 Forum index » How-tos
Is it a BRF (Band Reject Filter) ?
Page 1 of 1 [4 Posts]
oXo
PostPosted: Mon Oct 18, 2004 1:28 am    Post subject: Is it a BRF (Band Reject Filter) ? Reply with quote  Mark this post and the followings unread
Hello,
I just want to know if I'm wrong or not to say that we can create a Band Reject Filter if :
We split the audio signal in two identical signal and feed them in 2 filters : the first one is a LPF and the second one a HPF ?
Can you confirm, that's right ?
aquanaut
PostPosted: Mon Oct 18, 2004 1:36 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure about this but i think you can emulate a BRF better by using bandpass filters. It will create less of a hole and the sounds will be clearer.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Oct 18, 2004 3:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, LP + HP in parallel = Band Reject: you will need to mix the 2 outs
LP + HP in series = Band Pass
oXo
PostPosted: Mon Oct 18, 2004 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks G2ian.
I'm not as bad as I think Very Happy
And Yes, I mix the 2 outs Laughing ...
