Simple discrete synth
Page 1 of 1 [17 Posts]
Tenine
PostPosted: Fri Nov 21, 2008 8:25 am    Post subject: Simple discrete synth
Subject description: I've set myself a challenge
I'm planning to build a monosynth to use in my music (Think 80's 4AD ethereal stuff and MBV) and for live performances.
I have a pretty good knowledge of synthesis and have owned a Clavia NL2X for a about 4 years or so.
I want the synth to be pretty compact (maybe 13" square), so I'll be using a 32-note mini keyboard from an old Casio.
I'd be happy with the architecture being as simple as
one Oscillator with waveshaping,
one AR Envelope Generator
and a Lowpass Gate (maybe two of these).
I know I will be basing my oscillator on the UJT osc shown here - http://www.aaroncake.net/Circuits/torgan.asp
I don't plan to allow any external control interfacing, as it will be very much a performance synth (No, I don't mind the mini keyboard haha!).
Because of that, there's no real need for it to follow any industry standards as such.
Just preparing and writing down thoughts a the minute.
I will need -
Info on resistor-chain keyboards.
Keyboard CV S&H circuit.
UJT Oscillator circuit.
Waveshaping circuit.
AR Generator circuit.
Lowpass Gate circuits.
Am I overlooking anything?
Oh yeah, and this is the good part, this is kind of setting a challenge for myself, because I want to keep it as simple as possible and avoid using ICs!
Alternatively, I could make a fully polyphonic synth (I know I said simple ha!) using said circuits (less the Keyboard CV S&H), effectivly one synth per key. I could add global control over different parameters via lots of homemade vactrols (it may be frowned upon by some, I'm not sure, but I quite like this idea!).
Does anyone have any thoughts or suggestions please?
There's not many people I know who are into synth DIY so I just had to type out my thoughts and see what other people thought and if anyone gets my vibe on this thing!
Cheers!
snufkin
PostPosted: Fri Nov 21, 2008 8:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi just wanted to say
i am building a synth in a similar vain
i went for the sn voice circuit board it uses ICs but its easy as pie (i had only built guitar pedals before making it)
the sn voice is almost a whole mono synth in a single board !
a good power supply is also a must!
Dave Kendall
PostPosted: Sat Nov 22, 2008 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi.
Juergen Haible has some excellent info here which may give you some ideas.
The single transistor VCA has had favourable comments on the sdiy list IIRC.
good luck Smile
Tenine
PostPosted: Sat Nov 22, 2008 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey, thanks!
The single transistor VCA looks ideal - It'd go well with the Lowpass Gate, I'm sure.
I think some other Korgs use a similar circuit.
Tim Servo
PostPosted: Sat Nov 22, 2008 7:51 pm    Post subject: Simple discrete synth Reply with quote  Mark this post and the followings unread
Hey Tenine,
Another source for some simple schematics (many use only transistors, or just a few op amps), would be the PAiA 2700 series. Maybe check the PAiA web site, or just Google away. You should also check the slightly improved PAiA 4700 series. You might also look up Korg MS-10 and MS-20 schemos. I was wondering why you want to avoid ICs? There are cases where an IC (like an op amp) can actually make a circuit easier to construct. For example, look at the PAiA Gnome, which uses a bunch of transistors and one LM3900 IC to make a pretty neat compact synth.
Have fun with it!
Tim (not a Gnome, but I play one on TV) Servo
stolenfat
PostPosted: Sun Nov 23, 2008 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
what about adding some glide/portamento to give it some thing special.
I've seen schematics out there for some really simply lag units.
Pehr
PostPosted: Sun Nov 23, 2008 2:05 pm    Post subject: Re: Simple discrete synth
Have you seen the VCS3 schematics. Most of them are discrete:
http://electro-music.com/forum/viewtopic.php?highlight=vcs3+clone&t=29387
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
nicolas3141
PostPosted: Tue Nov 25, 2008 3:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I am currently building op-amp based stuff, but tending towards simplicity rather than sophistication in my designs. So I am very interested in the all-discrete challenge. One thing that would make a discrete synth easier to achieve is not attempting to go for accurate 1V/oct tuning. If you go for the V/Hz standard as per MS20 it makes it a bit easier. And if you don't worry about perfect linearity it makes it even easier. The difficulty is then that your controller (keyboard, etc) has to be correspondingly non-linear. Not such a problem if you plan to use a ribbon controller. Slightly harder if you are building a keyboard. More of a headache if you want midi control. The guys doing tube stuff are my inspiration for this approach. See http://www.cgs.synth.net/tube/index.html
Keep us posted on your thoughts and progress.
