Electro-Music Klee Sequencer Build and Applications Thread
Page 47 of 54 [1348 Posts]
Goto page: Previous 1, 2, 3, ..., 45, 46, 47, 48, 49, ..., 52, 53, 54 Next
Photon
PostPosted: Sat Nov 08, 2008 2:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok...I'm getting pulses on pin 15 of the CD4034s in time with clock signal, but it doesn't seem to be anywhere near a 15V signal, perhaps more like 0.2V. (but than again my scope hasn't been calibrated since about 1977 or so. Very Happy )
When I send an LFO signal into the external load jack I'm not able to see anything on pins 13 or 14.
The LFO into external load jack is causing the pattern LEDs to light. Clocking or pressing the manual step button repeatedly causes them to go off sequentially.
I'm going to try again to see if I can see anything at pins 13 and 14 with the external load input.
Photon
PostPosted: Sat Nov 08, 2008 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok, I've got pulse at pins 13 & 14 of the CD4034s with external load. I had to mess with the scope settings a bit.
over & out,
Papa Echo Tango Echo Romeo
Scott Stites
Audio files: 96
PostPosted: Sat Nov 08, 2008 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good! If the LEDs are lighting when you apply the external load pulse (and you're seeing the pulses) that means the CD4013 is doing its thang, and the CD4034s are receptive to it.
Now - if pressing your load key doesn't do anything, that means we'll have to address that, but first lets see if we can figure out why your LEDs are turning off sequentially.
If you've got all of your pattern switches on, so that the whole row lights up, then they sequentially turn off as you clock the thing, that would mean that your CD4034s are also clocking correctly and could be explained by the signal not getting back to their inputs. You can check that (if you haven't already) by loading only one LED, say the first one on Register A (Step 1). If that LED moves across the row before it disappears, that will tell us a lot right there. So - can you clock one illuminated LED across the row before it disappears?
My Site
Scott Stites
Audio files: 96
PostPosted: Sat Nov 08, 2008 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh - wait a sec - are you still only getting 0.2V clock pulses? Is that on your scope or DMM, and if your scope, it's not AC coupled is it (should be DC coupled)? Just covering bases. Very Happy
My Site
Photon
PostPosted: Sat Nov 08, 2008 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
It seems the random switch was thrown. I returned it to the pattern position. Loaded Register A (Step 1) LED and applied ext. clock. In the 8x2 mode, LED moved sequentially up to 8, then repeated. In 16 x1 mode, they moved sequentially all the way to 16 then repeated. Good news. Very Happy
When the random switch is thrown they go off sequentially. not sure if that's proper. Also LED 13 seems to be not lighting. I'll check to see if its dead or wired wrong.
Klee Sequencer debug
Scott Stites
Audio files: 96
PostPosted: Sat Nov 08, 2008 3:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow! Sweet wiring job! Where are all the dead components and other crap laying around? Get with the program!! Laughing
OK, yep - random input will do that if there is nothing feeding the random input. If it's in 8X2 mode, just the first 8 LEDs will "walk off" and never return - the last 8 (register B) should keep recirculating. In 16X1 mode, they'll all walk off.
The LED that's not lighting: Due to my skilled proficiency with making wire harnesses, I never have to check that, no, never, not me, but, you know, if I did ever have to check that, I'd, um, check the pot associated with the LED. In other words, check the the outer lug of the pot for step 13 (the side that's not wired to ground) when LED 13 lights up. If you get a voltage on the pot, but the LED doesn't light up, then the problem is the connection between LED 13 and J9.
If you don't get that voltage on the pot for step 13, and the LED isn't lighting up, either, then you might want to check the output on the CD4034 to be sure it's doing it's thing (pin 4 of U7). Generally, though it never, ever happens to me, mind you, no, it's usually the connection to the connector (the signal from the CD4034 splits at that point - one goes to the LED and one goes to the analog board for scaling).
How about your Load key - is it working?
My Site
Luka
PostPosted: Sat Nov 08, 2008 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
i think we need to start a inside-klee picture thread Smile
problemchild
melbourne australia
Photon
PostPosted: Sat Nov 08, 2008 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
good idea.
If you click on the above picture, it will take you to my flickr site where there's a bunch of inside the Klee pics.
Luka
PostPosted: Sat Nov 08, 2008 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
though we might scare people away from future runs of the sequencer hehe
problemchild
melbourne australia
Photon
PostPosted: Sat Nov 08, 2008 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
they're on the floor! I thought the wiring job was sweet too, until I tried to close the case! Thanks, though.
