TOM WHITSHIRE VCLFO PCB
Page 3 of 5 [105 Posts]
haxster
PostPosted: Mon Jun 01, 2009 1:58 am    Post subject: Reply with quote  Mark this post and the followings unread
No problem on downgrading or bailing out. Everything will get sold anyhow.
haxster
PostPosted: Mon Jun 01, 2009 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
SUMMARY FOR REV1.1 PCB TOM WILTSHIRE VCLFO
BUILDERS: AS SOON AS YOU GET THE PCB PM ME, OR EMAIL ME (IF YOU REMEMBER MY EMAIL) AND I CAN SEND YOU A ZIP WITH THE LAYOUT AND LITE VERSION PROGRAM SO YOU CAN VIRTUALLY TEST TRACES AND SEE UP CLOSE IF SOMETHING DOES NOT MAKE SENSE. IT MAKES IT A WHOLE LOT EASIER. BUILD TIME IS ABOUT 2 HOURS.
*clickmrmike (1) paid (SENT)
*creatorlars (1) paid (SENT)
*BBOB (2) PAID (SENT)
*NUMBERTALK (1) paid (SENT)
*SDUCK (1) paid (sent)
TO BE MAILED JUNE 01, 2009
*EGRAD (1) paid
*henrikgo (1) paid
*ADAMBEE7 (2) paid
They paid already:
*KITSHCH-BENT (4)
*factus10 (1)
*MONOPOLY (2)
ANOTHER ORDER HAS BEEN PLACED FOR (20) MORE 2ND RUN TOM WHILTSHIRE PCB'S---JUNE 1, 2009. EXPECTED ARRIVAL JUNE 10-11.
THE 2ND RUN IS OFFICIALLY ERROR FREE. SILKSCREEN MISTAKES HAVE BEEN FIXED AND NO MORE JUMPERS.THE NAME TAG ON THIS BOARD IS REV 1.2
THIS IS THE LIST I HAVE SO FAR FOR RESERVE:
JULIANW (2)
RECOMPAS (1)
ach_gott (2)
LUKA (4) MAYBE(2)
Funky40 (2)
The Alison Project (4)
just added:
Danno Gee Ray (1)
Dego (1)
a100user (1)
Waiting for The Alison Project (4),
everyone else paid and shipped out for 2nd run
Danno Gee Ray
PostPosted: Mon Jun 01, 2009 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be interested in one set.
Thanks
Dan
TekniK
PostPosted: Mon Jun 01, 2009 2:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi,would like to ask u,if there is an onboard protected external CV input for waveform selection and distortion on top of the '5v pot CV's inputs'
cheers
haxster
PostPosted: Mon Jun 01, 2009 5:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks like you have been studying the possibilities on the 0-5v inputs on the pic pins. I am way ahead of you and thought about that yesterday too. I came up with this layout and basically copied what i did with the Freq CV input. I don't know if I will make this board, I just got it out of the way for now. PM if you want the zip to have it made like right now. The difference is I chucked the Analog LFO's and laid out all the possible CV inputs for LEVEL, SH rate, and DISTORTION,
As far as CV input protection, it is going from jack to 100k, then to a TL072 ic (-) side of the op-amp, standard basic stuff. There is no ~10v Zener Diode or anything like that. i don't recommend just doing a hack directly onto the pins of the Pic with just an input jack, if your gonna add the cv capabilities jumper onto another protoboard with those TL072 buffers like on the PDF. Digital chips get easily damaged if you input more then 5v. The circuit was originally designed for 15v usage so there should not be a problem.
DONOT GET CONFUSED WITH THIS PICTURE, THIS IS NOT THE BOARD THAT WAS ORDERED FOR THE 2nd RUN!!
This pic is just to share and answer a question.
 Filesize:  94.4 KB
 Viewed:  295 Time(s)
Dego
PostPosted: Tue Jun 02, 2009 1:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I would like to have a pcb please. Cool
TekniK
PostPosted: Tue Jun 02, 2009 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for reply haxter
Luka
PostPosted: Tue Jun 02, 2009 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
could you have the circuit for the distortion and extra cv inputs
would make a nice daughter board
problemchild
melbourne australia
TekniK
PostPosted: Tue Jun 02, 2009 4:37 am    Post subject: Reply with quote  Mark this post and the followings unread
its the voltage controle waveform zwitching that is the most interesting part,but its not implemented
a100user
PostPosted: Tue Jun 02, 2009 4:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll take a PCB and burned PIC please?
