Resonant Lopass Gate PCB's (New Batch 4/29/12)
Page 18 of 38 [927 Posts]
Goto page: Previous 1, 2, 3, ..., 16, 17, 18, 19, 20, ..., 36, 37, 38 Next
xpander
PostPosted: Sun Dec 07, 2008 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
do you have any extra boards leftover?? i'd still like a couple.
a_guy_called_tom
PostPosted: Mon Dec 08, 2008 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
djthomaswhite wrote:
Please post details of your power hook up... Looks like goes to Doepfer?
Yep, mine's connected to a Doepfer power rail, plucking happily using +- 12 volts Smile
For those preferring to use a dual vactrol, heres how to do it (Thanks to Serenadi for explaining it to me). Make sure you isolate the crossing legs well and don't mix up the anode and cathode of the led.
dual vactrol
 Filesize:  21.05 KB
 Viewed:  11113 Time(s)
Last edited by a_guy_called_tom on Mon Dec 08, 2008 11:24 pm; edited 1 time in total
TekniK
PostPosted: Mon Dec 08, 2008 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
10x Tom! Wink
Appliancide*
PostPosted: Mon Dec 08, 2008 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
For those preferring to use a dual vactrol, heres how to do it (Thanks to Ilanode for explaining it to me). Make sure you isolate the crossing legs well and don't mix up the anode and cathode of the led.
Thanks for the dual vactrol advice! I just picked up a couple in a trade and was wondering if they would work.
Paul
http://appliancide/blogspot.com
sduck
PostPosted: Tue Dec 09, 2008 6:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, show and tell time. Just finished my version of the complete bells and whistles version. Based my panel on Thomas Whites design, with several changes.
The back - unlike previous builds, I didn't have to use cable ties this time - the wires all seemed to fall into place on their own.
These images and more are on my flickr page, if you want to see bigger images -
http://www.flickr.com/photos/sduck409/
Thanks Thomas (and team) for the great pcbs! It sounds fantastic!
 Filesize:  646.18 KB
 Viewed:  316 Time(s)
 Filesize:  1.03 MB
 Viewed:  343 Time(s)
fadeddata
PostPosted: Sat Dec 13, 2008 10:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, show and tell it is! I'm going to be wiring this up tomorrow morning Smile
-dustin
 Filesize:  168.18 KB
 Viewed:  319 Time(s)
 Filesize:  160.13 KB
 Viewed:  307 Time(s)
BananaPlug
PostPosted: Sun Dec 14, 2008 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice. Which method did you use for the panel graphics?
fadeddata
PostPosted: Sun Dec 14, 2008 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I used an Epilog laser engraver that I have access to. The pictures don't really do it justice. I'm repeatably amazed at how well laser engravers work. We should all go in on a group buy for one Smile
-dustin
slo
PostPosted: Sun Dec 14, 2008 9:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Sduck, vey nice job.
Can I ask what the CTRL input is? is it just a straight in CV? as you went with 2 other CV inputs.
George
sduck
PostPosted: Sun Dec 14, 2008 8:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, the control in is just a cv in without a pot.
And hopefully Dustin will post pics of the back of his LPG after he wires it all up - he showed me some of his work the other day, and his wiring is incredibly immaculate. And it's pretty fantastic looking from the front too!
LektroiD
PostPosted: Sun Jan 04, 2009 2:55 am    Post subject: Reply with quote  Mark this post and the followings unread
What is everyone doing for the 50KΩ resonance mod resistor? I've not managed to source a 50KΩ resistor anywhere. Can I put a 47KΩ and a 3KΩ in series to make this value, or is it not critical to get it exact and get away with a 47KΩ on its own?
Also, must the 4.7MΩ resistor be carbon? I only have metal film
Audio files: 303
PostPosted: Sun Jan 04, 2009 3:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Metal film is better, so just use that one.
As to the other resistor, 47k probably will be fine (usually it is, but I don't know the circuit).
mono-poly
PostPosted: Sun Jan 04, 2009 4:56 am    Post subject: Reply with quote  Mark this post and the followings unread
-dustin
How did you made these panels?
They look awesome!
doctorvague
PostPosted: Sun Jan 04, 2009 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
-dustin
The edges and lettering look very much like white silkscreening in the picture, but they are actually the aluminum showing through where the anodized black layer is lasered off, yes-no? There doesn't appear to be indentations there though like a CNC would do though, is that correct?
Looks great!
Phil
doctorvague's youtube channel
fadeddata
PostPosted: Sun Jan 04, 2009 5:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Woops! Sorry for the delay in responding. The panels are drilled through FPE (but I have a drill press now so I might start doing them myself *if* I can find a place to source anodized cut aluminum (anyone???)).
My employer has an epilog laser engraver that I used for "etching the panels". From what I know it actually is chemically changing the anodization to a pale off white. It's a very specific look that I like very much.
Oddly it feels raised and not as if it removed any material.
-dustin
American Gladiator
PostPosted: Fri Jan 09, 2009 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I have made three of these, and all have had a problem with the CV input cutting out at times, acting unstable, and changing in response to touching the faceplate. Anyone else noticed this? Possibly just a problem with my system interacting with this particular module. Running it off of a Blacet power supply.
orange
PostPosted: Sat Jan 10, 2009 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello Thomas!
Is it possible to order a couple of low pass gate PCB´s?
All best
dj orange
ericcoleridge
PostPosted: Sat Jan 10, 2009 7:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd really love to see made available again as well. I've made a quad version already-- but I'd like another.
Any chance of this PCB seeing production again Thomas?
discoslut
PostPosted: Tue Jan 13, 2009 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Thomas,
If you ever do a new run of boards I'm up for two.
thanks
intellijel
PostPosted: Thu Jan 22, 2009 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Please add me to the list for 4 pcbs if anymore become available!
Or can we get the gerber files and have our own made?
thanks, Danjel
Peake
PostPosted: Fri Jan 23, 2009 11:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
From page 1:
"I just got the approval from Don himself to put together a one-time PCB run for the Mathias (Fonik)-based PCB layout of Don's classic Lopass Gate."
Embarassed
To burn your own:
http://electro-music.com/forum/topic-22079.html
sduck
PostPosted: Fri Jan 30, 2009 10:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I finished putting together all of my pcb's, and put numbers 2 and 3 behind this panel. I've got fast vactrols on the left, slow on the right for some variety.
DRLGfront
I'd like to thank fadedata (Dustin) for inspiring to clean up my behind the scenes wiring - there's still room for improvement, but it's a lot better than previous efforts.
DRLGback
mono-poly
PostPosted: Sat Jan 31, 2009 2:04 am    Post subject: Reply with quote  Mark this post and the followings unread
That's a nice looking dual LPG!
sduck
PostPosted: Sat Jan 31, 2009 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Mono-poly.
A question - I've got these fairly expensive trimmer pots sitting on the pcb's of these things, and have no idea what they do. Does anyone know? I suppose I could just start tweaking the things and see what happens, but I'd rather know what I'm looking for first.
numbertalk
PostPosted: Mon Feb 02, 2009 8:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I asked about this earlier and here's what Thomas said (it's an offset trimmer):
Adjust offset to "taste". Just allows you to set the offset swing of the pot to a lower or higher range.
