xpander
Joined: Nov 16, 2008 Posts: 25 Location: san josé, california
Posted: Sun Dec 07, 2008 5:07 pm Post subject:
| do you have any extra boards leftover?? i'd still like a couple. |
a_guy_called_tom
TekniK
Posted: Mon Dec 08, 2008 12:28 pm Post subject:
10x Tom!  |
Appliancide*
Joined: Jul 04, 2007 Posts: 126 Location: Paul lives in a 1920’s film
Posted: Mon Dec 08, 2008 3:55 pm Post subject:
| a_guy_called_tom wrote: | | djthomaswhite wrote: |
Please post details of your power hook up... Looks like goes to Doepfer?
Yep, mine's connected to a Doepfer power rail, plucking happily using +- 12 volts
For those preferring to use a dual vactrol, heres how to do it (Thanks to Ilanode for explaining it to me). Make sure you isolate the crossing legs well and don't mix up the anode and cathode of the led. |
Thanks for the dual vactrol advice! I just picked up a couple in a trade and was wondering if they would work.
Paul _________________ http://appliancide/blogspot.com |
sduck
Posted: Tue Dec 09, 2008 6:25 pm Post subject:
Ok, show and tell time. Just finished my version of the complete bells and whistles version. Based my panel on Thomas Whites design, with several changes.
The back - unlike previous builds, I didn't have to use cable ties this time - the wires all seemed to fall into place on their own.
These images and more are on my flickr page, if you want to see bigger images -
http://www.flickr.com/photos/sduck409/
Thanks Thomas (and team) for the great pcbs! It sounds fantastic!
646.18 KB |
| Viewed: |
345 Time(s) |
1.03 MB |
| Viewed: |
381 Time(s) |
fadeddata
Joined: Dec 27, 2004 Posts: 43 Location: Nashville TN
Posted: Sat Dec 13, 2008 10:08 pm Post subject:
Ok, show and tell it is! I'm going to be wiring this up tomorrow morning
-dustin
168.18 KB |
| Viewed: |
343 Time(s) |
160.13 KB |
| Viewed: |
328 Time(s) |
BananaPlug
Posted: Sun Dec 14, 2008 7:30 am Post subject:
| Very nice. Which method did you use for the panel graphics? |
fadeddata
Posted: Sun Dec 14, 2008 7:47 am Post subject:
I used an Epilog laser engraver that I have access to. The pictures don't really do it justice. I'm repeatably amazed at how well laser engravers work. We should all go in on a group buy for one
-dustin |
slo
Joined: Feb 18, 2007 Posts: 204 Location: Victoria, BC
Posted: Sun Dec 14, 2008 9:36 am Post subject:
| Quote: | Ok, show and tell time. Just finished my version of the complete bells and whistles version. Based my panel on Thomas Whites design, with several changes.
Sduck, vey nice job.
Can I ask what the CTRL input is? is it just a straight in CV? as you went with 2 other CV inputs.
George |
sduck
Posted: Sun Dec 14, 2008 8:55 pm Post subject:
Yes, the control in is just a cv in without a pot.
And hopefully Dustin will post pics of the back of his LPG after he wires it all up - he showed me some of his work the other day, and his wiring is incredibly immaculate. And it's pretty fantastic looking from the front too! |
LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Posted: Sun Jan 04, 2009 2:55 am Post subject:
What is everyone doing for the 50KΩ resonance mod resistor? I've not managed to source a 50KΩ resistor anywhere. Can I put a 47KΩ and a 3KΩ in series to make this value, or is it not critical to get it exact and get away with a 47KΩ on its own?
Also, must the 4.7MΩ resistor be carbon? I only have metal film |
Posted: Sun Jan 04, 2009 3:30 am Post subject:
| LektroiD wrote: | | Also, must the 4.7MΩ resistor be carbon? I only have metal film |
Metal film is better, so just use that one.
As to the other resistor, 47k probably will be fine (usually it is, but I don't know the circuit). _________________ Jan
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Sun Jan 04, 2009 4:56 am Post subject:
| fadeddata wrote: | Ok, show and tell it is! I'm going to be wiring this up tomorrow morning
-dustin |
How did you made these panels?
