Ashaneen
Posted: Thu Nov 08, 2007 7:38 pm Post subject:
Advice on new synth |
I was wondering if I could get some advice on my next synth.
I am thinking about purchasing the Korg x50 or a similar synth for around $500-$1000 US. I mainly work on Psychedelic Trance / Goa but I still haven't found a decent inexpensive synth for my needs. The reason I am looking at a cheaper keyboard as compared to a full-on workstation, is that I do most of my sequencing in Cubase and/or Reason and don't feel like I need an on-synth sequencer (not like I could afford a $2000 synth right now anyway).
But my main issue is that I haven't been able to create exactly what I want with what I have (powerful laptop, Loads of Vst's, Sh-201).
My main issue is with not being able to create the complex bass arpeggios that I want. I have been using the Sh-201 and the software to create custom arp's but they don't sound as good as what am really trying to do.
The real reason I was leaning towards the x50 was for the ease of use of the (dual?) arpeggiator, the 200+ preset arp patterns, and the possibility of user-created arp patterns. Now, I did play with one today for around an hour and I liked it much more than the Juno-D, which was my other choice.
So, if neither one of these will help me make the quality of trance i'm attempting, does anyone have any suggestions as to whether I should get a different inexpensive synth, or if I should save up a bit and get something a bit more serious. Thanks. Last edited by Ashaneen on Fri Nov 09, 2007 3:55 pm; edited 1 time in total |
GovernorSilver
Joined: Apr 26, 2004 Posts: 1349 Location: Washington DC Metro
Ashaneen
Posted: Fri Nov 09, 2007 12:25 pm Post subject:
examples |
GovernorSilver wrote: | How about the Korg Radias or R3? Alesis Ion or Micron? |
I looked at the Alesis Ion and the Micron before I bought my Roland SH-201, and I chose the Roland because of the layout, clean sound, and the software-editable arpeggios, but that system of creating custom arp's just seems too cumbersome to me.
I wasn't sure how the arpeggiator was on the Ion, or the Micron, if they just had a few pre-set arp patterns or they were fully customizable.
Now online descriptions for the Radias and the R3 don't say much about the arpeggiator's customizability, and the R3 seems to just have a few arp patterns.
I was really looking for something with a good easy-to-use arpeggiator, and I was thinking that I just wanted something inexpensive.
But now, I'm at the point where I'm thinking a more high-end piece of equipment would be better for me in the long run.
So basically I'm mostly concerned about an arpeggiator that is fun/easy to use and has a lot of variety, and is customizable.
I'm not totally opposed to spending over $1000, but if I did, I think I should get a full workstation (low-end, not an X8 or anything). Suggestions?
edit: on the low-end workstation side, what about a Korg TR61?
http://www.zzounds.com/item--KORTR61
edit: I have attached a few examples of the style of basslines I am trying to achieve. Any advice is appreciated.
Description: |
 Download (listen) |
Filename: |
Rumble Bass1.mp3 |
Filesize: |
364.11 KB |
Downloaded: |
598 Time(s) |
Description: |
 Download (listen) |
Filename: |
Digital Bass.mp3 |
Filesize: |
548.6 KB |
Downloaded: |
620 Time(s) |
Description: |
 Download (listen) |
Filename: |
Digital Bass2.mp3 |
Filesize: |
364.93 KB |
Downloaded: |
584 Time(s) |
Ashaneen
Posted: Sat Nov 10, 2007 8:16 pm Post subject:
Well, I checked out both of those Korg synths, and I don't think either of those are what I am looking for. I was also able to play around with a Juno-G, and I think that is getting closer to what I feel will suit my needs. The Juno-G has a small sequencer, a fantastic and fully customizable arpeggiator, and it can sample audio and MIDI data. So, for around $1000, I think I am going to go with the Juno-G. The only problem I for see is that the patches/samples are not editable, so I am basically stuck with those on-board sounds or I can get extra sound modules. At least with the Juno-G I can sample and use the tweaked-out sounds from my Sh-201. Maybe I should just save up an extra $800 and go with a Fantom X6.  |
Posted: Sat Nov 10, 2007 9:42 pm Post subject:
The 201 is kinda cute. I like it. The Korg Radias is closer to a modern real instrument. I love it.
