Your 1st Modular attempts ?
Page 1 of 2 [32 Posts]
ramechling
PostPosted: Thu Jul 19, 2007 5:04 am    Post subject: Your 1st Modular attempts ?
Subject description: It's Greek to me !!
So, the all-watchful and ever-compassionate Mr. Mosc has gently twisted my arm to ask this sophomoric question....
now if I could only find the words ?
So many of you have recently posted a literal GOLDMINE of information on this site.... your personal successes and failures with synth modules you have praised and cursed, usually at great personal expense and TIME !
Here I'm thinking of (in no order) posts by Stein G., Dan L., Per W., Kas, EdisonRex, mono-poly.... a long list...
Only Mr. Mosc knows how many individuals view this Forum and all of us benefit.... a million thanks !
QUESTION: So, for those of you who have a desire to begin assembling a .... hmmm..."modest"... "portable".... "finite"(?)... modular synthe....
Is it just me, or do the English descriptions of endless features of modules lead to the "deer-caught-in-headlight" stare at some point ?
The audio samples are often as bewildering as the written descriptions and I can't help wonder, how does a beginner even begin to learn about such things ? Books ?...the most highly praised seems to be the out-of-print 1983 Electronic Music by allen Strange ($78 USD)
College courses ? Trial and error ?
My recent purchase of DSI's PolyEvo Keyboard is a thrill I never imagined to experience. But, I'm thinking that the recent flood of 2 or 3 function modules would allow me to fill a portable case such as the A-100p Doepfer case (or something similar) so that soundscapes could be created w/o keyboard and I'd be forced to stop when the case is full ! ??
The Minimoog I bought and learned on for a few years in the '70s did not come with an in-depth analogue synth tutorial... just a few recommended patches as I remember.... so, is it the same way now ?..sink or swim ?
Well, Mr. Mosc, that should be enough to start the avalanche.... thanks again for your encouragement to all beginners who read your Forum.
SHANTI
ramechling2005(at)gmail(dot)com
ndkent
PostPosted: Thu Jul 19, 2007 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Well since you are talking about a small/portable/finite system you do really want to focus on some directions and goals for what you want to achieve. There are many situations when a modular system is the way to meet your goals but there are also a lot of situations when a modular system might be working against you. In other words making things harder and more expensive to do.
You have to consider the context you want to use it in. This is especially important because while they might be incredibly attractive as something you want to use, small modular systems are usually pretty expensive for what they do, they aren't all that compact or lightweight, and while they have plenty of knobs, memory and numbers of voices might be a big benefit in a live performance situation.
There are definitely some good resources out there for learning how to patch a modular and program analog synthesis in general. Assembling a system is a bit tricky because other than hanging our on forums and boards and mailing lists, what's available for sale at any given time can quickly be improved upon or discontinued. I guess that's like music technology in general, but there often isn't a sort of newest model progression or the numbers of any modules on the market letting you just pick one up anytime used or something.
You really need to determine what you'd like your system to do. Don't forget to examine the alternatives to a proper modular. You'd be fooling yourself thinking modulars do all things well, though on the other hand they can do many special things. Definitely consider the possibility of a semi-modular system, meaning a synth that's not actually modules but does have many patch points. Its not a great option if you have very specific needs, but it's a really good option for most of your other requrements. Putting together a system then doesn't become an issue right away because it's already designed. Then you can augment it with traditional modules in a separate case later on once you've found a direction you wat to go in and you can see what you can do with patching that hopefully goes beyond fixed architecture synths.
ramechling
PostPosted: Thu Jul 19, 2007 6:25 am    Post subject: Discipline... don't lose focus ! Reply with quote  Mark this post and the followings unread
Thanks. Rather than specifics, your advice reminds me not to lose my focus and always exert some self-discipline !
I had almost given up on the dream(?) until I read an interview with Steve Roach where he spoke of creating ever-evolving soundscapes without use of an attached keyboard:
http://emusician.com/em_spotlight/steve_roach/
That provoked so many ideas... the thought has stayed with me for weeks.
I do not have any recording equipment and am thinking mainly of realtime or live usage. I forgot to mention my secret weapon, the Eventide Eclipse... married to the PEK it is breathtaking indeed.
Again, thanks for your suggestions !
EdisonRex
Audio files: 172
PostPosted: Thu Jul 19, 2007 7:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I think of building a modular or owning one as one of the expressions of freedom to create experimental music. I built my first modular because I wanted to understand how they worked, not simply to make music with one.