Good idea. I'll give it a look.
Not sure what you're referring too. Do you mean Manual load switch?
Scott Stites
Audio files: 96
PostPosted: Sat Nov 08, 2008 4:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, that's the doohickey I meant.
USDA regulations prevent pictures of the inside of my Klee from being publically distributed. Something about a rodent nusiance or some such rot....
My Site
Photon
PostPosted: Sun Nov 09, 2008 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok...the load switch works (electronically speaking). In other words there is continuity between lugs when I push the button. However it doesn't seem to load a pattern.
And things have gotten weird(er). Now the LEDs light up and STAY ON across the front panel (independent of pattern switch position as far as I can tell). when it gets to 16 (all on), they shut off one at a time, starting at 1. Then it starts again (lighting up, 1-16). If I switch to 8x2 it just happens to LEDs 9-16 (excluding 13 which doesn't ever light up).
If I throw the invert B switch, a group of 4 LEDS move across the panel. in 8x2 mode with invert B on I can get 2 different patterns in each half.
about LED 13:
I checked out Pot 13 and I'm getting a voltage at the outer lug when LED 13 should be on. I checked the J9 cable and it seems to be fine. Also I was able to get LED 13 to light by powering it directly, so the LED is good.
Hopefully my description isn't misleading. I'm even confusing myself. maybe I'll shoot a video of the symptoms
Scott Stites
Audio files: 96
PostPosted: Sun Nov 09, 2008 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
As I understand it, the external load works, though, right? That would mean that a good chunk of the circuitry is working correctly. This is a good thing.
1. On the switch, make sure one lug has +V on it, and the other lug is connected to digital ground.
2. Make sure that pin 5 of U2 has +V on it (when the load switch isn't pressed).
3. When the load switch is pressed, it grounds the +V through R27. This change is coupled through C11 to pin 5 of U2. Using your oscope, you should see pin 5 of U2 pulse down to around 0V and back up. This will not be a square pulse, but curved and stuff.
4. Pin 6 of U2 should, however, quickly pulse from low to high very quickly and very crisply each time you press the manual load switch.
Let me know if you see all of the above....
OK - just to double-check: When you send an external load, does the pattern, as you have it selected by the pattern switches, load as expected (discounting LED 13)?
It sounds to me like Invert B is probably wired backwards. With Invert B off, the patterns are allowed to recirculate. Or....hmmm, that video is sounding better and better... Very Happy
about LED 13:
Maybe or maybe not. Do you get a voltage at the anode of the LED when it should light?
If the voltage on the pot returns to zero when LED 13 is not supposed to be illuminated, then the CD4034 (U7) is throwing out the voltage OK (the result of which is what you see on the pot). It sends the voltage to two places. The voltage passes through J7 over to the analog board, where it switches a CD4066 to pass the range voltage to the pot. Again, like I said, if the voltage on the pot goes low after the bit "passes" LED 13, then that is all working.
The other path this same signal takes is straight from pin 4 of U7, through R44 (6K8 resistor) then to pin 4 of J9. From pin 4 of J9, it scurries up your wire harness and tickles the LED.
So:
1. Check that a voltage actually does go high on the anode of the LED when it's supposed to light up.
2. If the voltage doesn't go high, check continuity from the anode of the LED to one lead of R44 - you should have direct continuity.
3. Check continuity from the other lead of R44 to Pin 4 of U7 (the CD4034) - again, you should have direct continuity.
You can also check to see if the voltage goes high on either end of the resistor when the LED is supposed to light.
That might be spiffy. I'm having a bit of trouble figuring out what exactly is going on with the Invert B Switch. We may have some funkiness going on with the switching of the CD4053. In the theory of operations thread, it's illustrated a little better for understanding what should be happening in the modes - you might poke around there a little, too, which may or may not make a light go off over your head.
Lemme know whatcha find......we'll get this licked!
Take care,
Scott
My Site
Photon
PostPosted: Sun Nov 09, 2008 5:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Scott.
I'll read through the theory of operations thread a few times. Its been a while since I looked at it.
I'll also check through the stuff you suggested. If I get some time I'll try to shoot some video and get it posted. Hopefully there are a couple more weeks before the baby arrives. (yes, our first!)
baby=no time for synthesizering Shocked Very Happy
Scott Stites
Audio files: 96
PostPosted: Sun Nov 09, 2008 6:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Baby? Did I miss something here? Are you a new daddy?