As for arpeggiattor patterns, unless you are shooting off the stuff at insane speeds, why don´t you just play the stuff you need? If you really need to store a 1:1 repeatable pattern you can most likely use your DAW for this anyways. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
mtvic
Joined: Feb 03, 2003 Posts: 526 Location: Townbank Cape May NJ
Posted: Sat Nov 10, 2007 11:19 pm Post subject:
Why not trade the 201 ,save the 800 as mentioned add the 1000 and go for a
non special edition Prophet 8.
True analog.
just a thought. _________________ "I'm the transmitter' I give information."
>>> Kraftwerk Radioactivity<<< |
Ashaneen
Posted: Mon Nov 12, 2007 11:47 am Post subject:
Radias? Prophet 8? |
elektro80 wrote: | The 201 is kinda cute. I like it. The Korg Radias is closer to a modern real instrument. I love it.
As for arpeggiattor patterns, unless you are shooting off the stuff at insane speeds, why don´t you just play the stuff you need? If you really need to store a 1:1 repeatable pattern you can most likely use your DAW for this anyways. |
The 201, cute, okay. I think the thing is pretty powerful for the price, and the sounds I can generate with it are much more "analogue sounding" than what I found in 1hr of playing with the TR61.
Now, the Radias looks really nice, but I wasn't sure about the arpeggiator, and if it could do what I am trying to do. I haven't played with one at all yet, so perhaps that should be my the next synth I play with next time I'm at a store.
Yeah,.. I know I can use my DAW for arp patterns, but I was trying to get away from having to boot up my laptop every time I had a little inspiration and wanted to experiment. Same with the Sh-201, I like being able to have the full control the PC arp-editor provides, but it also requires my PC. I was thinking that I could find a really nice analog-sounding synth, with a nice on-board arpeggiator. Maybe the Radias... Hmm,..
mtvic wrote: | Why not trade the 201 ,save the 800 as mentioned add the 1000 and go for a
True analog.
just a thought. |
Thanks, but there is no way I can part with my 201 right now, and for the price I paid (<$400) I would probably regret it. I think I just like playing with it too much.
Now, the Prophet 8, I hadn't thought about that at all. Hadn't even really looked at that one yet. But this may be something I am interested in because everytime I'm out synth shopping, I end up playing with the Poly Evolver PK4 for longer than any other instrument I try. I love that thing, it's got insanely sweet sound. So, maybe if the Prophet sounds similar, and has a good arpeggiator and sequencer, that may be something I would think about. Definitely going to give that one a go next time I'm checkin' out synths.
So, elektro, how is the arpeggiator in the Radias? Do you think I could crank out basslines similar to the sound samples I posted. It looks almost too professional for me, and I'm really not confident enough in my abilities to justify the price right now. Also, I'm just worried that I will be stuck with the on-board arp patterns and I won't be able to achieve the sound I am going for. Specifically, be able to change a note or two within (customize) the arp patterns. This was really the only feature I liked about the Korg TR61, (the graphical "on-screen" arp-editor) the rest of it was basically sub-par.
So, if I am going to spend almost $2K, isn't there somethin' that will be perfect for me? Or should I be saving up more?
Thanks.  |
GovernorSilver
Posted: Tue Nov 13, 2007 1:16 pm Post subject:
I might get a Radias if the local Guitar Center still has any on clearance sale.
What kind of arp power do you really need?