They look awesome! |
doctorvague
Posted: Sun Jan 04, 2009 6:40 am Post subject:
| fadeddata wrote: | I used an Epilog laser engraver that I have access to. The pictures don't really do it justice. I'm repeatably amazed at how well laser engravers work. We should all go in on a group buy for one
-dustin |
The edges and lettering look very much like white silkscreening in the picture, but they are actually the aluminum showing through where the anodized black layer is lasered off, yes-no? There doesn't appear to be indentations there though like a CNC would do though, is that correct?
Looks great!
Phil _________________ doctorvague's youtube channel |
fadeddata
Posted: Sun Jan 04, 2009 5:21 pm Post subject:
Woops! Sorry for the delay in responding. The panels are drilled through FPE (but I have a drill press now so I might start doing them myself *if* I can find a place to source anodized cut aluminum (anyone???)).
My employer has an epilog laser engraver that I used for "etching the panels". From what I know it actually is chemically changing the anodization to a pale off white. It's a very specific look that I like very much.
Oddly it feels raised and not as if it removed any material.
-dustin |
American Gladiator
Posted: Fri Jan 09, 2009 10:50 am Post subject:
| I have made three of these, and all have had a problem with the CV input cutting out at times, acting unstable, and changing in response to touching the faceplate. Anyone else noticed this? Possibly just a problem with my system interacting with this particular module. Running it off of a Blacet power supply. |
orange
Posted: Sat Jan 10, 2009 1:42 pm Post subject:
Hello Thomas!
Is it possible to order a couple of low pass gate PCB´s?
All best
dj orange |
ericcoleridge
Posted: Sat Jan 10, 2009 7:14 pm Post subject:
I'd really love to see made available again as well. I've made a quad version already-- but I'd like another.
Any chance of this PCB seeing production again Thomas? |
discoslut
Posted: Tue Jan 13, 2009 8:03 am Post subject:
Hi Thomas,
If you ever do a new run of boards I'm up for two.
thanks |
intellijel
Joined: Sep 10, 2006 Posts: 67 Location: Vancouver, BC
Posted: Thu Jan 22, 2009 12:38 pm Post subject:
Please add me to the list for 4 pcbs if anymore become available!
Or can we get the gerber files and have our own made?
thanks, Danjel |
Peake
Joined: Jun 29, 2007 Posts: 1113 Location: Loss Angeles
Posted: Fri Jan 23, 2009 11:24 pm Post subject:
From page 1:
"I just got the approval from Don himself to put together a one-time PCB run for the Mathias (Fonik)-based PCB layout of Don's classic Lopass Gate."
To burn your own:
http://electro-music.com/forum/topic-22079.html _________________ We are selling emotions, there are no emotions in a grid. -mwagener
"IC 741. Sometimes you don't want fidelity." -Small Bear Electronics Catalog |
sduck
Posted: Fri Jan 30, 2009 10:05 pm Post subject:
Ok, I finished putting together all of my pcb's, and put numbers 2 and 3 behind this panel. I've got fast vactrols on the left, slow on the right for some variety.
I'd like to thank fadedata (Dustin) for inspiring to clean up my behind the scenes wiring - there's still room for improvement, but it's a lot better than previous efforts.
mono-poly
Posted: Sat Jan 31, 2009 2:04 am Post subject:
| That's a nice looking dual LPG! |
sduck
Posted: Sat Jan 31, 2009 8:09 am Post subject:
Thanks, Mono-poly.
A question - I've got these fairly expensive trimmer pots sitting on the pcb's of these things, and have no idea what they do. Does anyone know? I suppose I could just start tweaking the things and see what happens, but I'd rather know what I'm looking for first. |
numbertalk
Posted: Mon Feb 02, 2009 8:02 am Post subject:
| sduck wrote: | | A question - I've got these fairly expensive trimmer pots sitting on the pcb's of these things, and have no idea what they do. Does anyone know? I suppose I could just start tweaking the things and see what happens, but I'd rather know what I'm looking for first. |
I asked about this earlier and here's what Thomas said (it's an offset trimmer):
Adjust offset to "taste". Just allows you to set the offset swing of the pot to a lower or higher range. |