richardc64
Audio files: 26
PostPosted: Tue Nov 25, 2008 6:20 am    Post subject: Reply with quote  Mark this post and the followings unread
The R portion of an AR generator won't be of much use with that oscillator: it stops oscillating when a button or key is released.
Richard (wet blanket) C64
nicolas3141
PostPosted: Tue Nov 25, 2008 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
The release sound only is a problem with a conventional organ/piano type controller where the key press is both a pitch selector and a gate/trigger/volume all in one (although volume is generally a pedal thing with organs).
With a more guitar-like controller you might have one hand selecting the pitch and the other hand doing the gate/trigger/volume control.
Or a sax-like controller with both hands controlling pitch, while the gate/trigger/volume stuff is under breath control.
That's the beauty of DIY instrument making. Outside the square is a place we are free to go to.
Tenine
PostPosted: Tue Nov 25, 2008 2:41 pm    Post subject: Re: Simple discrete synth Reply with quote  Mark this post and the followings unread
Tim Servo wrote:
I was wondering why you want to avoid ICs? PAiA Gnome, which uses a bunch of transistors and one LM3900 IC to make a pretty neat compact synth.
I hadn't checked out the Gnome before, thanks for that Tim.
I'm not sure there's anything I will take from those circuits, but it's nice to see transistors used as buffers instead of op-amps, and on a single-ended PSU too! I'm planning to use 18V or +/-9V.
I just enjoy working with discrete circuits, I'm not really sure why.
Yeah, I could do. Could also be used for slurring Gate signals, so you get a slower Attack and a bit of Release.
True, which is why I need to build a S&H for the keyboard CV, so the CV is held after the key is released.
There's some experimentation to be done first though- need to get some UJTs!
I hadn't seen them before, they're much too complex for this particular project, but I'll make a copy of the schematics for the future. Thanks!
Tenine
PostPosted: Tue Nov 25, 2008 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd completely forgotten about Ken's tube-based synths, inspiring stuff, thanks!.
You seem to really understand what I'm trying to build.
Have you got any photos of what you've built? I'd be interested in seeing your results.
richardc64
Audio files: 26
PostPosted: Wed Nov 26, 2008 4:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a reprint of the orginal Radio-Electronics article for building the PAIA 2720 modular synth. Uses very few ICs. The VCO uses a UJT.
http://www.paia.com/manuals/docs/2720-buildamodular-article.pdf
(2.6MB)
I also found this
http://web.media.mit.edu/~joep/papers/EarlySynthesizerReport.pdf
which is largely based on the 2720, but more complex. Not the clearest of documents. (10MB)
nicolas3141
PostPosted: Sat Nov 29, 2008 1:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Have a look at this stuff - lots of the modules are discrete transistor based :
http://home.earthlink.net/~synthfred/h_toctop.htm
Tenine
PostPosted: Mon Dec 01, 2008 4:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Nicolas. I looked at the link briefly on Saturday (I was at work) and it looked very promising, but unfortunately it's dead now.
Do you have any of the schematics saved please?
How's your synth going?
phdinfunk
PostPosted: Mon Dec 01, 2008 7:08 am    Post subject: UJT oscs
Subject description: experience..
I briefly played with these. I actually really liked them as they're easy to make and mine worked fine (I didn't have a keyboard to test tracking or anything at the time). Also, the sound was cool. The UJTs I had sounded really grungy and badazz.
nicolas3141
PostPosted: Mon Dec 01, 2008 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
A UJT used this way is a bit like a schmitt trigger in a single package. But if you want to build the equivalent circuit from more common components you can build a simple discrete schmitt trigger with an NPN a PNP and a few resistors. You give yourself more options for voltage switching points, etc. and you are more likely to have the bits onhand than a UJT. Add a cap and you have an oscillator.
