 Forum index » Clavia Nord Modular » G2 Performances - Experimental
Random again
Page 1 of 1 [5 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Jul 14, 2004 1:57 am    Post subject: Random again Reply with quote  Mark this post and the followings unread
What I wanted was to introduce a degree of repetition to an otherwise random pattern. So that it might be perceived as more 'musical'. I am posting a single slot prf as the technique is slot dependent; it also stores tempo for master clock.
I have experimented with the recording mode of the note sequencer, but this idea is simpler. I use a clock divider connected to Clock Sync output, to determine the number of repetitions. The dividers output pulse is converted to a midi signal which 'presses' the Rnd button on the sequencer. The same pulse clocks a RndClkA, which via another midictlsend changes the sequence length. The notequant module, in combination with the value control (on the CtrlSend) allows selecting a minimum length and restricting the values to odd or even numbers.
Variation 1-3 uses the one shot sequencer mode, unused sequencer steps gate some other sounds via the sequencer link output, variation 4 is the same as 3 but uses loop mode so shorter sequence lengths repeat. Variation 5-8 are duplicates except they repeat 4 times, not 2.
Rounded off with some cliché retro synthesiser sounds.
Random2.prf2
Repeating Randomness Experiment
 Filename:  Random2.prf2
 Filesize:  5.82 KB
 Downloaded:  1906 Time(s)
egw
G2 patch files: 8
PostPosted: Wed Jul 14, 2004 4:35 am    Post subject: Reply with quote  Mark this post and the followings unread
You can also do this with the random pattern generator (new module in 1.2).
I'm working on a sequencer patch that will randomly generate repeating patterns. You can adjust things like the length, density, range, key, complexity etc.
Audio files: 227
PostPosted: Wed Jul 14, 2004 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice patch, Ian. It's fun to play it by selecting the different variations while it's playing.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Jul 14, 2004 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah yes random pattern module, very good thanks. Because it is pseudo-random and has control inputs, you can not only repeat patterns in the short term, you can jump back to the same pattern later. You can also replace the sequence length trick with a random clk (with low probability) fed into the reset inputs, or something like that.
I thought that one of the A or B inputs might have been a single step index into the pattern so that you could get 'shift right' type effects but apparently not.
Look forward to hearing your patch.
jamos
G2 patch files: 41
PostPosted: Wed Jul 14, 2004 9:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, this is nice. I've been listening to this for the past 20 minutes figuring out how the logic works. It's inspiring.