My Emu Command Station XL-7 can do up to 32 simultaneous arppegiators, each on its own MIDI channel. There are 8 different modes to choose from (up-down, random, user pattern, etc.). MIDI CCs can also be mapped to parameters that affect arpeggiator behavior (like length of note, gate values, etc.). Looking forward to experimenting with this via MIDI guitar.  _________________ Current and recent work on Soundcloud
Some old stuff on VIRB |
GovernorSilver
Ashaneen
Posted: Tue Nov 13, 2007 4:49 pm Post subject:
Re: examples |
GovernorSilver wrote: | Ashaneen wrote: | [
Now online descriptions for the Radias and the R3 don't say much about the arpeggiator's customizability, and the R3 seems to just have a few arp |
Did you look at the Radias owner's manual?
http://www.korg.com/downloads/pdf/RADIAS_OM_E2.pdf
"Editing The Arpeggiator" starts on p. 47. And there is another section on arpeggatior parameters on p. 90-something. |
Thanks for your input. Yeah, I guess the online descriptions don't do the Radias any justice. After reading those pages in the manual, and realizing the price (<$1200) this looks like a great synth for my needs.  |
GovernorSilver
Posted: Wed Nov 14, 2007 1:16 pm Post subject:
Re the arpeggiator in the Radias: I´m not using it. If I need that arpeggiator feel to voices I´ll rather write the full stretch of events into a sequencer first.
The built-in sequencer is really nice. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
GovernorSilver
Ashaneen
Posted: Thu Nov 29, 2007 9:54 am Post subject:
Thanks for all the advice. I ended up finding a Radias to play with in a local Guitar Center in Southern California, and was only slightly impressed. Yes, the synth is very fun to play with and the sequencer seems decent. But, again I was not too impressed with the arpeggiator. Sure, it was customizable after figuring the right button combination and key-presses to use, but I still don't think it's what I'm looking for.
I'm thinking now I am going to save up more money (maybe another $1000+) and get something that will suit my needs perfectly, (if it even exists).
In reality I am looking for a synth (analog or VA) that has an arpeggiator that I can edit on-the-fly. Is there anything out there like that?
A synth that I can have an arp going with and be able to dial a knob or hit a slider, or even touch a screen (V-synth or Fantom X-8 maybe?) to be able to adjust individual steps on the fly. So I can hear what it sounds like in real-time.
Granted, I have what I "need" to create the arps I want slowly with Cubase and the 201's editor, but I was looking for something with a more hands-on arp that I could maybe use live. Is there anything out there like that?  |
egw
Joined: Feb 01, 2003 Posts: 1569 Location: Asheville NC
G2 patch files: 8
Posted: Thu Nov 29, 2007 1:30 pm Post subject:
Arpeggiators are intended to be adjusted in real time, by playing the notes on a keyboard. In this way you "edit" the individual steps. If you don't want to play the notes on a keyboard, maybe what you really need is a step sequencer. Most of these allow real time editing. _________________ www.gregwaltzer.com |
Ashaneen
Posted: Mon Dec 03, 2007 4:59 pm Post subject:
egw wrote: | Arpeggiators are intended to be adjusted in real time, by playing the notes on a keyboard. In this way you "edit" the individual steps. If you don't want to play the notes on a keyboard, maybe what you really need is a step sequencer. Most of these allow real time editing. |
I don't have a problem playing notes, I was just looking for an "easier" way because I'm a lazy sac.
Well, so far, what I have been doing with Cubase and my SH-201 is playing the keyboard until I find a note-sequence that is the perfect pattern.
Opening the SH-201's arp editor and creating an arp pattern that is exactly what I just played, save it, then edit that one slightly, save it, edit the new one, save that also. Then record each of those individually as a "sample", and using cubase/reason to put it all together.
I was just looking for a really good arpeggiator in a solid VA, or real Analog synth, that would eliminate using a computer, and hopefully reduce the time it takes to edit/create each arp pattern.
I get by "fine" with what I have now, but I was just trying to find something to make my life a bit easier, and hopefully find a synth that is "fun" to play with, with respect to the arp.
