Schaeffer, Front panel Designers tips and tricks
Page 2 of 3 [61 Posts]
factus10
PostPosted: Wed Jan 30, 2008 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Eric,
If all you have is FPD, do this:
- place a text object
- enter text on multiple lines
- use the enter to create space between your lines of text or use the text line height/spacing controls to manage the space
I did this with my Klee panel (a little bit of both). I'm pretty sure it saved some $.
The only challenge I really noticed was trying to space text out horizontally... that seemed harder to control but not impossible.
If you have Front Designer, you can do a whole lot of the design work in that then export it as HPGL objects. I think, but I'm not sure yet, that will save a bunch. I'll know for sure next week when I have time to test it out.
ericcoleridge
PostPosted: Wed Jan 30, 2008 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
just create a text object. while editing the text in the text field you can easily insert paragraphs (multiple lines) by hitting the enter key (just as usual).
you will have to change the line spacing according to text height and your needs.
adjust alignment.
I see. Much simpler than I was thinking. You have to kind of align your paragraphs spacing to fit into the right places on your panel.
ericcoleridge
PostPosted: Wed Jan 30, 2008 3:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just have FPD, and I've brought down the cost of my designs significantly by eliminating the in-fill (thanks to the suggestions in this topic).
I guess theres no way (on FPD) to save "Macro Elements" as HPGL objects and then re-setting them into your design?
I'm very curious to know how much money you save using HPGL files now
factus10
PostPosted: Thu Jan 31, 2008 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I have next week off from work and I'll be spending nearly the entire time assembling some of my projects (esp my Klee). One of the projects I'm going to work on is the panel for my MFOS mixer. I'll post full notes here, probably mid week.
Sound
PostPosted: Sun Apr 13, 2008 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
Using the Front Designer 3.0 I have noticed that when you type a text label, and you have the font size say at 2,2mm, when you input the text, SOMETIMES, it changes to 2,18 or 2,4 or other measures Question why? do it happen to you?
LetterBeacon
PostPosted: Mon Feb 02, 2009 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I want to have the scale around the pots of the panel I'm designing (what is the correct name for that??) to be similar to the DotCom format - is there a HPGL library online that has things like this in it so I can just import them into FPD, or do I have to draw them myself?
Sound
PostPosted: Mon Feb 02, 2009 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
If I understood your question, you can design all the front panel, also the scales around the pots with this software:
http://www.abacom-online.de/uk/html/body_frontdesigner.html
After it you import the file to the schaeffer front designer software.
Regards.
LetterBeacon
PostPosted: Mon Feb 02, 2009 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the link!
I'm sorry, it's my fault because I phrased my post very badly - what I meant was does there exist a library of synth symbols and scales in the HPGL format for people who don't have something like Front Designer? It just seems 39 Euros is a lot of money if I just want to design scales!
slacker
PostPosted: Mon Feb 02, 2009 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know if it's any good, but here's a free online scale creation tool that can do HPGL http://stiftsbogtrykkeriet.dk/~mcs/Scale.html.
LetterBeacon
PostPosted: Mon Feb 02, 2009 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheers for that, I'll give it a go.
TekniK
PostPosted: Wed Feb 04, 2009 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi,is there a app that converts an EPS,Ai (illustrator) file to HPGL ,so that i can import in FPD?
LetterBeacon
PostPosted: Wed Feb 04, 2009 4:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be interested in this too...
LetterBeacon
PostPosted: Sun Feb 08, 2009 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
What kind of thickness do people go for when designing Euro modules? I notice that Fonik's FPD files are usually about 1.5mm, is there any wobble or give in the panel at that thickness?
Sound
PostPosted: Sun Feb 08, 2009 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
2mm is what uses Doepfer.
Although that 1.5mm is enough, 0.5mm more is a good improvement, the panel is much more robust.
Regards.
PostPosted: Sun Feb 08, 2009 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
no, not at all. even with no components mounted...
LetterBeacon
PostPosted: Mon Feb 09, 2009 6:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's my first attempt at a Euro style panel. As you can see it's basically Fonik's panel of his Chris MacDonald CV processor and Fonik's own LPG circuit with the resonance mod (Fonik, I hope you don't mind me adapting yours - if it's a problem then let me know).
Can anyone spot anything immeadiately wrong with this panel that I, as a first time FPDer, haven't noticed? I'm slightly concerned with the LPG's switches being so low down on the panel, although I think I might just get away with it.
I've used 7mm holes for the pots, but now I've printed it off on some paper I think it's going to be a tight squeeze getting alpha pots in there. I might up the diameter to 8mm to be on the safe side.
