<on air> Twyndyllyngs Chez Mosc
Living VCOs
Page 2 of 21 [520 Posts]
Goto page: Previous 1, 2, 3, 4, ..., 19, 20, 21 Next
Would you prefer one PCB with 3 VCOs a la JH-5A, or 1 VCO per PCB with more features
One PCB with Oscillator Driver and 3 VCO cores (like JH-5A - cheap!)
60%
 60%  [ 62 ]
1 PCB = 1 VCO (with many waveforms and inputs)
39%
 39%  [ 41 ]
Total Votes : 103
jhaible
PostPosted: Wed Dec 10, 2008 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's the frontpanel of the JH-5A, which shows what features a combination od Oscillator Driver + 3 VCOs would have.
JH.
Now playing: Tori Amos, American Doll Posse
jh5_front.pdf
 Filename:  jh5_front.pdf
 Filesize:  119.9 KB
 Downloaded:  1320 Time(s)
Audio files: 326
PostPosted: Wed Dec 10, 2008 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
Is there a way to add a poll on a thread that's already in use?
Yes, by editing the first post of the thread.
jhaible
PostPosted: Wed Dec 10, 2008 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you!
JH.
jhaible
PostPosted: Wed Dec 10, 2008 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Poll added - please vote!
JH.
Luka
PostPosted: Wed Dec 10, 2008 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
i voted for single as it makes more sense to me
however now i think about it almost all modules in my synth are duals or quads so perhaps im easy either way
problemchild
melbourne australia
/mr
PostPosted: Wed Dec 10, 2008 4:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
vtl5c3 wrote:
I'm interested. Are we talking one VCO per board or more?
Romeo
That's a good question.
Depends on how many waveforms you need.
In the JH-5, there's only saw and pulse (with PWM) and one Oscillator Driver controlling 3 VCO cores. This can be very compact. Maybe (maybe!) 3 VCOs on a single 27 Euro PCB.
If you want full fledged VCOs with all waveforms and all kind of modulation inputs, it's probably one VCO per board.
Given that linear detune is mostly useful when more than one VCO signal is combined, and that many users can lose the point if the module is a single VCO, I definitely think this design would be best with a dual or triple unit. For me that feels much more valuable than having all kinds of sugar on it. Smile
I've been thinking of different variants of the theme... for instance a dual oscillator with a common Detune pot that tunes the VCOs in opposite directions, and a Balance pot that sets their relative amplitude AND keeps them in "weighted well-tunedness" by tuning them so that the louder "heavier" VCO is closer to the base frequency. If you get my point. Laughing
The reason for balancing them to different amplitudes could be the probably well-know fact that the fundamental (or bass, or "body") component of the sound fades in and out if you sum two similar waves with slight detuning. Then I thought about the possibility to have the lower harmonics coming from one single un-detuned VCO and the higher ones from two or more linearly detuned VCOs. The "detune sound" would then appear in the range at the top where it's good to have it, and the bass/body range is stable and solid. The HP/LP filters between the two ranges would probably need to follow the VCOs pitch though, which might make it less straightforward in analogue hardware...
Another solution for this would be to only have the very fundamental coming from one sine VCO, and then add a couple of linearly detuned VCOs with their fundamentals removed. This is actually very doable, and I realize just now when writing this that maybe that's what you should try if you want to add a new invention to it? Very Happy
(CS-50 owners of the world unite - we all know how good it is to add the sinewave bottom after finishing the creamy goodies at the top)
Sebo
PostPosted: Wed Dec 10, 2008 5:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
A triple VCO is very appealing to me.
[/quote]
Sebo
My Music:
Dego
PostPosted: Thu Dec 11, 2008 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
[/quote]
I want one!
numbertalk
PostPosted: Thu Dec 11, 2008 7:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I voted for the triple VCO as well.
a_guy_called_tom
PostPosted: Thu Dec 11, 2008 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
i would be very interested (2-4 vcos), assuming it works with +- 12 volts, the pcb is small enough for eurorack and there aren't any really hard to get parts needed.
sounds like a great project!
tom
mono-poly
PostPosted: Thu Dec 11, 2008 10:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd love to see a Buchla 158 or 144 like vco.
Simple vco with 1 waveform output.
