today> Various Artists September equinox Concert
Dim D
Page 8 of 13 [313 Posts]
Goto page: Previous 1, 2, 3, ..., 6, 7, 8, 9, 10, 11, 12, 13 Next
What "chipset" would you like to see in a Dim D PCB
Original chips. They are still out there.
76%
 76%  [ 39 ]
Low voltage BBDs - easier to get, probably more noisy. Takes longer to design.
5%
 5%  [ 3 ]
Make a PCB that allows both options. Will be more expensive (more PCB area required!), and will take the longest to design.
13%
 13%  [ 7 ]
Not interested. (Who needs a Dim D? And isn't there another Dim D project on the way?!)
3%
 3%  [ 2 ]
Total Votes : 51
living sounds
PostPosted: Fri Mar 27, 2009 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi everybody,
first I'd like to say thanks to Jürgen for this great project!
So I finished my Dimension D (modern component version) yesterday and it generally works as it should.
But I've got a few remaining question:
1. Compared to the examples provided on your website my build seems to lack some clarity in the high end. I've taken great care to use quality components (Elna Silimic II electrolytics, WIMA polypropylene whereever possible, otherwise MKP, NPO ceramics wherever possible). The frequency response is quite uneven, here is an mp3 of a sine sweep (mode 4):
www.scherer.de/Download/DimDSweep.mp3
2. Is the unit set up for +4db operation? It does seem to distort (on program material) with the bias set to optimal settings at these levels. Works fine at -10db (but THD in general still is quite high, as can be seen on the mp3).
The power supply seems to be able to handle it, at +4db the noise is at -92db, and there isn't any hum to speak of. All opamps get fed almost perfect +- 15V .
3. I've got a slight deviation between left and right channel, maybe 1/2 db. I replaced C67 with a 100uf one for now because the 47uf one blew up (due to wrong orientation), can this be the cause? Could anything have been damaged due to the cap failure?
4. The trimpots near the MN3007s don't seem to do anything.
5. Same goes for all the trimpots on the main board. Is this correct?
6. What would happen if one actually used shorting unbalanced connections?
7. Finally: Can I put in 5532/5534 op amps instead of the TL071/2 here? I've got some vintage ones that sounded great in every other unit I used them.
Thanks in advance!
Gregor
jhaible
PostPosted: Fri Mar 27, 2009 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, this is analogue electronics, not measurement equipment!
Can you actually hear 0.5dB ?!
JH.
living sounds
PostPosted: Fri Mar 27, 2009 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
JH.
I'm not really bothered about that anyway. Smile But the other questions give me some trouble, especially the distortion and the frequency response. Is this how it should be in my unit?
jhaible
PostPosted: Fri Mar 27, 2009 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
JH.
Hart to tell. Do you notice any unpleasant distortion (other than the "warming" of the sound) on vocals for instance?
BBDs *do* add distortion. That's why these old boxes are so sought after - they give a warmness that's hard to achieve otherwise.
About using different opamps: You can try othe rones, but wathch for offset voltages and HF oscillations.
Generally, I think the THD is dominated by the BBDs and the compander chips in this circuit, though.
JH.
living sounds
PostPosted: Fri Mar 27, 2009 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
JH.
JH.
Thanks! The THD seems to be quite high, did you have a look at the mp3? Below 100 Hz distortion is as high as 35 db below the wanted signal, around 8khz it is ca. 50 hz lower.
So what about the frequency response? Is this normal (because your examples don't seem to show this behavior. Any hints on what could be the culprit for this?
Gregor
jhaible
PostPosted: Fri Mar 27, 2009 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
JH.
JH.
Gregor
I haven't made any frequency response measurements.
Expect a little bit of HF rolloff, but nothing dramatic.
I haven't visually analyzed your mp3, I'm sorry.
Spent the whole day shipping Solina boards.
If you have too much loss on the high end, check the capacitor values in the opamp feedback path - that's the first thing I'd do.
JH.
jhaible
PostPosted: Fri Mar 27, 2009 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, increasing THD towards the bass range is typical NE570 compander behaviour. *Good* for the sound, IMO!
JH.
living sounds
PostPosted: Fri Mar 27, 2009 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
JH.
OK, no problem there then! Smile
There's a frequency plot of a 20Hz-20Khz linear sine sweep through the unit (mode 4) attached to this post. Impedances on my converter (balanced connection) are 24 ohms on the input and 100 ohms on the output.
The low end as well as the high end are 9 db down compared to the parts in the midrange with the highest amplitude. This seems too much to me.
BTW, is the chorus made for +4 db level input?
Thanks for your time, it's great to get answers here so quickly!