I've just bought some of these on my lunch break:
Can you use alpha pots with these knobs? The knob seems very small...
 Filesize:  24.88 KB
 Viewed:  17167 Time(s)
PostPosted: Mon Feb 09, 2009 7:05 am    Post subject: Reply with quote  Mark this post and the followings unread
if it was, i would not have uploaded my fpd-file Very Happy
BTW the LPG circuit is not my design, it's peter grenaders adaption of the buchla cirtcuit with the mark verbos resonance mod some nice people here in the forum optimized (see thread for dave's great PCB).
this way you simply won't be able to mount the switches vertically. i@d recommended to take the measurements from the datasheets of the components you want to use and sketch them onto the layout. don't forget to consider the mounting rails of the rack!
stay with 7mm. 8mm is far too large. the potentiometer won't be aligned properly. if you want some clearance, try 7.2mm.
can you post a link? hard to judge from a picture...
LetterBeacon
PostPosted: Mon Feb 09, 2009 7:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a link to the pots on Maplin's wesbite: http://www.maplin.co.uk/Module.aspx?ModuleNo=19412 They look the same as the ones you use on your modules, do you think they are the same? How flat against the panel do you manage to get the knobs sitting?
It would be a shame if I couldn't get the switches vertical on the panel. I've put a switch up against the paper print-out and it will be very close with the mounting rail in. Do you think it's worth making the panel a couple of HP wider to be on the safe side?
One other thing: When I use FPD, the prices are all in US$, how do I make it give me the prices in Euros? I'm assuming I'll want to get the panal from Germany rather than the US...
PostPosted: Mon Feb 09, 2009 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
these are not the same, but quite similiar. aren't these the ones blacet uses? however, they will fit perfectly on 16mm alphas with nurled shaft. the skirt hides the mounting crew so the knob will sit VERY flat. here is a link to a large format picture of the PS3100:
http://farm4.static.flickr.com/3500/3198008550_18b0a6ded2_o.jpg
today i put potentiometers in columns and i never want to have two columns of potentiometers side by side, just to have enough clearance for operating them. for some of my older modules i did not take care of that. i wish i had (OTOH i used smaller knobs for my 2nd cabinet). take a look at my 3rd cabinet, then you will get the idea immediately:
download from the german website?
LetterBeacon
PostPosted: Mon Feb 09, 2009 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Although I don't have an alpha pot in front of me, the knob that I got from Maplin does seem very short. I can't imagine these one sitting against the panel in the same way yours do. Maybe if I use a bolt and sit the pot away from the panel a bit? Where do you get your knobs from?
Not having the pots side by side is a good idea I think. I think I will widen my panel, although it does mean doubling the size of it! It tricky trying to make the best use of panel space without over-crowding it.
PostPosted: Mon Feb 09, 2009 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
rs-components. i can't tell you the part number, their page is currently not available.
LetterBeacon
PostPosted: Mon Feb 09, 2009 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got home and the knob didn't fit on the alpha pot.
Is this what you use:
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=2994799#header The 6mm splined shaft?
And that fits on a regular alpha pot like this one?:
I've decided to put the CV Processor and Dual LPG onto separate panels. I've attached a new panel design for the Dual LPG. I've decided to use the slower VTL5C4 and so have included Thomas White's mod as well. Does everything look in order? I've changed the text to 1.5mm as I'm using upper case letters rather than your lower case 2mm - do you think that'll be ok?
 Filesize:  19.96 KB
 Viewed:  231 Time(s)
292c Solo.fpd
 Filename:  292c Solo.fpd
 Filesize:  2.36 KB
 Downloaded:  272 Time(s)
PostPosted: Tue Feb 10, 2009 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Crying or Very sad
no, your link directs to the 11mm diameter knob for 4mm shaft. i use these 13mm diameter knobs for nurled 6mm shafts: rs number 299-4957
they fit perfectly as you can see from my posted picture above (the link actually)...
very nice panel. you will enjoy it!
PostPosted: Tue Feb 10, 2009 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
i just reviewed the fpd-file.
check the datasheet of the switches you plan to use against the drilling size of you frontpanel! same applies to the jack sockets. these 8mm holes are for the cliff 1384(1) sockets.
LetterBeacon
PostPosted: Tue Feb 10, 2009 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for taking the time to review my panel. Unfortunately I can't seem to find the measurement I need on the switch's datasheet, but I printed out the panel and it seems to fit through the hole.
I'm probably going to use the Cliff S6BB/PC sockets, I think according to the datasheet I need an 8.3mm panel cut out, so I'll revise the panel accordingly.
Oh and just so I'm 100% clear - when you say nurled pot you mean like the type I posted in my last post?
Thanks again for your time!