The second modular I built, now 30 years ago, was also an educational experience, being financed by my high school and a collaboration between the music and math departments. Having been through both the start of commercial electronics and the mainstreaming/commoditization of electronica I find the ability to tinker with circuits and make sound sculpture/experimental sound/timbre creation a liberation.
The modules I am putting together now are to augment my existing studio which has all sorts of stuff (a PEK being one of them). Phase I will mostly be modifiers (control voltage randomizing, sound shaping). I'm more interested in using interesting circuits I wouldn't get in my "normal" (ha!) instruments. Phase II will add voices to augment my existing VCOs. I intend to set it up to allow cross patching between as much of the kit as I can.
I think a lot of people like the control you have with a modular setup. Beats heck out of the 1980s LCD display. The best part is being able to quickly try something, I always found it easier to patch than to muck about with parameters on a digital board.
Ah well. ndkent summed up the need to know what you want first. And remember you aren't married to a keyboard. mono-poly for example doesn't use keyboards at all. You can easily find other ways to control with voltage control.
Garret: It's so retro.
Mohoyoho
PostPosted: Thu Jul 19, 2007 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Ramechling,
The PEK is a pretty powerful synth, and has features that many modular owners would envy. Before building the modular, I would master the PEK to see what it is that it lacks to fulfill your sonic goals. As far as keyboardless manipulations, one does not need a modular for that. As previously stated, most semimodular systems can handle that task. My Voyager has plenty of ins and outs to bypass the keyboard for neat sounds that could be manipulated by knobs, XY pads, etc. via its CV ins. Even the Phatty has some of those capabilites. I'm not that familiar with the PEK, but perhaps it does too. If you have access to the gate and pitch, then you are on your way.
Even if the PEK doesn't have CV in (I don't know) one could easily manipulate the oscillators and every function via a keyboardless midi controller.
As far as learning basic subtractive synthesis, there are books like the Moog Cookbook, but I found one of the best tutorials for me was Arturia's Moog Modular V. It was through learning that software that steered me to eventually purchasing a Voyager. The Arturia software will teach you all the basics and more. Plus, it has a great users manual/book that takes you through subtractive synthesis. I would say one could easily apply what you would learn from that software to the PEK and most synths. I can't empasize enough how much that software teaches synthesis.
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
EdisonRex
Audio files: 172
PostPosted: Thu Jul 19, 2007 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh yeah I forgot to mention.
Probably one of the best electronic music theory tutorials is the ARP 2600 User's Manual. You can still buy these online from the author, Jim Michmerhuizen.
Audio files: 236
PostPosted: Thu Jul 19, 2007 4:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
IMHO, the best thing to do when you are considering buying or building a modular system is to download the free G2 demo program from the Clavia web site. That allows you to try out many things without investing any cost.
You can build and patch you own modulars to your hearts delight and see what works for you and what doesn't. You can learn quite a lot. The demo is restricted to mono, but that's the same as a real modular, for the most part. Unlike a real G2, the demo doesn't have audio input modules and the midi functions are pretty limited too, but it is still a superb learning tool. I think it is in many ways better than the Arturia Moog V and being free it is much cheaper.
Now, aside from learning, I think the G2 and G2X are the best modulars you can get. Still, what real modulars offer, aside from the subtle sound qualities, is a visual and tactile experience when you play them. The G2 is more powerful, but it can't compare to the touch of a real modular system.
I have a Moog IIC Modular system which is really cool, but my G2 is like having at least 30 of them with patches that can be instantly recalled and polyphonic to boot.
ndkent
PostPosted: Fri Jul 20, 2007 6:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree that the Nord G2 Demo software is a fantastic and free virtual way of having the experience of patching a modular system.
One thing that you probably will discover is most of the patches that have an evolving self playing nature that you can modify on the fly also unfortunately use quite a number of modules. The increase in complexity comes from an increase in modules and patch complexity. The good thing with the software is so long as you have CPU power left you can keep adding and patching virtual modules. Quite a difference from figureing out how to pay for new modules and waiting for them and then needing new cases and power supplies, etc. Wink
I believe most smaller modular systems tend to either have capabilities similar to a monosynth (but generally cost more and are often less portable) or they can be processing systems more focused on processing the output of other sound sources. That brings up one big ergonomic difference. Being virtual, the demo Nord G2 won't process external signals and the hardware G2 has audio imputs, so that's a big plus, but still doesn't have a real modular's ability to extract or insert signals throughout the patch. In my mind that's the key value of a small modular system. You can insert effects mid patch, you can process external audio (though virtual instruments often can) and you can sometimes create feedback structures that defy "virtual" simulation
I guess the Nord Demo software is free so I can't complain and then the hardware Nord G2 can simulate a very very large modular system and do things like store patch states, so that's what I'd consider the value of the hardware Nord G2.