Not sure how I'll cram it behind a euro panel but I'll worry about that later.
Let me know when you require payment.
Thanks
David
haxster
PostPosted: Tue Jun 02, 2009 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Well with the PCB layout i just posted above you could sacrifice for example the "Level CV" and criss cross that resistor that was supposed to lay straight flat and have it go to one of those CV circuits instead.
I will post the cv circuit alone, first the protoboard style picture, then later a schematic.
haxster
PostPosted: Tue Jun 02, 2009 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is the CV input circuit, the control knob for that input you decide to midify goes to a 5k resistor then to Main Analog positive voltage instead of 5v. I just noticed on the PCB i posted above(not the 2nd run/don't worry) i forgot to do that Embarassed . That's already fixed.
 Filesize:  33.7 KB
 Viewed:  272 Time(s)
 Filesize:  43.04 KB
 Viewed:  280 Time(s)
TekniK
PostPosted: Tue Jun 02, 2009 9:21 am    Post subject: Reply with quote  Mark this post and the followings unread
oh,yes ofcource,am stupid this time,sorry
adambee7
PostPosted: Sat Jun 06, 2009 3:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Boards arrived. Cheers man. Very Happy
numbertalk
PostPosted: Sat Jun 06, 2009 4:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Board made it to Brooklyn and got your email with the zip file. Thanks!!
e-grad
PostPosted: Mon Jun 08, 2009 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Just have received the board and pic. Even though s.o. attempted to smash the box everything seems to be in OK condition. Thanks!!!
haxster
PostPosted: Mon Jun 08, 2009 6:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
2nd Run is now closed
THIS IS THE LIST I HAVE:
2ND RUN TOM WILTSHIRE PCB
JULIANW (2)
RECOMPAS (1)
ach_gott (2)
LUKA (2-4) (NOTE FOR ME: POSSIBLE 2 LEFTOVER)
Funky40 (2)
Danno Gee Ray (1)
Dego (1)
a100user (1)
loopcycle (2)
I will PM you FRIDAY or SATURDAY, THEY SHOULD ARRIVE TO ME FRIDAY. I begin to ship out SATURDAY/MONDAY.
loopcycle
PostPosted: Wed Jun 17, 2009 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
received the boards on monday, thanks!
a100user
PostPosted: Fri Jun 19, 2009 6:14 am    Post subject: Reply with quote  Mark this post and the followings unread
What is the function of the 6 switches (2 DPDT, 2 SPDT and 2 on/off/on)?
Thanks
David
haxster
PostPosted: Fri Jun 19, 2009 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
The six switches are for the Analog LFO only. 3 is for (1) Analog LFO, so the other (3) just mirrors.
Time Switch(SPDT): toggles between (2) Capacitor values to give you 2 ranges in speed.
SQUARE ON/OFF(DPDT) switch: turns the square on/off
Shape Switch (SPDT) w/ center off: toggles shapes---Saw up/triangle(center off)/ saw down.
The simple LFO was influenced from Ray Wilson's SoundLab Plus and modified with the Time Modification.
Download this to help you zoom in and see the pcb if you cannot read a value or get confused.
To also sum it up:
Rev1.1 requires Jumpers
Rev1.2 does not require jumpers
TW_VCLFO(Lite pack).zip
 Filename:  TW_VCLFO(Lite pack).zip
 Filesize:  2.1 MB
 Downloaded:  248 Time(s)
a100user
PostPosted: Sat Jun 20, 2009 4:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Haxster
Looking forward to building this.
David
haxster
PostPosted: Sat Jun 20, 2009 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
This will help when adjusting the 3 trimmers.
 Filesize:  99.82 KB
 Viewed:  201 Time(s)
haxster
PostPosted: Sat Jun 20, 2009 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I built a Motm style one yesterday populating the digital LFO only.
The pic shows Rev 1.1 with the 2 jumpers needed on the pots.
 Filesize:  184.86 KB
 Viewed:  210 Time(s)
 Filesize:  151.12 KB
 Viewed:  194 Time(s)
 Filesize:  198.45 KB
 Viewed:  222 Time(s)
Luka
PostPosted: Tue Jun 23, 2009 11:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
pcbs arrived
the package when through inspection / quarantine :/
weird. i hope the PICs are ok
problemchild
melbourne australia
Funky40
G2 patch files: 5
PostPosted: Thu Jun 25, 2009 12:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
got my boards, thanks alot Haxter !