Gregor
 Filesize:  113.61 KB
 Viewed:  192 Time(s)
jhaible
PostPosted: Fri Mar 27, 2009 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, the service manual says so.
JH.
living sounds
PostPosted: Sat Mar 28, 2009 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I've just checked the individual pathways. The input stage of the main board is fine. But the return signal from the BBD board is severly bandlimited, the signal falls steeply above 9,5 khz as well as below 70Hz (the latter one doesn't matter much in a real world application). Could this be caused by one of the ceramic opamp feedback caps having the wrong value? The problem is that a lot of them are unlabled (though I took care - I thought - to put them in correctly)...
Or could this be caused by a broken transistor?
Gregor
jhaible
PostPosted: Sat Mar 28, 2009 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Band limiting the BBD signal is intentional. 10kHz seems about right.
I wouldn't call it "severe" - it's just the BBD path, and not the overall response, after all.
All in all, it means the highest frequencies are there - just a little attenuated, and not "chorussing".
JH.
living sounds
PostPosted: Sun Mar 29, 2009 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
JH.
That's all right then!
The distortion is still there though. Even at lower levels the audio distorts audibly on exposed midrange heavy material like vocals and piano.
ognam
PostPosted: Mon May 04, 2009 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello Everybody...
I have one question:
Is this transformer too small for the PSU of a Dim D version (2 PCBs)?
http://www.reichelt.de/?;ACTION=3;LA=2;GROUP=C526;GROUPID=3317;ARTICLE=27380;START=0;SORT=artnr;OFFSET=50;SID=25zxgdgqwQARkAACD9s@U39ebd88fa2d8386219f8fca69d8c7db0
or should that be a toroid to avoid hum?
Thanx Jonas
jhaible
PostPosted: Mon May 04, 2009 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
ognam wrote:
Hello Everybody...
Thanx Jonas
These things are crap, IMO. Huge stray field, and no mounting screws.
JH.
ognam
PostPosted: Tue May 05, 2009 12:52 am    Post subject: Reply with quote  Mark this post and the followings unread
OK... Thanks.
Then I will go for a toroid. How much mA will I need for each winding for my Dim D version?
I also have another question...
What is meant with "no floating balanced outputs"?
Can I connect the outputs to an unballanced input if I take a Cable where Pin3 of the XLRs is left out so that it is not shorted to ground?
Is there any problem to connect an unballanced input to the XLR ins?
Thank you for this great project!
Jonas
jhaible
PostPosted: Tue May 05, 2009 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
ognam wrote:
OK... Thanks.
This depends on so many things that I'm reluctant to give numbers here.
But the smallest non-PCB-mount toroidals from Reichelt are 30Watt, and that is *plenty*. (My prototype is powered with a 12 Watt wallwart.)
Yes - emphasis added.
JH.
lexvortex
PostPosted: Tue May 12, 2009 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi JH,
I have a question about the BC550C, can I use a BC550B instead? Also can I use a LM13700 instead of the LM13600?
Thanks Very Happy ,
jhaible
PostPosted: Tue May 12, 2009 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
lexvortex wrote:
Hi JH,
Thanks Very Happy ,
Yes, and yes.
JH.
lexvortex
PostPosted: Wed May 13, 2009 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi JH,
lexvortex wrote:
Hi JH,
Thanks Very Happy ,
Yes, and yes.
Thanks Very Happy ,
lexvortex
PostPosted: Mon May 18, 2009 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi JH,
I have another question about components. For the BC560, what is the best replacement for that? BC557? I've built quite a few projects that specify BC560s and allow a replacement using a BC557, I am curious as to why the BC560 is chosen rather than the BC557 or other equivalents and what difference it makes to the circuit. I have heard that the BC560 is a "quieter" or low noise version of the others. Would it be worth my time to track down the BC560 and replace the BC557s with them eventually.
Thanks,
JoeMorris
PostPosted: Mon May 18, 2009 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is the N570N OK for this project?
jhaible
PostPosted: Mon May 18, 2009 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
You mean NE570N ?
JH.
JoeMorris
PostPosted: Mon May 18, 2009 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes, sorry..!
jhaible
PostPosted: Tue May 19, 2009 12:02 am    Post subject: Reply with quote  Mark this post and the followings unread
JoeMorris wrote:
yes, sorry..!
Yes, NE570N is good.
JH.
JoeMorris
PostPosted: Tue May 19, 2009 12:55 am    Post subject: Reply with quote  Mark this post and the followings unread
ive just realised ive been rather silly and that NE570N is on the PCB silk screen and BOM. I was just going on the first page of this thread. doh! thanks anyway.