But back to real analog modular gear. There is an experience that comes with physical patch cables, a real knob per parameter and generally zero menus, scrolling etc.
Audio files: 236
PostPosted: Fri Jul 20, 2007 6:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can't do anything with audio inputs on the G2 demo, but the real G2 has 4 inputs and 4 outputs and than be connected to any point in a patch. There are also an additional 4 independent audio channels for routing between the slots. (a slot is an independent virtual modular synth). It offers quite a bit of flexibility.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri Jul 20, 2007 11:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree about the physical knobs, there is just something about the thing you are adjusting being physically in the circuit. I don't have such fond memories of patch cables though.
I had quite a few patch cords of varying lengths, I still smile when I see patch cords draped around someones neck or over the back of a chair. It is a smile based on not having to use them anymore Laughing
ndkent
PostPosted: Sun Jul 22, 2007 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
You have a point, especially when trying to perform spontaneously live rather than in starts and stops. I guess sort of like a DJ with a second turntable, you can patch muted modules while others run by thesmelves or you can try to patch everything as much as possible and turn down the attenuators on parts of it. But there is a sense in some degree of patchcords physically and mentally getting in the way of making music. Though the payoff is patchcords do let you work with modulation along paths, rates and amounts beyond a lot of other more finite hardware and software systems.
etherline
PostPosted: Mon Jul 23, 2007 2:29 am    Post subject: Reply with quote  Mark this post and the followings unread
This manual is also downloadable elsewhere. This set me to thinking:
would copyright revert to the author when ARP ceased or would it follow the rights to the ARP name? Pretty certain that commissioning companies don't let technical authors own the copyright to user manuals in the same way that my work belongs to the company that I work for. In which case, does even the author have the rights to publish it Question . What *is* the story with vintage user manual copyright?
EdisonRex
Audio files: 172
PostPosted: Mon Jul 23, 2007 5:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Jim owns the copyright to that work. Alan Pearlman (actually David Friend) did a deal with him back in 1970, actually if I remember the story as Alan told me, Jim had written the manual for the 2600 before the 2600 was a product. There was an abridged version of Jim's work on the 2500 manual as well, but the 2500 was aimed at people who knew more about what they were doing (universities, rich rockers). The 2600 was aimed at a less technical market originally. One of the things that made ARP famous was that Alan gave away a lot of free kit in return for testimonials. Alan is a very nice person and it reflected in a lot of the business decisions made at Tonus/ARP.
Jim went on to, among other things, found the Boston School of Electronic Music, which used that manual as part of it's Introduction to Electronic Music course. I own a 1973 edition of that manual, which I got from ARP when they were at their old shop in Newton Highlands.
Now as to vintage manuals, in general, copyright applies and copyright stays with the owner. There are plenty of manuals floating around as scans and PDFs but I believe many are up on the net without the permission of the copyright holder. Some of the works are probably abandoned but that doesn't mean the rights don't apply.
Mohoyoho
PostPosted: Mon Jul 23, 2007 6:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know if this is the full manual, but here's a link to some of Jim's writing on synthesis:
http://www.wayoutware.com/manuals.html
Mark Mahoney
doctorvague
PostPosted: Mon Jul 23, 2007 1:29 pm    Post subject: Re: Your 1st Modular attempts ?
ROFL
yep, just keep believing that
Laughing
doctorvague's youtube channel
ndkent
PostPosted: Wed Jul 25, 2007 4:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I think I can follow your line of thought that with the configurable architecture that a modular provides you can definitely create more complex and self playing sounds than a typical fixed architecture synth, let alone all but the most complex polysynths because of the practical reason that whatever synth components are in there need to be multiplied for polyphonic voices.
A modular definitely can create complex sounds, but sometimes the price comes with a greater number of modules. You can create one voice that's deliriously complex with enough modules or maybe several parallel patches. But many modules need to come into play.
Well to me at least, the term "soundscape" tends to involve layering. Now a long delay is definitely one way to create multiple layers live from individual layers and of course if multitracking is an option then you can have numerous layers. So it's not impossible at all, but it is challenging if the resources are limited.
But you do have to consider even with modules having more than one function, they are either going to offer a choice of *one* of several functions or offer several more basic rather than full featured functions. I'd think it may be challenging to create the level of complexity one might desire if one greatly limits ones resources.
ndkent
PostPosted: Wed Jul 25, 2007 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
ramechling wrote:
Hey, I really appreciate everyone's thoughtful help.
