Resonant Lopass Gate PCB's (New Batch 4/29/12)
Page 20 of 38 [927 Posts]
Goto page: Previous 1, 2, 3, ..., 18, 19, 20, 21, 22, ..., 36, 37, 38 Next
doctorvague
PostPosted: Mon Mar 23, 2009 5:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd be up for 4 more boards if you do a run.
Phil
PostPosted: Mon Mar 23, 2009 5:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Spratty wrote:
I don't have any cv devices to plug in though - I was just thinking about plugging this in with some stompboxes...
then you should really think about building a simple square wave LFO and throw it in your LPGs. CVs are all the fun in VCFs Wink (especially the vactrol based LPG).
doctorvague
PostPosted: Mon Mar 23, 2009 5:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Indeed!
Or an envelope follower
or a 5V foot pedal...
Ya gotta get ya some voltage.
Spratty, you mention stomp boxes-
are you using this on guitar?
Phil
EDIT:
sorry Thomas, I just realized I'm highjacking your thread...
Krelnarb
PostPosted: Tue Mar 24, 2009 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wishful wishful,
another run?
I'm in for two,
if it's done.
Spratty
PostPosted: Sat Mar 28, 2009 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello fonik & doctorvague
Yes I probably should Wink Any suggestions? Temporarily I can borrow an MF102, it has an LFO, so all I'd need is a trs cable to plug that in right? With CV the voltage goes to the tip? 0-5v+ cv is ok for this circuit?
I saw the Buchla Envelope follower in another thread - might not suit this that well though...
Yeah, I'm thinking electric guitar, my playing might not be all that great (very beginner), but in previous times I've been a bit of an fx/scifi sound design junkie. Guitars/synths + fx = fun.... DIY synthesis was probably inevitable ... Wink
Spratty Wink
PostPosted: Sat Mar 28, 2009 5:04 am    Post subject: Reply with quote  Mark this post and the followings unread
yes. try using the pulse wave. this will give you the vactrol experience...
303monkey
PostPosted: Sat Mar 28, 2009 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I would be up for eight boards if another order is made.
jnuaury
Audio files: 9
PostPosted: Sat Mar 28, 2009 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
another in favor of another run
az/gde
YouTube
loren_e
PostPosted: Sun Mar 29, 2009 1:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll take two boards if another run of PCBs is made. Maybe eventually I'll build them! Very Happy
simmeau
PostPosted: Tue Apr 07, 2009 4:20 am    Post subject: Reply with quote  Mark this post and the followings unread
What range of cv do they expect?
Constantine
PostPosted: Sat Apr 18, 2009 8:49 am    Post subject: Reply with quote  Mark this post and the followings unread
if there'll be another run, i'd definitely buy 4 or more pcbs.
jooks
PostPosted: Sat Apr 18, 2009 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I´ll buy 2 pcbs if there´s another run. Thanks!
adambee7
PostPosted: Mon Apr 20, 2009 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
i'll take 4 if there's another run please. Very Happy
mirri
PostPosted: Tue Apr 21, 2009 2:33 am    Post subject: Reply with quote  Mark this post and the followings unread
If there is another run count me in for a couple.
/m
hadal-drop
PostPosted: Tue Apr 21, 2009 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
echo echo echo echo
i'm also interested in a couple of boards
Laughing
xpander
PostPosted: Tue Apr 21, 2009 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
... and a few boards wanted over here, too.
CJ Miller
PostPosted: Tue Apr 21, 2009 9:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would certainly buy a few, I was away and just came back to the board after the first ones had gone. Can somebody fill me in (still reading 20 pages of this topic) is this circuit for regular 10v audio levels, or Buchla audio levels?
If there's another run, I'll commit to 6 boards!
TekniK
PostPosted: Thu Apr 23, 2009 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes no problem,i use it with high voltage output modules,works great.
jnuaury
Audio files: 9
PostPosted: Thu Apr 23, 2009 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I noticed bridechamber is doing panels for this bad boy... would he be in charge of the boards this time around?
synchromesh
PostPosted: Sun May 03, 2009 8:54 am    Post subject: Me too Reply with quote  Mark this post and the followings unread
Hi, I'd be interested in a couple of boards if there is ever another run.
John :^P
Tasmanian Alkaloid
PostPosted: Mon May 04, 2009 5:13 am    Post subject: Reply with quote  Mark this post and the followings unread
I finished one today, i'm not particularly proud of the panel, but i thought i'd chuck it up here.
I had 3 audio ins & 3 cv ins, but found the 3rd inputs a bit too much for my needs, so trimmed it back to 2 of each.
Also, i couldn't find a 50k resistor for the Resonance mod- so i used a 51k, and it seems a bit squishy near fully CW. I wonder how important the value is here, does anyone know?
My other pcb probably won't have the mixers, just direct inputs.
Thanks again Thomas & everyone else who made it possible!
 Filesize:  44.66 KB
 Viewed:  214 Time(s)
mistercooper
PostPosted: Mon May 04, 2009 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm up for at least one pcb if there is another run.
djthomaswhite
PostPosted: Mon May 04, 2009 7:10 pm    Post subject: Another run?
Subject description: What do you think?
Hi guys,
Just a bit of an update here...
Another run? I'm super down to get one together, but I have been unlucky in communicating with Don Buchla. I have now sent 4 emails to him and have not been able to get a reply. He was very VERY nice to approve the first run. I was hoping for a quick approval for another one. I have stated many times I will not do one without his blessing in honor of his design.
One needs to realize the situation (to my knowledge, correct me if I am wrong. MANY people have done (made commercially available) Lopass Gates now without Don's approval including Doepfer, Plan B, Cyndustries and Make noise. Each design has had small changes from Don's original design like mine does. Remember, mine removes the switching IC from the original thanks to designs posted on the web and therefore public domain. My changes are adding the mixer section for Audio and the Mixer section for CV, also from designs in public domain. So, am I really doing something wrong by making more of these without permission from the master himself?
I know desire for these, as shown by the posts here and the emails directly, will influence people to say "No way dude, make more!!!" but is that really the case? Who can give legal advice here? I want to make more, but don't want to be a hypocrite either. Many have contributed to the success of this project since Don's original design. If Don says "no" or I can't get an approval I will not make anymore. But...
What are your thoughts on this out there? Maybe I can post my board designs for public domain so at least people could get them made on their own type of thing? Thanks in advance for your opinions!
Thomas
Thomas
www.naturalrhythmmusic.com/diy.html
Tasmanian Alkaloid
PostPosted: Mon May 04, 2009 9:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Did Don originally say "Yes, i approve, but only for a certain number of pcb's"?
Maybe his silence is his way of saying that he's already given approval.
If anything can be said of Don, he doesn't look back.
But if i was in your position, i'd call him on the telephone.
xpander
PostPosted: Tue May 05, 2009 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmm... i talked to him briefly yesterday & may swing by buchla's later today to pick up some 200e goodness.
i'll try to remember to ask him although seriously i can't imagine him doing anything other than giving the green light.
