MUX modules at audio rate, please
Page 1 of 1 [6 Posts]
Any takers?
Yeah
86%
 86%  [ 13 ]
Nope
0%
 0%  [ 0 ]
Don't care
13%
 13%  [ 2 ]
Total Votes : 15
Tim Kleinert
G2 patch files: 236
PostPosted: Mon Oct 24, 2005 2:24 pm    Post subject: MUX modules at audio rate, please Reply with quote  Mark this post and the followings unread
I'd like the MUX modules, especially the XMUX, to adapt to audiorate when being controlled by a signal of audio bandwitdh.
(Eg. driving the XMUX with a triangle oscillator and hooking 8 envelopes to its inputs would make a nice advanced morphing wavetable oscillator.)
Wan
G2 patch files: 46
PostPosted: Tue Oct 25, 2005 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes Exclamation
It would become a waveform constructor. Very handy imho.
Very good suggestion Tim.
Grtz Wan
Tim Kleinert
G2 patch files: 236
PostPosted: Tue Oct 25, 2005 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, you can already do this stuff with the CtrlSeq module. But this way would give you dynamic control over the levels.
Also, I find it inconsistent that some of the G2 modules optimize to audiorate when being plugged into by an audio signal, whereas some others do not.
I'd like this optimisation scheme be consistently applied to all modules. This would enable alot more fun audio stuff like eg. applying the NoteScaler modulo trick to waveforms, muxing/demuxing at audiorate to generate new waveforms on the fly, etc.
PostPosted: Tue Oct 25, 2005 1:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
tim wrote:
[...] I'd like this optimisation scheme be consistently applied to all modules. This would enable alot more fun audio stuff like eg. using the modulo trick with waveforms etc., muxing/demuxing at audiorate to generate new waveforms on the fly, etc.
I agree here.
Just one thing though I think the current optimizer makes wrong decisions occasionaly, unwanted ones at other times, making signals red where they could/should be blue.
I'd also like to have more control making signals blue wwithout using a special extra module for that. Maybe with blue / red selection buttons on outputs, or maybe by having two versions of most modules.
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Oct 26, 2005 12:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I agree here.
Oh, yes, absolutely.
I often have the feeling that Clavia has been uber-careful to make the G2 as simple as possible to use, in order not to scare off potential buyers. I understand that position. I think this is the reason why they made the blue/red optimisation automatic rather than manually controlled.
However, to paraphrase Confucius, control is always better than trust.
I think a blue/red bandwidth toggling button would be easier than having two versions of modules. This way, you could change the bandwidth whenever you need to, while patching, and there wouldn't be as many modules to choose from in the menu tabs.
I think this could be a new wish list entry in itself.
PostPosted: Wed Oct 26, 2005 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Agreed, but thought it good to be mentioned here as well to intruduce a little caution for overhasted developers (ehm, who ? where ?)
