BlacKcaT
Posted: Sun Jan 14, 2018 4:39 am Post subject:
RYO 3x VCA - Stripboard layout help |
Never done a stripboard layout from schematics. I know there are some free sw for it, but dunno where to start. Is there any of you so kind to help me with this?
http://ljunggrenaudio.com/products/3XVCA/3xVCA%20schematic%201.0.gif
I'm looking to do that on stripboard and put in my eurorack.
Hope this insn't unfair, since the schematics are online, and I only want to build one or two for my system.
Any help is much appreciated!
EDIT: If you are going to build this one, please read all the 3ad in order to follow alla the changes made at the project. Many thanks to Nardu, who made the job! Last edited by BlacKcaT on Thu Jan 25, 2018 6:36 am; edited 1 time in total |
gabbagabi
khakifridge
Posted: Mon Jan 15, 2018 6:22 am Post subject:
| If you're looking for software, then check out DIYLC. Good for vero, perf and PCBs. |
BlacKcaT
Posted: Mon Jan 15, 2018 10:41 am Post subject:
Thanks for the reply g.gabba,
I'm not able ATM to develop a new schematic for a 2x2, so I'm trying to draw a stripboard layout for this tested one |
gabbagabi
Posted: Mon Jan 15, 2018 10:53 am Post subject:
in every of the 3 VCAs in the schematic is written Ljunggrenaudio.com
just leave the one on the bottom out
so u will use one LM13700 and two tl074 to build two VCAs |
BlacKcaT
Posted: Mon Jan 15, 2018 11:23 am Post subject:
| khakifridge wrote: | | If you're looking for software, then check out DIYLC. Good for vero, perf and PCBs. |
Thanks! I'll check it  |
BlacKcaT
Posted: Mon Jan 15, 2018 11:25 am Post subject:
| g.gabba wrote: | in every of the 3 VCAs in the schematic is written Ljunggrenaudio.com
Fairly simple  |
gabbagabi
Posted: Tue Jan 16, 2018 8:42 am Post subject:
in bocca lupo per il progetto |
Nardu
Joined: Feb 28, 2011 Posts: 62 Location: Braila, Romania
BlacKcaT
Posted: Wed Jan 17, 2018 5:08 am Post subject:
@nardu ! This is great! Thank you so much for this! I'll check it  |
Nardu
Posted: Wed Jan 17, 2018 6:29 am Post subject:
RYO 2X VCA |
Not finessed !
Here with potentials
I used IC2, IC5, but with the pins renumber. Pins IC3 are the same.
Instead of D1,D2,R1,R2,C1,C2,C3,C4 I have used 2 ferrite bead. I will complete pcb with this pieces too.
| RYO 2X VCA stripboard version with LochMaster software. Potentials |
302.16 KB |
| Viewed: |
526 Time(s) |
_________________ http://nardusynth.blogspot.ro/ Last edited by Nardu on Thu Jan 18, 2018 4:57 pm; edited 1 time in total |
gabbagabi
Nardu
Posted: Wed Jan 17, 2018 9:01 am Post subject:
@g.gabba, I use for pcb design Sprint-Layout 6.0 from Abacom http://www.abacom-online.de/uk/html/body_sprint-layout.html .
It's simpler and more productive. Export Gerber files, Drill data (Excellon), Isolation milling (HGPL, .plt), bmp, jpg, gif, emf. Print all layers with option.
All you need to produce DIY pcb; press&peel, toner transfer, CNC milling, plotter, PCB manufacturing... China!