I do not own a computer...that does not appeal to me.
My original question concerned how baffling it is to me as to how manufacturers of synth modules expect to EVER sell their products to beginners, like myself ?
Without 20+ years of hard-earned experience at patching, how do they expect beginners to make any sense of even the descriptions of various modules, let alone the pathetic sounding audio samples on their websites ?
There are a few books written many years ago about analogue theory, but much has appeared on the market in just the last 5 years.
How do beginners even learn what I/Os to use... do the modules come with Owners Manuals... I doubt it !!
Isn't it a shock to see that Mr. Richter offers NINE patchseet suggestions on his Wiard site, and yet cautions that he assumes the reader has previous experience ?
Again, thanks for your help and I hope to "advance slowly" and keep pestering all of you !
Shanti - Richard
In my posts I was trying to emphasize that a modular synth does some things exceptionally well but can be very inefficient when looking at all the gear out there.
That really is a reason why there's not incredibly much out there. It's a niche market. The vast majority of people starting out with synths really haven't started out with a modular since the 1970s, and even in the 70s it was because they were considered "state of the art" and colleges sometimes had them (and a few still do only more as an alternative). People tend to come after knowing synthesis pretty well or are incredibly determined to use one. It's by no means a 20 year experience needed thing. Some of the pioneers had experience with electronic music but many didn't.
While you usually need some help to figure out what modules to start with, that's not really info directly found in a book, most well known musicians who used modulars did not get a manual (the Moog modular for instance).
Except for the few sem-successful "mainstream" occasions when for instance Arp made the 2600 or Roland translated some books for their 100M series back in the late 70s or Clavia to some extent with their virtual modulars in the last decade, when a company actually felt they had a shot at attracting entry level users they did make some attempt to offer something to learn from.
But unfortunately the reality is the little companies today are really tiny and it's more or less assumed you aren't starting with a modular as your first analog synth. It's not so big a leap if you know fixed architecture analog synths well (or their virtual analog counterparts). It is a leap, but a beginner can start with the configuration of their analog synth as a foundation.
As to documentation, many modular makers do have documentation to each of their modules. Some are pretty good. A bit of websurfing will find a lot. Some assume a lot of prior knowledge, some start with defining what they do and I'm sure you'd find those useful (take a look at Doepfer.com their manuals aren't perfect in terms of info or grammar but they have the largest number of modules available and they have both a descriptive web page (for every module) and almost always a longer .pdf file manual that doesn't just reprint what's in their online listing.
It is a sort of conundrum to write a book currently. I've thought about it. If you write something general that applies to any modular synth you need to do a lot of "backtracking" and generalizing because there are enough differences and quirks that need special explanations for specific gear. Then if you write a text on a specific modular then you are writing for a very small audience made smaller since a fair number don't need an entry level book any more.
ramechling
PostPosted: Wed Jul 25, 2007 10:32 am    Post subject: Doepfer PDF files Reply with quote  Mark this post and the followings unread
Hey, the PDF files for the Doepfer modules are astonishing....just what I needed.
Mr. Duncan offers PDF files of both his A and B series Owners Manuals !
I guess I had forgotten about them or wasn't ready at the time.
I need to buy a ream of paper and start printing.
I seem to remember considering an ARP 2600 when I bought the Minimoog but the 2600 was quite a bit more money.
Now that I think about it, the difference in price would have been worth it just for the Owners Manual !
Meanwhile, Shawn and Chuck O. are always ready to answer detailed questions about any equipment they stock in Pomona.
They were very helpful in guiding me when I made the Looperlative and later the PEK purchase. Thanks again !
-RM
synthetic
PostPosted: Tue Dec 18, 2007 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
The E-mu Modular Manual is also a very good resource:
http://www.synthman.com/cgibin/z.cgi/emu/support/E-MU_Modular_Operation_Manual.zip
I believe this was designed for free download (30 years after the fact).
ramechling
PostPosted: Tue Dec 18, 2007 12:39 pm    Post subject: Smallest modular in S. Carolina Reply with quote  Mark this post and the followings unread
Thanks, I'll look through this. Meanwhile, it looks like I've made the plunge into the banana-jack modular world with a Med. Power Sply. and Twin Wasp Filter having arrived and VC Tabla, etc. to arrive...uh...soon ?
It seems odd that the Plan B and Wiard sites have some info as to the modules' functions, but so far I only have single sheets to show how to plug into the power distribution card so as not to burn down the house Smile
Oh, this should be... fun ?