My Site
Photon
PostPosted: Sun Nov 09, 2008 7:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, baby is due in the next few weeks. Very Happy
Disregard my last post. Part of my problem is a combination of things not working properly and me not completely understanding Klee operation. I'm going study up on all the great doc.'s you've provided, then I'll be better able to describe whats going on. Thanks for all your help & patience Scott.
Pete
Scott Stites
Audio files: 96
PostPosted: Sun Nov 09, 2008 8:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, sir, congratulations!!! Very Happy
There's no other DIY* project that compares....
Cheerios,
Scott
*Yeah, it takes two, but you get my drift....
My Site
sduck
PostPosted: Sun Nov 09, 2008 8:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't worry - I did the same thing, asking about how to fix things that weren't broken, because I hadn't really understood the theory and operations. It's all good!
And there is a pic of the back of my klee on page 11 of the post your panel designs thread.
Funky40
G2 patch files: 5
PostPosted: Sun Nov 23, 2008 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
i'm not shure if i should make my Klee panel with an additional row of LEDs which just would show which steps are active.
Does this makes sense or do you allready have enough optical feedback when looking to the blinking lights ?
I'm not shure after looking to the Videos.
@Scott
i have drawn the A-B/B-A circuit into a little Board while waiting for the Epoxy to dry.
I assume it would be ok to post it here, is it ?
http://electro-music.com/forum/phpbb-files/pimped_klee_ab_424.png
Scott Stites
Audio files: 96
PostPosted: Sun Nov 23, 2008 9:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Go ahead and post the circuit!
Not sure what you mean about the LEDs - do you mean over each pattern switch that stays static and shows which are on and which are off for a particular pattern? If so, might be kinda cool, actually. When I find a pattern I like (randomly or whatever), I'll stop the clock and program it in so I can get back to it. That involves flipping switches on under every lit LED and flipping switches off that are under every off LED. An extra row of LEDs would make that easier to do, especially in the dark - set the switches so that each row of LEDs is identical. Then start the sequence and the active row begins to move. Very Happy
Spiff. You could do it with DPDT ON-OFF switches instead of SPST ON-OFF switches for the pattern switches.
Cheerios,
Scott
My Site
Funky40
G2 patch files: 5
PostPosted: Mon Nov 24, 2008 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep, thats the Idea
Yes, this was exactly my thought.
ok, then i can keep my Dotcom layout, and must see if i not go for 4 HU instead of euroformat for the small one.
Cheerios,
Scott
ok
thanks Scott !
plord
PostPosted: Tue Nov 25, 2008 12:28 am    Post subject: Documentation bug
Subject description: P213, page 49
Hi folks,
First off, let me say that the documentation for the Klee is awe inspiring. But I think I have found a bug. The description of the wiring harness for P213 on page 49 does not match the connection diagram for P213 on page 64. Looking at the schematics, it appears that page 64 is correct; pin 1 goes to Output B, NOT to optional output A; page 49 has it all reversed. Right?
I only discovered this because I am not including the optional outputs, so my wiring harness only had 3 wires in it...and when I got to p 64 they were the wrong ones!
I searched for P213 and got no hits. Am I the first to run into this?
PostPosted: Tue Nov 25, 2008 1:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I think you're right plord.
And yes, I think you're the first to notice that mistake! Very Happy
Wasn't that the secret "Holiday in the Bahamas" Easter Egg mistake Scott? Laughing
Funky40
G2 patch files: 5
PostPosted: Tue Nov 25, 2008 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
puhhhh, allready 47 sites Shocked
My little Artwork for the A-B/B-A Klee addon from Scott stites is now posted in the Layout Factory.
It is untested.
http://www.electro-music.com/forum/post-216978.html#216978
it was mentioned bevore: it might be also interesting as a little standalone unit
Scott Stites
Audio files: 96
PostPosted: Tue Nov 25, 2008 8:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
My apologies, plord! I know what a drag it is to go to the trouble of building a cable. Then the damn thing has the wrong wires.
Thanks for reporting it - Build Issue 6 now corrects it.
Cheerio,
Scott
em_klee_build_issue6.pdf
electro-music Klee Build Document, Issue 6
 Filename:  em_klee_build_issue6.pdf
 Filesize:  1.81 MB
 Downloaded:  5326 Time(s)
My Site
