 Forum index » How-tos » Surround and Sound Reinforcement
I fear wind noise (moderately urgent question)
Post new topic   Reply to topic Moderators: diatonis, mosc
Page 1 of 1 [11 Posts]
dewdrop_world
PostPosted: Thu Sep 06, 2007 9:36 am    Post subject:  I fear wind noise (moderately urgent question)
Subject description: Outdoor performance with mic
I was just fiddling around with my mic (Shure SM57, I'm a cheap bastard) and discovered that its windscreen does a good job of blocking an airstream directed at the tip... ok. But wind coming in at the sides goes right through. That's going to pollute the audio stream pretty badly when I play outside (on Saturday - yikes!).
There must be a way to get somewhat better audio insulation. If I cup my hands around the sides of the windscreen, noise drops dramatically. So would it work, perhaps, to jerry-rig a cylinder out of some soft paper, like toilet paper maybe, and tape it around the outside? Damn ugly but it's the sound that matters.
Or is there something better I could get from guitar center?
Thanks.
Audio files: 227
PostPosted: Thu Sep 06, 2007 9:52 am    Post subject: Reply with quote  Mark this post and the followings unread
The SM57 is a great mic. You can run over it with a car and it'll still work.
Most guys that are really into field recording end up making their own wind baffles. I think you can come up with something by experimentation.
PostPosted: Thu Sep 06, 2007 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
I did have some reasonable results once with loosely packed cotton wool held together with galvanized wire, but it's a bit of an art I guess to get it right.
edit: hiding a mic in some vegetation helps as well, like long grass or dense bushes.
dewdrop_world
PostPosted: Fri Sep 07, 2007 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing I don't think I'll try that one today or tomorrow.
When I went to the first SC symposium in Birmingham, they didn't have a mic-stand clip that fits the SM57. So the organizer said, "How would you like to use a £500 condenser mic?" "Well, if I must..." Razz
Well, not much time to experiment at the moment, but I'll keep it mind for the future.
James
Mohoyoho
PostPosted: Fri Sep 07, 2007 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Probably the best are the zeppelin windscreens that look like a Persian cat. They have long fibers coming out of it which deaden wind noise. You'll see them used frequently by news crews on outdoor events. You should be able to get one at any professional audio/video outlet: Full Compass, B & H, Bradley Broadcast, etc.
They're not cheap. Here's some links with some professional ones, and a DIY that looks pretty good and cheap.
http://www.joelandkaren.com/mic-zeppelin/
http://www.equipmentemporium.com/new%20Fuzzy's.htm
http://www.fullcompass.com/product/298039.html
On the second link, copy and paste the link to your browser. I can't seem to get the 's.htm to become part of the whole link. I guess there's something about the apostrophe. The site has some interesting pictures.
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
EdisonRex
Audio files: 172
PostPosted: Fri Sep 07, 2007 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheap wind screens:
Get a needlepoint hoop. You can get them at sewing stores. They're like these big double wicker hoop things. Get something about 8" max.
Then go get some ladies nylons. I think drugstores sell them but I always had my wife buy them...
You cut a nice double thick row and suspend them in the hoop(s). put the hoop in the direction of the wind (this also makes a dandy cheap pop filter for close miking).
I know a lot of folks who swear by cotton stuffed in a nylon (again, women's undergarments) stocking and shoved around your mic's head.
Not pretty, but effective.
Garret: It's so retro.
PostPosted: Sat Sep 08, 2007 5:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I've always had a problem with trying to mask wind noise.
In the end I decided to just blame it on the dog. Shocked
jksuperstar
G2 patch files: 18
PostPosted: Sat Sep 08, 2007 8:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Some of my mics came with the standard sponge wind noise block. Works fine for low-velocity wind. Your SM57 has a sponge in the front of it to prevent wind puffs such as from a human, or drum head, or horn. The external ones just slip onto the mic, and it's what you typically see on reporters' mics whenever they are outside interviewing someone (sometimes big & orange, or black).
Audio files: 227
PostPosted: Sat Sep 08, 2007 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Too late for James, he's probably at his gig right now. I suppose he'll fill us in on what he finally came up with.
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Sep 08, 2007 1:28 pm    Post subject: Re: I fear wind noise (moderately urgent question)
not if you play in front of the White House where black helicopters fly all around you Cool
dewdrop_world
PostPosted: Sun Sep 09, 2007 7:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, correction, it's not right in front of the White House. Jackbooted-thug fantasies are not quite warranted.
Nice thought on the big fuzzy windscreen - for the moment, my main concern was that the SM57's smaller windscreen isn't airtight at the back, where it connects to the mic body. In some pre-show testing I got really nasty wind noise through that. So I rubber-banded some TP around that area and the sides of the foam (leaving the front open for my signal). It worked well enough in that setting - in the recording I don't detect the noise floor jump to a ruinous level when the mic input gets routed to the main outs.
Thanks for the suggestions - learning all the time!
James
PS The gig went pretty well. Haven't posted any clips yet.