Here is an example
83.98 KB |
| Viewed: |
464 Time(s) |
| Photo view with solder mask, like real |
163.82 KB |
| Viewed: |
500 Time(s) |
_________________ http://nardusynth.blogspot.ro/ Last edited by Nardu on Wed Jan 17, 2018 3:20 pm; edited 4 times in total |
Nardu
Posted: Wed Jan 17, 2018 2:30 pm Post subject:
RYO 2X VCA - Front panel |
Front panel idea 4HP EuroRack
12.87 KB |
| Viewed: |
25284 Time(s) |
 Download (listen) |
| Filename: |
RYO 2x VCA-4HP_eurorack.pdf |
12.44 KB |
| Downloaded: |
520 Time(s) |
 Download (listen) |
| Filename: |
RYO 2x VCA-4HP_eurorack v,2.pdf |
12.45 KB |
| Downloaded: |
493 Time(s) |
 Download (listen) |
| Filename: |
RYO 2x VCA-2HP_eurorack.fpd |
1.11 KB |
| Downloaded: |
500 Time(s) |
 Download (listen) |
| Filename: |
RYO 2x VCA-2HP_eurorack v,2.fpd |
1.14 KB |
| Downloaded: |
505 Time(s) |
_________________ http://nardusynth.blogspot.ro/ |
gabbagabi
Posted: Thu Jan 18, 2018 12:58 am Post subject:
hi nardu, iam also using sprint-layout
Do u guys know how the 13700 behaving when the CV is negative?
they just quiet or they get damaged? Since there is no protection against negative CV in the Schematic i could imagine that they just go quiet.
And If they do so u could pimp this dual VCA further to a Ringmod with a switch. |
BlacKcaT
Posted: Thu Jan 18, 2018 11:25 am Post subject:
Hi Nardu,
you are so kind Thank you for sharing all this info and the panels and so on!
This is a nice present for the community !
I've a question about sprint-layout. Is it also possible to draw the schematics, and then let the sw do the p'n'p layout for toner transfer method?
This would be really interesting indeed! |
BlacKcaT
Posted: Thu Jan 18, 2018 11:28 am Post subject:
| g.gabba wrote: |
nice idea, how you would manage that? |
gabbagabi
Posted: Thu Jan 18, 2018 11:48 am Post subject:
cv2 input goes to the output of IC2D
and
IN2 input goes to the output of IC5C
so it will be a double switch
ONLY if the anwer is YES to:
they just quiet or they get damaged? Since there is no protection against negative CV in the Schematic i could imagine that they just go quiet. |
Nardu
Posted: Thu Jan 18, 2018 5:12 pm Post subject:
| BlacKcaT wrote: | ......
please reformulate the question _________________ http://nardusynth.blogspot.ro/ |
gabbagabi
Posted: Fri Jan 19, 2018 12:10 am Post subject:
| i guess he meant something like the partplace & autorouter function- which sprint-Layout does not have |
BlacKcaT
Posted: Fri Jan 19, 2018 2:38 am Post subject:
| Nardu wrote: | | BlacKcaT wrote: | ......
please reformulate the question |
oh, sorry I was unclear ...
I was meaning if it is possible from schematics to have components layout and traces.
For example, from this:
to this:
this way I can use toner transfer method for make my pcb
thanks |
Nardu
Posted: Tue Jan 23, 2018 10:55 am Post subject:
Stripboard version for 2X VCA 76x92mm |
Stripboard version for 2X VCA 76x92mm. Is not like the original scheme
All you need here - RYO 2x VCA stripboard.zip
203.6 KB |
| Viewed: |
448 Time(s) |
250.68 KB |
| Viewed: |
470 Time(s) |
197.59 KB |
| Viewed: |
476 Time(s) |
 Download (listen) |
| Filename: |
RYO 2x VCA stripboard.zip |
425.36 KB |
| Downloaded: |
523 Time(s) |
| modified front panel, gap between holes, inches |
 Download (listen) |
| Filename: |
RYO 2x VCA-2HP_eurorack v.2.1.fpd |
1.14 KB |
| Downloaded: |
463 Time(s) |
_________________ http://nardusynth.blogspot.ro/ Last edited by Nardu on Tue Jan 23, 2018 11:17 am; edited 1 time in total |
Nardu
Posted: Tue Jan 23, 2018 11:14 am Post subject:
| BlacKcaT wrote: | .......
thanks |
Of course, it's possible, but because it is off topic I will answer in detail here - http://electro-music.com/forum/post-428482.html#428482 _________________ http://nardusynth.blogspot.ro/ |
BlacKcaT
Posted: Tue Jan 23, 2018 11:33 am Post subject:
| Super! |
Nardu
