VCA stripboard.zip
 Filesize:  203.6 KB
 Viewed:  469 Time(s)
 Filesize:  250.68 KB
 Viewed:  490 Time(s)
 Filesize:  197.59 KB
 Viewed:  499 Time(s)
All you need
 Filename:  RYO 2x VCA stripboard.zip
 Filesize:  425.36 KB
 Downloaded:  543 Time(s)
RYO 2x VCA-2HP_eurorack v.2.1.fpd
modified front panel, gap between holes, inches
 Filename:  RYO 2x VCA-2HP_eurorack v.2.1.fpd
 Filesize:  1.14 KB
 Downloaded:  479 Time(s)
Nardu
PostPosted: Tue Jan 23, 2018 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks
Of course, it's possible, but because it is off topic I will answer in detail here - http://electro-music.com/forum/post-428482.html#428482
BlacKcaT
PostPosted: Tue Jan 23, 2018 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Super!
Nardu
PostPosted: Tue Jan 23, 2018 4:14 pm    Post subject: Stripboard version for 2X VCA 76x92mm, version 2 Reply with quote  Mark this post and the followings unread
Stripboard version 2 for 2X VCA. Original scheme; CV1,CV2 - LM324, IN1-Out1, IN2-Out2 - TL084
 Filesize:  339.24 KB
 Viewed:  473 Time(s)