EdisonRex
Audio files: 172
PostPosted: Tue Dec 18, 2007 2:43 pm    Post subject: Re: Smallest modular in S. Carolina Reply with quote  Mark this post and the followings unread
It should be fun. You'll manage, and you ask good questions.
Peake
PostPosted: Wed Dec 19, 2007 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you're looking for a "finite" modular, get a 6 module Wiard and never look back. 6 Wiard modules will provide for years of discovery and enjoyment. It's one of the rare modulars that are designed as a holistic system, and not a continuous sprawl of unrelated timbre and function.
http://www.wiard.com
ramechling
PostPosted: Wed Dec 19, 2007 3:14 pm    Post subject: It's a Wiard world Reply with quote  Mark this post and the followings unread
Thanks, Peake...I've been receiving daily posts from the Wiard Forum for many months and Grant is always very kind to respond in-depth to all questions !
He has done a masterful job on his homepage in creating downloads of module functions and even recommended patches... who else does that ??
What a thrill to read Gary Chang's comments about the SCREAM Festival last month in L.A. Actually, all who played at that event have posted their impressions as well as photos.
morbius
PostPosted: Sat Jan 05, 2008 10:26 am    Post subject:  Your First Modular
Subject description: learning/using/buying
With 35+ professional years, I agree totally with knobs vs. pixels. But- it's still personal preference. For some, being able to recall/store patches, polyphony, and all that the computer-age offers is a big draw. For others, the hands-on, 'real' equipment, actual modules and patching is important.
And the b!tch of it is... the modular-virgin has nothing to go by to decide what's right for him. If you go with virtual, you'll never know about the entire experience of owning/using/building a real modular. If you buy into the 'real' equipment, you might (or might not) decide that virtual would have been easier/better/cheaper for YOUR needs.
That being said... perhaps a little bit of both, for starters... or even, locate someone in your area who has a modular (we're all usually willing to let someone come in... check it out... show it off... esp. in home-studio settings). Many owners of Synthesizers.com, MOTM, Cyndustries, Modcan, and others can be found on their 'user-group' forums (many on Yahoo). Joining those groups... introducing yourself, and asking if anyone in your area would give you a taste, is perfectly okeedoke.
A lot of the 'old-timers' started out building cheap kits (I won't name names... not even if it starts with a "P")... and went on from there. There are companies (mentioned above) who offer very reasonably priced systems, and modules. Synth-dot-com offers a 'starter system'... pay X down, receive whatever module per month. If you don't like your 'new' modular.... they resell very well... figure on about 80% resale value (+/-).
Learning- Definitely... Alan Strange's book... the APR-2600 manual. Both are easier to understand, than falling down. But- I feel all of the reading and theory in the world will not replace sitting down in front of a system... patching this to that, and experiencing what happens... then realizing why. The primary things to understand... signal flow, and outputs to inputs; voltage-control; sound sources; sound modification (filters, etc.); modulation; and controllers. Once you grasp the concept... you'll take off and fly.
But really... join a couple of synth 'user groups'... introduce yourself... tell 'em you're new, don't own one yet, but would like to learn. You can ask specific questions you may have, or even ask if there's anyone who'd be willing to teach you a little... just to get you up and running. But you're still going to have to read-up on the theory, and have an idea of what each module does... what it's used for, and how they connect together to produce and modify the sounds.
One other thing- I see the synth-world in two groups.... one- systems like Buchla, which is designed pretty much for strictly 'electronic sounds' and experimentation, and then, there's most of the other brands... which are pretty much geared towards creating melodic (tonal) music. You can use the later to do the former... but, it would be more difficult to use the former to do the later (IMO). Don Buchla makes killer synths... but it's well known that he despises keyboards, and doesn't offer a 'real' keyboard controller at all. I'd recommend checking out synthesizers.com. They also have a WIKI site for dotcom synths, which could be another valuable resource for learning and researching.
Good Luck.
~Morbius~
http://www.MusicByCybertron.com
morbius001a@yahoo.com
Audio files: 236
PostPosted: Mon Jan 07, 2008 1:17 pm    Post subject: Re: Your First Modular
Good post, Morbious. Many well taken points.
Maybe I'm picky, but I don't think it is fair to say he despises keyboards. That word implies a deep emotional hatred. I don't think that is really accurate. If you would hook up a midi keyboard to a Buchla system I doubt if Don would be upset. In general, he makes things that interest him and can't be purchased elsewhere. Just because he is not into keyboards doesn't mean he despises them. From what I recall, he is very open minded.