Still looking... At this rate, I should have saved up a few grand to spend on a Synth by the time I find something. Hopefully I will find what I am looking for by this time next year.  |
GovernorSilver
Posted: Tue Dec 04, 2007 12:44 pm Post subject:
Ashaneen wrote: |
A synth that I can have an arp going with and be able to dial a knob or hit a slider, or even touch a screen (V-synth or Fantom X-8 maybe?) to be able to adjust individual steps on the fly. So I can hear what it sounds like in real-time |
It's a shame you weren't on the market for such a synth 3 years ago, otherwise I would have strongly recommended looking for an Emu Command Station on ebay. Up to 32 simultaneous arps, each on its own MIDI Channel if desired, user patterns, arps can respond to 8 or do different MIDI CCs at once, etc. _________________ Current and recent work on Soundcloud
Ashaneen
Posted: Thu Dec 06, 2007 10:02 pm Post subject:
It's a shame you weren't on the market for such a synth 3 years ago, otherwise I would have strongly recommended looking for an Emu Command Station on ebay. Up to 32 simultaneous arps, each on its own MIDI Channel if desired, user patterns, arps can respond to 8 or do different MIDI CCs at once, etc. |
EMU MP7 & XL7 COMMAND STATION
Sounds like it will work.
If I could find a synth with that type of arp control in it, that would be perfect.
I guess the hunt is on for an Emu.
Thanks! |
Mohoyoho
GovernorSilver
Posted: Tue Dec 11, 2007 3:07 pm Post subject:
Ashaneen wrote: | GovernorSilver wrote: |
Thanks! |
Good luck! The ebay prices are still decent for the Command Stations, but the expansion ROMs were cheaper 3 years ago. Like you could have got the Beat Garden ROM for under $100 back then - now there's one on sale for $220-something. _________________ Current and recent work on Soundcloud
Ashaneen
Posted: Wed Dec 12, 2007 2:05 pm Post subject:
Good luck! The ebay prices are still decent for the Command Stations, but the expansion ROMs were cheaper 3 years ago. Like you could have got the Beat Garden ROM for under $100 back then - now there's one on sale for $220-something. |
Yeah, I have been looking for used command stations on eBay, but I'm still not sure if I should, because I went into my local analogue synth store: http://www.analoguehaven.com/ this weekend and fell in love with the v-synth.
Roland came out with a really nice product (V-synth GT) and I couldn't believe how good it was. I was blown away.
The full color screen and the ease of use (Tried it for 2+ hours, including the super-editable arpeggiator) has me Sold on the V-synth.
I think it will be more worthwhile for me to just save up some extra $ and get this .
Thanks for all the advice.  |
GovernorSilver
Ashaneen
Posted: Thu Dec 13, 2007 2:11 pm Post subject:
GovernorSilver wrote: | The V-Synth XT can be found for under $1500 on ebay too. I just lost an auction on one, with final price being about $950.
That's not bad, perhaps something to look into. But I really like the way the GT is set up, plus having the keys is a big advantage for me. On eBay I have found some for around $2000-$2500, so I may go that route. I just like the GT too much, and I may even get a new one if I can find a good price (with warranty).
Thanks again!  |
BobTheDog
Audio files: 32
Posted: Fri Dec 14, 2007 7:41 am Post subject:
I have an XT and the GT is basically two XTs with some extra stuff thrown in.
The XT is great already so the GT should be extra great
You will have many many hours of fun with it.
Andy |
spinach_pizza
Posted: Wed Dec 19, 2007 9:08 am Post subject:
I don't know whether this is helpful, but two other ideas come to mind (if you're interested in analog sound):
1. Futureretro's Revolution (about $700, I think) which has an analog monosynth and sequencer, both tweakable on the fly.
2. Any analog or digital synth with cv or midi inputs, hooked to a FR Mobius (about $400). You could use a Spectral Audio Neptune II rack analog monosynth, with 3 oscillators, LPF, MIDI interface, etc ($600 at Nova Musik), and for $1000 have a pretty cool setup for basslines. The Mobius and the Neptune are eminently tweakable in real time. |