But great fm and/or am sound.
frijitz
Audio files: 54
PostPosted: Thu Dec 11, 2008 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I proposed doing this several months ago, but there wasn't much interest:
http://electro-music.com/forum/topic-28713.html
I guess if it doesn't say M... or B..... it's gonna get killed by the fanatics.
Ian
bugfight
PostPosted: Thu Dec 11, 2008 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
hehe which fanatic will try to kill the "living" vco?
mono-poly
PostPosted: Thu Dec 11, 2008 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ian
Hmm Ian
That might be interesting for me.
Someow i did mis that.
Do you want me to make some examples with fm and am on some old Buchla ones?
johans121
PostPosted: Thu Dec 11, 2008 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be interested in both JH's & Ian's. More VCO's the better.
Don't feed me Indian, you WILL regret it!
-Jim
Peake
PostPosted: Thu Dec 11, 2008 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ian
Or E... or O... or SSM... or T... or... well, you get the idea...
And what oscillators AREN'T living???? You use the "living" adjective to describe something desirable...as opposed to something undesirable??
jhaible
PostPosted: Thu Dec 11, 2008 4:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't think of it as an adjective in the first place - it's intended to be a *name*. I like it better than "JH-5A, VCO section".
The first post in this thread describes the idea behind it.
These will be *cheap* VCOs: unexpensive components, 3 VCOs on a single PCB (if I follow the poll), not the best precision that could otherwise be achieved, but with some design details that may (or maybe may not) make them interesting for a few people nevertheless.
JH.
numbernone
PostPosted: Thu Dec 11, 2008 7:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am interested in several triples if "cheap" falls into my definition.
Oh hell I would probably take several regardless.
frijitz
Audio files: 54
PostPosted: Thu Dec 11, 2008 10:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, loud and clear. You are going to dump on *anything* new.
jhaible
PostPosted: Fri Dec 12, 2008 12:32 am    Post subject: Reply with quote  Mark this post and the followings unread
If I go for it, it probably will be the usual 160mm x 100mm board for 27.00 EUR.
If I don't get 3 VCOs on such a board, I'll probably go for 2 on the same size.
(It's not just a matter of how densely I can populate the boards, but also of preventing them from unwanted sync effects.)
I think 27.00 EUR would be a good price even for 2 VCOs per board - but my goal is 3.
JH.
TekniK
PostPosted: Fri Dec 12, 2008 1:32 am    Post subject: Reply with quote  Mark this post and the followings unread
2 vco's on one pcb is ideal Juergen,but would be perfect if u just could add sine for both 2 on the pcb
Tenine
PostPosted: Fri Dec 12, 2008 9:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks pretty interesting to me!
This could be a nice first module that follows the 1V/Oct standard.
What sort of parts will be needed?
Just standard op-amps or OTAs? Anything that's hard to find outside Europe?
Thanks.
Tenine
Thanks.
jhaible
PostPosted: Sat Dec 13, 2008 2:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks.
No special parts, as far as I can tell now.
I have to look inside what I've built to check what transistors I've actually used, but the simulation files show the trusty old BC550C and BC560C everywhere.
You will need a differential pair per VCO, of course.
I'll provide footprints for different options here.
The Oscillator Driver in what I've built has a 3080 OTA for aftertouch-controlled vibrato, but it's easy to replace this with something less obsolete in the PCB version.
JH.
fluxmonkey
PostPosted: Sat Dec 13, 2008 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
i polled in for 1-osc-per-board... altho i'd probably build a set, my thinking is that separate boards would make the physical build easier: i usually have lots of ins and out on my oscillators (multiple modulations etc) and the number of flying wires can get pretty ratsnest; individual boards would help divide and conquer that confusion.
along the same lines, i also find it helpful to have the modulation ins and the outputs routed to headers that are physically proximate, and ideally near the edge of the board... again, for sanity in construction. board-mounted pots sometimes serve the same idea, but aren't as useful to me 'cause i build in frac and most such pots are spaced for 5u... but its sort of the same idea. of couse, this is secondary to requirments to electically isolate sections from crosscoupling, etc.
just my input, j. in any event i'm in for this. much appreciated as always!
b
www.fluxmonkey.com
