Simmons SDS 3 - DIY?
Page 7 of 15 [354 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, 9, ..., 13, 14, 15 Next
PostPosted: Wed Aug 06, 2008 12:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Coriolis wrote:
800mil vertical spacing
Eh? What's that in mm?
C
20.32mm Very Happy
Coriolis
PostPosted: Wed Aug 06, 2008 1:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Btw: Mono, that SDS3 demo you posted sounds lovely! For some reason I can't play the second one, but the first one did the trick for me Very Happy
Does anyone have a clear, top-down shot of the front panel of the SDS3?
Just to get an idea what's on there...
C
PostPosted: Wed Aug 06, 2008 2:29 am    Post subject: Reply with quote  Mark this post and the followings unread
A mil is a milli inch.
Coriolis
PostPosted: Wed Aug 06, 2008 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I see - thanks guys.
C
mono-poly
PostPosted: Wed Aug 06, 2008 2:40 am    Post subject: Reply with quote  Mark this post and the followings unread
http://farm1.static.flickr.com/45/116962226_8a8b75b2d4.jpg
I'd rather not see pots mounted on the pcb but i always can wire from there.
Are the gonna be some mods added like cv control?
asafnetzer
PostPosted: Wed Aug 06, 2008 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I think that pcb mount hardware can help and make a cleaner looking board and if some of us wants we could always add wires instead.
I'm not afraid of the overall size as I think this should be a standalone module, but maybe thats just me. Wink
bubblechamber
PostPosted: Wed Aug 06, 2008 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
we won't be matching trannies on this...
i should get a lot more work done today... i'll post a preliminary panel layout
as soon as i get it done
PCB mounted hardware will make the layout a lot easier. with a little luck we'll have this wrapped up in the next month or so....
There will at least be a CV for the pitch control.
david
You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same.
mono-poly
PostPosted: Wed Aug 06, 2008 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
On the orgional sds3 there were 3 drumchannels.
And one modulator channels with 2 lfo's if i remember right.
These could be routed to the pitch and the decay if i'm right.
bubblechamber
PostPosted: Sun Aug 17, 2008 8:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
got a little sidetracked, but it's been a productive weekend.
does anyone have a really clear close up of the front panel? the schematic doesn't really make clear what's a trimpot and what's a panel mounted... my instinct is to bring all trimpots to front, within reason.
Do we want the distortion null pot on the front?
it's looking like a single voice will fit into a eurorack panel...
i'm sure more questions will be coming up as this gets further along.
d
 Filesize:  297.21 KB
 Viewed:  426 Time(s)
stijn
PostPosted: Fri Aug 22, 2008 6:39 am    Post subject: Reply with quote  Mark this post and the followings unread
oooh man, just discovered this thread. an sds3 clone lovely!
if there is going to be a pcb manufacturing run, I'm up for 4 at least Laughing Laughing Laughing
Luka
PostPosted: Fri Aug 22, 2008 6:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
im looking forward to this also
im looking to make a companion to my mb808, ill call it the mb828.
this along with the THMPS and some 909 kick/snare/clap will make some nice voices
problemchild
melbourne australia
Danno Gee Ray
PostPosted: Fri Aug 22, 2008 6:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd possibly be in for one as well.
bubblechamber
PostPosted: Fri Aug 22, 2008 9:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
just about done with the layout...i'll start the double checking and testing next weekend.
if this works i'm thinking about doing a run of these. when it get closer to done i'll make a real announcement. looks like they'll cost around $8-10US each.
As Fonik predicted there is just not enough room for the pots to be PCB mounted if the PCB is to fit in a eurorack/frac faceplate and still be single sided for those that want to roll their own...
What I've decided to do is use a ribbon connector and a second board for the pots, jacks and switched. The header rows are around the edge of the board, so it should be pretty easy to wire up if you're putting it in something other than a Eurorack faceplate.
i'll keep you guy posted as this glacier slowly slide into the sea.
david
bugfight
PostPosted: Fri Aug 22, 2008 9:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
if you want to home etch this, you should make the traces much fatter.
in fact, i'd do that anywayz...
if you do a run, i will be in.
the mighty queue needs feeding, after all...
PostPosted: Sat Aug 23, 2008 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
maybe this would be the right to time to make a decision: double sided professional PCB run or singlesided.
i'd preferred professional manufactured PCBs, no panel mount controls, circuit divided in voice and main boards, maybe just voiceboards...
what do you think?
bubblechamber
PostPosted: Sat Aug 23, 2008 11:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
they'll be 3 or 4 times as thick for the Press N Peel version, it's just easier for me to work with thin traces in the layout phase...
what do you think?
I think the boards are going to be complete voices, no PCB mounted pots. i'll post a P'nP layout for a control board in a eurorack layout...
i've been thinking pretty seriously about doing a small run just for me and a couple of friends. I want at least 8 of these and I really don't want to etch and drill that many.
i'll do a broader announcement next week and see what kind of interest there is in this, right now there are 25-30 spoken for so we don't need that many to get a good price on these.
it shouldn't be more than $8US each for the PCB, i'd like to get it down lower. there's a pretty big price break at 100. i'd love to see some 8 voice SDS3...
I will probably use MyroPCB, I've ordered boards from them before and I've been very happy with their work.
filterstein
PostPosted: Sun Aug 24, 2008 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Great, I can't wait Very Happy
Statick
PostPosted: Tue Aug 26, 2008 6:37 am    Post subject: Reply with quote  Mark this post and the followings unread
hi, i just registered here to post on this thread
i recently acquired an SDS 3. it really is quite awesome!
i'm only borrowing it however, but i am trying to convince the owner to part with it (wish me luck!). any idea what a fair price is for an SDS 3 and a single pair of pads ?
anyway, i would be very interested in some of these PCBs so add my name to the list. also if i can help in any way by virtue of having a real SDS 3 sitting right next to me, just let me know.
SineSurfer
PostPosted: Tue Aug 26, 2008 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I may be interested in a couple of boards too.
Statick: do you think you could share some SDS 3 sound samples?, been searching the web for some without any luck
mono-poly
PostPosted: Tue Aug 26, 2008 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
There are 2 examples from a sds3 in this tread somewhere.
SineSurfer
PostPosted: Tue Aug 26, 2008 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
duh!, two of those examples are yours it seems mono-poly Smile
http://www.electronic-obsession.se/studio/simmonssounds/sds4.mp3
http://modular.googlepages.com/sds3.mp3
http://modular.googlepages.com/sds3b.mp3
So, each channel is capable of doing the whole range of sounds then(bd, snare, etc.)?
looks like I'm in for 3 pcbs Wink
Statick
PostPosted: Tue Aug 26, 2008 4:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
sure, i'll record some stuff when i get some spare time (which i don't have a lot of at the moment). anything in particular or just a range of stuff ?
Statick
PostPosted: Tue Aug 26, 2008 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes, each channel is identical
SineSurfer
PostPosted: Wed Aug 27, 2008 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Statick wrote:
... anything in particular or just a range of stuff ?
Thanks Statick, the previous examples got me convinced already Wink
Dego
PostPosted: Fri Oct 03, 2008 4:31 am    Post subject: Reply with quote  Mark this post and the followings unread
How is this project developing? Smile No hurry. Just thinking on it...
